Question about Sharp AL 1631 Copier
Replace toner How do I put new toner into the cartridge
  • 62 Answers
Dear sir,
Commonly the sharp and toshiba toners are normally sealed units, therefore no toner refill avaibable.
Contact your service outlet to order a new toner cartridge
Posted on May 13, 2008
Where is the drum on the MFC-8860DN and how do I remove it?
The drum is part of the laser toner cartridge
Open the front door
Press the square button in the center of the paper receiving are, it is marked with a small triangle
Press and pull, it will open a door showing the toner cartridge
Pull out the toner cartridge
The top part is black and the bottom assembly is grey
There is a blue little latch in the right side of the cartridge
Press the latch and the toner cartridge will be release
Remove the toner cartridge.
You need to replace the grey bottom assembly with a new one
A compatible assembly, which will have a new drum, will cost around
$30 at amazon an oem around $70
Reassembly and reinstall in reverse of the disassembly
I hope this was helpful
Mar 17, 2015 | Brother MFC-8860DN Printer
DCP 7060D replace cartridge
I suggest You Go To
Above URL Link To Fix Your Brother Printer Issue Or Brother Printer Problem To Perform Below Brother Printer Step:
REPLACE TONER (video instructions available)
The message REPLACE TONER indicates the toner cartridge needs to be replaced with a new one. Please follow the steps below to replace the toner cartridge.
NOTE: Videos and illustrations shown below are from a representative product and may differ from your Brother machine.
The Brother machine has separate consumables: the toner cartridge and the drum unit. Verify you replace only the toner cartridge, and not the drum unit. Click here to see the difference between the toner cartridge and the drum unit. Also you can confirm the order number (Order No.) of the toner cartridge on the Consumables & Options page. Click here to go to the Consumables & Options page.
Make sure that the machine is turned on. Open the front cover and leave the machine turned on for 10 minutes to cool down.
* This movie is being streamed from YouTube. (Opening new window.)
You must ensure the machine is turned on when you replace the toner cartridge so that the machine recognizes the toner has changed.
After you have just used the machine, some internal parts of the machine will be extremely hot. Wait for the machine to cool down before you touch the internal parts of the machine.
Hold your Brother machine with one hand, and take out the drum unit and toner cartridge assembly by pulling on the handle in the middle of the drum unit and toner cartridge assembly. We recommend that you place the drum unit and/or the toner cartridge on a clean, flat, level, stable surface with a sheet of disposable paper or cloth underneath it in case you accidentally spill or scatter toner.
DO NOT use cleaning materials that contain ammonia, alcohol, any type of spray, or any type of flammable substance to clean the inside or outside of the machine. Doing this may cause a fire or electrical shock.
DO NOT use any type of spray.
Push down the green lock lever and take the toner cartridge out of the drum unit.
DO NOT put a toner cartridge into a fire. It could explode, resulting in injuries.
Be careful not to inhale toner.
Handle the toner cartridge carefully. If toner scatters on your hands or clothes, immediately wipe or wash it off with cold water.
To avoid print quality problems, DO NOT touch the shaded parts shown in the illustration.
Be sure to seal up the toner cartridge tightly in a suitable bag so that toner powder does not spill out of the cartridge.
Go to Above Mention Official Brother Printer Url Link for instructions on how to return your used consumable items to the Brother collection program. If you choose not to return your used consumable, please discard the used consumable according to local regulations, keeping it separate from domestic waste. If you have questions, call your local waste disposal office.
Unpack the new toner cartridge. Hold the cartridge level with both hands and gently shake it from side to side several times to spread the toner evenly inside the cartridge. Pull off the protective cover.
Wait to unpack the new toner cartridge until immediately before you put it in the machine. If a toner cartridge is left unpacked for a long time, the toner life will be shortened.
Put the toner cartridge in the drum unit immediately after you have removed the protective cover.
To prevent any degradation to the print quality, DO NOT touch the shaded parts shown in the illustrations.
DO NOT touch the toner surface.
Brother strongly recommends that you DO NOT refill the toner cartridge provided with your machine. We also strongly recommend that you continue to use only Genuine Brother Brand replacement toner cartridges. Use or attempted use of potentially incompatible toner and/or cartridges in the Brother machine may cause damage to the machine and/or may result in unsatisfactory print quality. Our warranty coverage does not apply to any problem that is caused by the use of unauthorized third-party toner and/or cartridges. To protect your investment and obtain premium performance from the Brother machine, we strongly recommend the use of Genuine Brother Supplies.
