Question about KitchenAid Washing Machines
We have a bad smell coming from the washing machine. Smells like mildew or mould. What could cause this? It's not the drain, it's in the machine itself.
  • KitchenAid Master
  • 43,501 Answers
Here is a tip about how to clean your washer
How to have a Clean Washer
heatman101
Posted on Aug 31, 2010
Clothes smell after washing cycle
Nice, or not nice?
To get rid of the mildew odor, run an empty machine on the hottest setting with bleach or Affresh ($8, homedepot.com), a cleaner that deodorizes a washer's interior. And after each load of laundry, leave the door ajar to allow the interior to dry.
How to Get Rid of Mold Smell in Front Loader Washing ...
www.wikihow.com > ... > Housekeeping > Cleaning > Laundry Jump to Preventing Smells in Your Front Loading Washing Machine - Part 2 of 2: Preventing Smells in Your Front Loading Washing Machine.
how to get rid of a bad smelling high efficiency washer ...
wholelifestylenutrition.com/.../learn-this-tip-say-goodbye-to-bad-smellin... Learn this tip and say goodbye to bad smelling HE washer machines forever! ... Not only did it smell moldy and musty but my clothes were starting to smell this ... gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==
Why Your Washing Machine Smells, and How to Clean It
laundry.reviewed.com/.../why-your-washing-machine-smells-and-how-t... Add this solution to your machine's detergent container, pour two cups of white vinegar into the drum, and run a normal load at high heat. The baking soda and vinegar should break up any residue stuck to your drum and kill any mold that might be present.
Washing Machine Smell on Pinterest ' Smelly Washing ...
https://www.pinterest.com/explore/washing-machine-smell/ Great tutorial on how to clean your front load washing machine, get rid of mold and mildew and prevent it from returning. I clean mine after every wash (a little ... gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==
Why Does My Washing Machine Smell Like Mildew? - Real ...
www.realsimple.com/home.../cleaning/.../mildew-smell-washing-machine To get rid of the mildew odor, run an empty machine on the hottest setting with bleach or Affresh ($8, homedepot.com), a cleaner that deodorizes a washer's interior. And after each load of laundry, leave the door ajar to allow the interior to dry.
Jan 09, 2016 | Washing Machines
Washing machine smells like mould
The odor may come from several sources. Mildew may be around the door's gasket. That might be cleaned with a rag and a half bleach/half water concoction. The soap dispenser tray may have had stagnant water present. Other hose areas may be growing mildew.
Here are some things you can try:
1) Run dishwasher powder detergent once a month through the washer. Or...
2) Run 3 quarters cup of bleach through an empty hot wash cycle once a month.
3) Yes, baking soda, ye olde oder absorber, can also be tried.
3) Clean the trap (where coins, etc. may be captured). Clean the filter.
Some High Efficiency machines have "high efficiency, HE detergents recommended for them. Does the drum have a soapy coating? If so, it will likely require at least an empty hot water cycle to get rid of the excess soap which may be responsible for the smell.
Naturally, if you are using bleach to clean the the washer door, you want to clean the bleach off too before you ruin some clothes by contact.
Hope this helps.
Aug 04, 2015 | Washing Machines
Kenmore 2600 TOP LOADER smells like Mildew. I can hear water sloshing around under drum. Is that Normal?
The drain on all washers have this issue. Unless the drain hose runs down hill, when the pump stops, water runs back into the machine that was in the hose but was not drained.
Feb 17, 2014 | Kenmore Washing Machines
I have really bad smells coming from the filter part at the bottom when i take it out and their is oalot of water coming from the filter end
A few tablespoons of vinegar in the middle (fabric softener) compartment of the soaps drawer every few loads should help with any smells.
