Question about Epson Stylus CX4800 All-In-One InkJet Printer
Tried several time to clean nozzles and even installed new Epson cartidges but results are lousy on all three colors. Black prints fine. Wiped down the contacts with still no improvement. Any ideas?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 150 Answers
Make sure the alignment is correct. it has an auto alignment option if you can explore the options
Posted on Aug 31, 2010
I installed a new black ink cartridge and now it won't print black even though it shows its full on in levels
If your black cartridge was empty for any length of time before you replaced it, even if it was still installed in the printer, chances are that the black print head nozzle has dried ink in it. Cleaning may or may not resolve the problem, but cleaning also uses obscene amounts of ink. Epson printers are notorious for clogs since they have some of the smallest print head nozzle sizes (thus their high dpi resolution).
There are some Youtube videos that suggest ways to clean severely clogged Epson print heads. I cannot vouch for them as I have never tried them, but you can view them and decide for yourself.
Feb 04, 2016 | Epson WorkForce WF-3620 Wireless Color...
Epson C88 3/16" gap every inch printing black text
Reload the printer drivers, you can get this from the manufacturers web site under support or downloads.
its a common error and an easy fix.
good luck !
Mar 30, 2017 | Epson Stylus C88 InkJet Photo Printer
The black ink will not print on my Epson Stylus SX600FW printer. Th eprinter was left for a few weeks without black ink. Has the needle heads dried up and become clogged? How can I fix this problem?
I have an Epson sx600fw which has had a problem printing with black ink. I spent alot of money trying genuine and cheap inks as official advice is to replace with a genuine epson cartridge and clean up to 6 times before seeking further help. Tried this to no avail. By accident I found that if you set the paper type to glossy or photo then miraculously the black will work but in this setting it is slow. Epson replace the printer under warranty but I have just received a new one and it has exactly the same problem. I am slightly reluctant to buy another set of genuine inks to waste through 6 cleaning cycles as they are over £35 so am not sure what to do but I guess I will approach Epson again.
Sep 11, 2009 | Epson Stylus Multifunction Inkjet Printer/...
How to use only black cartridge on cx7450 epson !
Hi, this is not a solution because I don't think there is one apart from buying new inks. You need to consider 2 things, firstly the official line: Epson (and all other inkjet manufacturers) do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing. It is also why the "print in Black only" option (available on some printers) only works when the coloured inks are OK.
The 2nd unofficial line is that it is a win-win situation for manufacturers. Firstly they get to cut down on costly warranty call outs for blocked heads (replacement printers, technician manhours, etc) and secondly they get to sell lots more inks (Ka-ching!). If you really want to print black text only (and save cash on price per-print) then a mono-laser printer is the best way as they can now be bought at inkjet prices.
Apr 06, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Black and white not printing correctly, color is fine
If you are not using Epson ink, your printer will do this. Epson printers hate knock-off ink. Always use Epson ink if you want to keep your printer working properly. To solve the problem you are having, try cleaning the ink tubes. Make sure you re-install them properly. Hope this helps. Charlene
Feb 10, 2009 | Epson Stylus CX3810 All-In-One InkJet...
HP PSC 2410xi color printing issues
Try using warn distilled water and Q-tips to gently clean the area where the ink cartridge and the carriage mate up. You may have dried old ink in there which is clogging the print nozzles. Allow to air dry, reinstall cartidges, start machine and let it go through its cleaning cycle. Also check www.hp.com. Hope this helps.
Jan 30, 2009 | HP PSC 2410 All-In-One InkJet Printer
Black does not work after multiple head cleanings
It sounds like the black nozzle is clogged. I am not sure if that is a part that is end user serviceable. Best bet would be to call Epson and see if it is something you could repair or if they need to have you send the unit to them. Sorry.
Jan 10, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Printer cartridge problem
I have a 440 and have had the same problem. Of course, I have been using cartridges from Printpal, Inkgrabber, etc. that are not official Epson. I have found that it takes several cleanings and after the cartridge has been in the position for the ink to go down it will start. My last order from Printpal said to set all the cartridges in the position they are in when installed in the printer for several days prior to installation. Of course, every cleaning of the print head uses up more of your ink. You don't have much choice though.
May 07, 2008 | Epson Stylus Color 440 InkJet Printer
Printer refuses to print black
Hi, I have question?
The ink that yuo are change are original epson cartidge ink?If yes , try to head cleaning twice and then nozzle check ,then the result of test print are soild in color are good , the unclean head having plenty spaces within the color in test print.
Jan 07, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus CX4800 All-In-One InkJet Printer Logo
46 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
