Question about Rolex Watches
Is my rolex R1628 8385 750 datejust real or not
  • 26 Answers
SOURCE: Rolex oyster perpetual datejust time/date setting instructions
Unscrew the crown pull out the crown to the first position, One click and rotate the crown clockwise. This is for Quick Set models
For non quickset
Posted on Jan 03, 2009
  • 26 Answers
Depending on how old the watch is, It may be quick set or older models are not quick set. In older models you need to unscrew the crown, pull out the crown and rotate the crown to set the time, and in order to set the date rotate the hour hand past 12 twice in order for the date to change. Set the date first and then set the hour and min. For quick set models unscrew the crown and pull it out to the fist click this position you can "quickly" set the date by rotating the crown. Set the date and then pull out the crown to the second position out. Rotate the crown to set the hour and min. Then push the crown back in and screw it down.
Posted on Jan 06, 2009
escapement
  • 2334 Answers
SOURCE: does anyone have a manual for a datejust rolex
No, there isn;t any downloadable manuals for Rolex watches, but operation of Rolex Datejust is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in date setting position,
3) when you pull the crown further out to the second click, it is in time setting position.
To find the daytime or night time on the watch: pull out crown to the second click and advance watch hands forward till you pass the 12 mark on dial. If the date changes as you pass it - it is the night time (midnight). If the date do not change as you pass it - it is the daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
Posted on Feb 04, 2009
  • 183 Answers
SOURCE: how to change bezel on Rolex Datejust
The bezel is secured by a Teflon gasket. To remove the bezel I would use a watch knife and gently press it in between the bezel and the case. Make sure you go straight in and it might not be a bad idea to use a layer of plastic around the knife so it doesn't leave marks. Also, do not use a widling motion. GO STRAIGHT IN. This will also prevent damage to the case and bezel. Repeat this several times working your way around the bezel. Be sure you don't continue to apply pressure with the knife once the bezel begins to come up as you don't want to damage the Teflon seal. Once you have the bezel out you will need to replace the Teflon seal the exact same way it came off on your replacement bezel and press back into place.
Posted on Sep 18, 2009
escapement
  • 2334 Answers
SOURCE: How do you open the latch on a Rolex datejust
If I understand right, by the latch you mean bracelet clasp. You just pull it by the crown. Clasps on ROLEX watches can be very tight, so, have to pull it with appropriate force. Rate me, plz.
Posted on Feb 09, 2010
Old rolex # 732832 how old
It looks like model 16234, with a jubilee strap. Looking at the dial I would say , 2006 year.
Sep 11, 2014 | Rolex Datejust SS
Watch keeps running but cant move hands to set time on rolex datejust
Debbie is the watch definitely genuine?
It is a common fault on fake Datejust's..is the crown completely out?
Mar 29, 2013 | Rolex Datejust SS
HOW DO I EXPAND THE WRISTBAND ON A DATEJUST PERPETUAL ROLEX
It depends on the model and if it relates to 1960's in its clasp there are some holes to expand the wrist band but you can expand it more by adding reserve piece that you can buy (if you don't have it) from watch makers or authorized retailers. Please be careful because they have tiny screws and are very expensive especially those which are belongs to two tone watches.
Feb 01, 2013 | Rolex Datejust SS
How to set rolex datejust turn-o-graph 116263 time
Unscrew the crown, pull it out and set the time by turning it. After setting the time push crown back in and screw it back on flush with case. Rate me, plz.
Mar 15, 2010 | Rolex Datejust SS
How do you open the latch on a Rolex datejust watch
Feb 08, 2010 | Rolex Datejust SS
How do i remove the bezel to my rolex datejust
RECOMENDATION:
Contact a local official Rolex dealer to address the problem.
GOTO:
http://www.rolex.com
To find a local dealer.
Hope this tip helps.
R/
David
Oct 24, 2009 | Rolex Datejust SS
How to remove a Rolex jubilee bracelet
if its a real rolex, take it to a store dont play around with perfection. but the way a rolex bracelet is held on is by spring bars. look at the back of the watch and put a small screw driver in the lots and push down on the spring bar. then start to ease the bracelet out, now dow the same on the other side the end should come out
Oct 06, 2009 | Rolex Datejust SS
Does anyone have a manual for a datejust rolex
Feb 03, 2009 | Rolex Datejust SS
Rolex datejust
What you have is an older model Datejust -- or at least an older model movement. During the 1950s, many Rolex Datejust models had an alternating red/black date wheel. Tudor (Rolex's second brand) also had movements with the same red/black date wheel.
BTW, those watches are becoming more and more collectible. Sounds like you may have a nice classic on your wrist! :-)
I hope this helps!
Regards,
CharlieJ
[Please rate this solution, if it helps you.]
May 19, 2008 | Rolex Datejust SS
Watches Logo
911 people viewed this question
Top Rolex Watches Experts
Samyfam
Samyfam
Are you a Rolex Watch Expert? Answer questions, earn points and help others
