Question about InFocus LP 820 Multimedia Projector
The projector will power up and run for a minute and then powers back off. It will occasionally restart on it's own.
  • 3,153 Answers
Maybe start with a good clean out first.
I tend to use those cans of air meant for computers but dont poke the nozzle in too far !
If it still has issues then its time to start opening her up to check the fan and such.
Posted on Aug 31, 2010
LP820 projector powers up and all is well. After about 40 seconds to a minute it powers down. Control panel lights are on and LCD display says restarting. It comes back on for a couple of seconds and...
It could be are any of the led's blinking. ?
The other thing is to check the bulb is seated correctly in its connector.
Try removing bulb and reinserting.
Also clean the air filters at same time to make sure they are fine.
Please dont forget to vote if you liked my answer
thanks
Feb 10, 2011 | InFocus SP-LAMP-012 Projector Lamp for...
Panasonic PTL500U LCD HiDef projector. Unit occasionally powered up briefly, lamp lit, then shut down, standby LED flashed orange/red. Sometimes lamp lit and sometimes not. Technician diagnosed bad ballast...
If you take the back off you might find a couple of bulged electrolytic caps on the power supply board that need change, or just buy a new power supply at www.partstore.com
Dec 22, 2010 | Televison & Video
Epson 77c Projectors occasionally freeze - controls don't work
this is maybe overheating problem, check that the fan on it is working
Fosg2000, please Rate me
Mar 16, 2010 | Epson PowerLite 77c Projector
I just replaced the bulb unit in my Toshiba TDP-MT800 projector but when I press the power button nothing happens
Make sure the Lamp is seated correctly and firmly and the microswitch on the lamp door closes. Some projectors require a button sequence to be held down whilst powering up the projector in order to reset the lamp counter and restart it. You could also try the old lamp back in it for a few minutes to see if it starts up using the old lamp, providing it hasn't shattered.
Good Luck
Dec 31, 2009 | Toshiba Office Equipment & Supplies
Infocus Screenplay 5000 - Pop - Gone!
the power supply is bad. there is a fuse on it, but it wouldn't be a occasional problem. the caps on the ps board may be drying up and causing it notto function. replace the ps.
Jun 30, 2009 | InFocus ScreenPlay 5000 Multimedia...
InFocus LP130 Projector has intermittent power off
go into the menu to find out the lamp hours. it could be the lamp, but if the projector shuts down and not just the lamp, there is either an overheating issue, or a power supply issue.
Mar 07, 2009 | InFocus LP130 Replacement Projector Lamp -...
Projector overheats after 30 minutes and shuts down
Is the fan in your projector still working in high speed or not spining?
Dec 15, 2008 | Sanyo PLC-SW30 Multimedia Projector
Projector shuts off after about 45 minutes
Just a long shot, but...
I have an epson 9000i that did the same thing. Turns out that unit has a small fan (I think 60mm) right next to the power supply to keep it cool, in addition to the large fan that exhausts past the lamp. The fan runs non-stop as long as the unit is powered-up for two reasons I can think of - keep the power supply a little cooler, and the lamp a little warmer so there's not such a temp difference when it powers-up. Long story short, that fan had died. I replaced it with an aftermarket 60mm fan and it's been working fine ever since. Hope this helps.
Bob
Jun 03, 2008 | Epson PowerLite 5550C Multimedia Projector
My Panny AE700U shut down & won't restart
HI there
This is a faulty Mainboard that will need either repair or replacement.
If a Projector starts playing on and off tricks I have found it to be 99% of the time a faulty Mainboard.
Apr 13, 2008 | Panasonic PT-AE700U Multimedia Projector
Projector turns off
hi there may i give a shot?
fan sound get lourder......that is normal after start up
check the bulb
check the filter
restart the projector reset button back of projector
Oct 31, 2007 | Canon LV-5210 Multimedia Projector
InFocus LP 820 Multimedia Projector Logo
174 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
