Question about Siemens CF110 Cellular Phone
Need wiring diagramme for simpson model 39-081-320 tumble dryer
Where can I obtain a spare motor and wiring diagramme for an unidentified dryer?
are there part numbers on the parts you are looking for
Feb 02, 2016 | Dryers
How to wire Simpson 1200S dryer motor
Check with Simpson directly to obtain the diagram.
Jun 10, 2014 | Dryers
Simpson Dryer only blows cold air
It's either the fuse, heating element, thermal cut-off or thermostat
May 20, 2012 | Washing Machines
Simpson Maxidry Tumble dryer (Cloths dryer) How
Hi there, There is a switch at the bottom of the dryer. It has a groove for the spring to fit around. Then the spring goes through the metal tag with the holes in the pulley. The pulleys 2 prongs then fits into the slot near the motor. The belt goes through the pulley and around the motor wheel. When fitting the drum, tape the belt at three points on the drum with the machine door facing down making installation easier. Once installed remove the tape. The dryer now works like a dream. See the attached photo. Good Luck!8e72e75.jpg
Jun 21, 2010 | Dryers
Simpson sirocco clothes drier tumbles ok, but heater not working
Bad heating coils, or bad ignitor if gas.
GE Dryer Model #DWSR483EB2WW Dryer tumbles,
Does it get hot when you start the dryer, and never gets hot again when its running? The solenoid wire might be opening due to heat, the solenoid is responsible for opening the gas valve, and booster valve. The wire is located in a round plastic sleeve with two electrical contacts sticking out.
Dec 11, 2009 | GE DBSR453EBWW Electric Dryer
I have a maytag model 747g dryer. I dryer tumbles
The heating element is burnt out. Unplug the dryer. Follow the wires from the control panel. They will go to the heating element. The element is probably held in by anywhere from 2 to 6 screws. Remove the screws and you should be able to pull out the element. The element is coiled wire that heats up when power is applied. If you look closely you can probably see a break in it. To get a replacement you will need the model number which will be on a metal plate either on the back of the dryer or inside the dryer door. Take the old part with you so you can do a comparison and make sure you get the right part.
Jul 17, 2009 | Dryers
Diagram of how to replace drive belt on simpson sirocco 500 tumble dryer
May 12, 2009 | Dryers
Dryer won't tumble
Check thermal fuse located behind rear panel mounted on dryer (depending on model of the dryer) duct. Fuse is the component with 2 blue wires and is white in color. Try jumping 2 wires together or OHM out fuse. Fuse being bad is a sign that either
a) Dryer vent is clogged ..... If dryer takes any longer than 1 60 min cycle to dry loads than the vent IS CLOGGED!!
b) Dryer thermostat (next to fuse with 4 wires 2lg red and 2sm)
is not cycling proper
c) some other electrical short causing element not to cycle proper
Check Temp of discharge air with thermometer
on High should cycle on somewhere around 120
and back off at no higher than 170 no less than 155
Jan 18, 2008 | Dryers
Siemens CF110 Cellular Phone Logo
158 people viewed this question
Top Siemens Cell Phones Experts
Computer Repairing
Computer Repairing
michael galang
Yoav Shilon
Yoav Shilon
Are you a Siemens Cell Phone Expert? Answer questions, earn points and help others
