Question about ASI COMPAL DL75 15.4 WXGA 915GM DDR2 533 SODIMM INTEGRATED VGA GMA900 Motherboard
How do I reset the bios in a DL75. Tried to get into bios screen by pressing F2 but it just keep going to window
How to reset Windows XP Professional SP3 to factory default settings?
Turn Off the computer now as soon as you hit the power button, keep on holding Alt key & keep on tapping F10 key ie: Alt+F10, it will open the recovery console select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
During the boot process you will see on the screen to press a certain key to enter setup usually delete or the F2 key this will differ depending on which bios you have
Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope it helps
Apr 01, 2012 | Microsoft Computers & Internet
I cannot get into the bios
To enter bios would be ether Delete button or F2 when computer starts to boot. if you see windows screen it is past where you have to keep on pressing one of these 2 keys. Start to boot and keep on pressing Delete key and if it does not load bios set up try F2 key. Hope this helps.
Mar 15, 2011 | Acer Aspire One PC Notebook
When I start my computer (a 1 month old Toshiba laptop with Intel i5 core processor that came with Windows 7) it pauses on the prompt screen and then error message "error sending end of post message...
This is usually a BIOS error. In order to fix this you must either perform a system recovery(perferred), or simply restart your BIOS by following these instructions:
System Restore:
1) Go to the start menu.
2) Go to "Accesories."
3) Navigate to the "system tools" sub-folder, and click "system restore."
4) Follow the on screen instructions, and select a date before the problem starter occurring.
If that doesn't work,
Resetting BIOS:
1) Restart your computer.
2) Press the "F2" button while your computer is booting up over and over again until you arrive at the BIOS setup screen.
3) Press "F9" to reset BIOS.
4) Press "F10" to save your previous BIOS settings.
Mar 09, 2011 | Sony Computers & Internet
How to reset bios my dell vostro 1500 . (11R50G1-595B)
To reset the BIOS please follow the below steps.
1 . Restart your Dell laptop. Click on "Start," "Turn off Computer" and "Restart."
2 . Press "F2" during the boot process to enter the BIOS. Press "F2" before the Windows loading screen. Certain models may use a different key. The key will be displayed during the boot process. For most Dell models, the key is "F2."
3 . Use the "Alt" + "F" key combination to load defaults.
4 . Press "Esc" on your Dell laptop keyboard to save and exit.
5 . Choose the "Enter" key to save all changes and exit the BIOS screen. Allow your laptop to restart for BIOS settings to reset.
Thanks. Have a great day.
Dec 30, 2010 | Dell Vostro 1500 Notebook
I want to wipe my hard drive completely, and i downloaded dariks nuke and boot. but i dont know how to open my bios and do it. so how would i go about opening my bios? i own a dell inspiron 1525
To get in to bios you have to reboot and once screen turns black keep on pressing F2 key but dont hold it down but tap it and it will bring you in to bios menu. Some dell's use "Del" (delete) key so if this is the case just do same thing instead of tapping F2 just keep on tapping "Del" key. This will take you into bios. If this daris nuke does not work just put in your windows cd and reboot and on black screen just keep on tapping key F12 and this will ether give you boot menu to choose form and you need to choose cd or dvd rom or sometimes it will go in to it right away and it will say "press any key to boot from a cd-rom" so you can press any key on keyboard (like space bar) and then choose option to install windows and not repair, choose delete partition which is usually like couple screens(one is letter L and one is just delete) and then choose install windows and choose quick or normal format. Once formatting is done it will start the new install. Good luck.
Nov 04, 2010 | Computers & Internet
When I turn notebook on it only powers to the screen that says f2 for set up or f12 for boot options, occasionally I can hold the f12 key while powering up notebook, release key when it comes to that...
try to reset the bios to factory defaults to do that keep tapping the f2 key as soon a you turn on the computer until you see the bios screen then using keyboard go to a tab which says boot then press f9 key press 'y' to confirm then your computer should boot properly everytime..
take a look at this picture just to show you how that screen looks if this doesn't work try doing system restore..to do system restore try this link..see the use system restore topic
Oct 02, 2010 | Toshiba NB205-N210 Netbook
Inspiron laptop clock incorrect
Go into the BIOS by turning on the laptop and pressing F2. In there i believe on the main screen you can change the time and date. Do that, save changes and exit and then go into windows and see if it keeps the right time and date.
Let me know how it goes.
May 12, 2009 | Dell Inspiron 1525 Laptop
Receiving PXE-E61 media test failure/PXE-M0F exiting intel PXE RO
If you get this error in a black screen before windows xp can boot up....
CLIENT MAC ADDR: xxxxxxx GUID: xxxxxxxxxx
PXE-E53: no boot filename recived
PXE-MOF: exiting intel PXE Rom
Your network card's settings in bios have somehow been changed. PXE means Pre-Execution Enviroment. In other words, it allows your network card to connect to a network server to pull operating system images off the network and other files without having an operating system installed.
The Fix,
Go into BIOS press F2 or F12 whatever your PC's screen at bootup says. In Bios, reset your bios settings to the default bios settings, or original settings. This fixed my problem with the above error. Nothing else fixed it. Windows Recovery cd will not fix it, because you cannot boot windows if this error is still occuring, Your network card will keep prompting DHCP to search for a network.
Its a bios function not a windows function.
Jan 21, 2009 | Toshiba Satellite A135-S2276 Notebook
HOW TO BOOT
While your computer is booting up, when the manufacturers screen comes on, press and hold F2
Jan 28, 2008 | Compaq Presario X1000 Notebook
Computers & Internet Logo
41 people viewed this question
Top ASI Computers & Internet Experts
marley mcelhinney
Are you an ASI Computer and Internet Expert? Answer questions, earn points and help others