Put the new toner cartridge firmly into the drum unit until you hear it lock into place. Make sure that you put in the toner cartridge properly or it may separate from the drum unit. If you put it in properly, the green lock lever will lift automatically.
Clean the primary corona wire inside the drum unit by gently sliding the green tab from left to right and right to left several times. Be sure to return the green tab to the home position. If you do not, printed pages may have a vertical stripe.
Put the drum unit and toner cartridge assembly back into the machine. Close the front cover.
After replacing the toner cartridge, DO NOT turn off the machine's power switch or open the front cover until the LCD clears the Please Wait message and returns to Ready mode.
If the error message still continues to appear, refer to
If You Still Having Brother Printer Technical Problem then Follow Us For On :
Brother Printer Support
Jan 23, 2014 | Brother Office Equipment & Supplies
Are you sure it was a full NEW toner cartridge?? Not an old one you had lying around.
If it was a new one the next question line goes as follows.... the machine will say in the display to "Rplace toner soon"...that dosn't mean its empty and to replace it..that means itsLOW and you should have a new toner cartridge "on-hand" because it will soon stop printing and say "REPLACE TONER". At that time the toner cartridge should be replaced, when it is installed a "fuse" on the cartridge blows and resets the toner light on the display. If you installed the toner cartridge when the display was saying "replace toner soon" you have blown the fuse in the new cartridge, now the machine has run about another 100 copies and says "replace toner"....but you now can't reset the light because the fuse is already blown because you may have replaced the cartridge too early!!! WHAT CAN YOU DO if that is the can replace the fuse on the cartridge..its pretty easy to see, just replace it with another mini-fuse of the same rating written on the existing fuse..then put the cartridge in again..the fuse will blow, reset the light and away you will go. When all else fails read the operators manual.
Jan 23, 2011 | Muratec MFX-1430 Copier
BROTHER-MFC7430 Toner life end
actually, you dont' really need to replace your drum, your drum actually is good for 5-6 years.
you just need to clean up the drum with duster and put that back into the machine.
when reset the drum, you just need to open the front cover and press Clear buttom then 1.
after that the whole thing will be reset and ready to go for it.
Dec 27, 2010 | Brother MFC-7340 All-In-One Laser Printer
Dell 3100n keeps saying "Change Black Toner" even
Before installing a new toner, put a disposable towel over the ink toner exit, and shake your toner lightly back and forth and up and down. Make sure your toner cartridge is in the open position before replacing it in your printer.
If you are using a refillable ink cartridge, make sure you are resetting the cartridge using the method described by the refillable manufacturer.
If this does not answer your question please request more information before voting on my answer. I will try to find more information about your toner cartridge that will help you futher.
Nov 16, 2010 | Dell 3100cn Laser Printer
Need to replace toner. Do I buy a whole new toner cartridge or just toner and if just toner, how do I put the liquid in? Thank you
It is always better to buy a whole new toner cartridge than to deal with the mess of trying to refill the old one. So therefore as a technician I would recommend you buy a whole new toner cartridge.
Aug 24, 2010 | Canon PC1061 Copier
Put in new toner still says toner needs replacement ? Using original Brother toner?
Brother says a standard toner cartridge will print about 3500 pages ... Things You'll Need: Replacement toner cartridge; Piece of paper ... Turn off the printer and allow it to cool for at least 15 minutes, if you have been using it recently. ... Put the new toner cartridge in the printer same way the old toner ...
Jul 20, 2010 | Brother MFC-7220 All-In-One Laser Printer
Toner life end
There is no reset code the likely thing is that you have a faulty toner cartridge. Put another new one in and check the machine then.
Before you try the above shake the toner cartridge and tap it some more as it may also be the toner inside have become solid and needs breaking up.
Hope one of the above works for you
Thanks J
Jan 08, 2008 | Brother IntelliFax-2820 Laser Fax
Keeps showing J1 error, toner light is flashing
The J1 error means the toner cartridge needs to be replaced. Since you just replaced the cartridge, you should remove the cartridge and repeat the following steps.. Shake the new toner cartridge horizontally four or five times and then remove the cover. Slide the new toner cartridge in until it locks in place. It sounds like the cover may still be on the cartridge.
May 14, 2007 | Xerox WorkCentre XD103F All-In-One Laser...
Sharp AL 1631 Copier Logo
70 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