You could add some diluted bleach to the soap and fabric softener compartments and wash something you don't mind getting bleached. It should kill off any mould or mildew that may have build up in the nooks and crannies. Open the button trap door and clean it out as well (front lower right corner - says push and has a large screw plug inside. Close really tightly after or it will leak)
Nov 06, 2010 | Haier HWD1000
The loading door gasket-- the big rubber liner doesn't drain
Some front loaders have a door boot drain hole, most do not and it is normal for some water to accumulate at bottom of boot. To help with mold and mildew use a washing machine cleaning solution, follow directions. Also a bleach solution of 2 parts water 1 part bleach sprayed on area helps. If mildew is really bad, nothing will completly remove it. Make sure you use only a high efficiency detergent.
Feb 03, 2010 | Washing Machines
Odor in front loading duet washing machine
The following link explains how to minimize wash tub odor, and what generally can cause it:
http://www.fixya.com/support/r513372-front_loader_mildew_odor
I personally own one of these washers and have followed this same regiment since I purchased it new 9 years ago. I have never had a mildew or odor problem. Consumers that are not in the habit of using hot water very often will also run into odor and mildew problems, because detergent alone does not always kill bacteria. It is recommended that you run a "Clean Cycle" from time to time, to sanitize. Some newer models have a clean cycle added on the control panel.
NOTE: It is normal to have residual water in the drain lines and in the drain pump. If you need to clean, or check the drain pump, please follow the advice in this next link:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
Debris caught in the drain pump reservoir can often cause some unwanted odors.
If the rubber door bellow develops mildew and mold, use a non abrasive pad (the little green pads are considered non-abrasive) and scrub the rubber with bleach diluted with water (50/50 mix). This will often kill and remove unwanted mold and mildew. If the door bellow becomes embedded with mold or mildew, it may have to be replaced in order to get rid of it.
If you establish and maintain a diligent routine, these washers will not mold or smell. Often what seems to be a dream appliance that is supposed to make your life easier, may actually require more attention in order to maintain it properly.
If you have questions or comments, please let me know. I hope this helps you.
Jan 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Admiral Washer smells like mildew
yes it could . If you are trying to pump the water 7 feet or more above the floor then it will at the end of the cycle get air into the drain hose causing cavatation, the result when the machines stops is the water running back down the drain hose back into the tub and that is what causes the musty smell.
Lower the drain if possible
Apr 10, 2008 | Admiral AW22 Top Load Washer
New Bosch water not draining
This video will show you how to change a door seal on this Bosch front loader washing machine
we have all bosch repairs in our channel
Apr 01, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Musty smell in washer
From another consumer with the same problem:
The mildew smell started about a month after we got it and got increasingly worse! Had a service tech out who replaced the gasket, but he left me a product called WHIRLOUT. It is made for hot tubs and spas and whirlpool tubs. You can get it at a pool supply or Home Depot or Lowe's. It is made to remove the soap scum buildup that provides a growing environment for the bacteria, which produces the smell. You add about a cup to the normal wash cycle. Do not put in the dispenser, add when the water is in the tub. I ran it through twice the first time. Then about once a month to keep it clean. Another thing he told me, don't use dryer sheets in the dryer because they will eventually cause a film to build up on the sensors that tell you when the clothes are dry. I've switched to Downey fabric softener in the washer. He also told me NOT to use a really thick fabric softener because it will not go easily through the dispenser. There is a drain hose by the filter on the washer - pull it out first and drain the left over water into a bowl or pitcher before you clean the filter. This will prevent the mess when cleaning the filter!!! LG never told me this, the same technician showed me this, too!
Mar 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Inside of Washer Smells
often in washing machines there is a drain trap which needs cleaning out from time to time, (usually accessible from the front behind a removable facia) The manual should tell you how to clean this. you need to drain the water first (as there is often a little water still in the system). if you look on the program dial there is often an item that has an arrow pointing down, this should be the drain program, after this is done you can remove the draining cover and clean the workings inside, hopefullt this will solve your problem :)
Sep 27, 2007 | Whirlpool AWZ410 Front Load Washer/Dryer
Washing Machines Logo
169 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
