Question about Delta Faucet Plumbing
Can you actually remove a diverter from the spout without taking the spout off? When the diverter is lifted up only a little bit of water comes out of the shower and the rest continues to come out of the tub spout. I don't have the model # but it appears to be a Delta tub spout.
  • 43,501 Answers
No often the problem is that the metal deteriorates inside of the spout...
Replace the whole spout... it will either spin off or there will be a small setscrew underneath at the back and then it will pull off...a new one is not that exspensive...
heatman101
Posted on Aug 31, 2010
  • kamoor01 Nov 08, 2010
    do you have to shut off the water supply before unscrewing the spout ? (or is just having the handles turned off enough ?)
  • D. Floyd Kolb
    D. Floyd Kolb Nov 09, 2010
    You can just have the handles off and you will be ok...
Tub spout diverter
Check the basement. There may be a valve (two valves) that someone partially closed in the past to limit how much water was used for a bath.
Dec 21, 2013 | Plumbing
I installed a single lever shower unit when water is turned on i water out of spout and shower head . i took it a part all washers look good and doubled checked unit was put on right to water lines
You should also have a diverter in the spout. Just turn the old spout off and turn the diverter spout on. You lift the ball on top to use the shower.
Dec 05, 2012 | Delta & Single Handle Shower Faucet
Little water comes out my shower head when I take a shower, should I call a plumber, or is this something that I can fix myself?
remove the shower head. and if the water flows normal, its a clogged up shower head. if takeing a shower and the diverter valve goes bad. water will come out of the spout. check out shower head to see if its clogged. sometimes you can soak the head in a good cleaner and it helps it. but if its the showerhead thats plugged. you can always put a new one on also. good-day !
Jan 10, 2012 | Home
I have an American Standard model 4251 with poor water flow from spout. Sprayer works great but little water flow from the spout. Aerator is clean. If I take out the diverter flow is much better. Looks...
Contact A/S via web site they will probably send you a new diverter free if you raise enough stink about having this problem and you would just buy another brand faucet.
May 30, 2011 | American Standard 4251 'The Standard...
I recently move into a condo that has a Delta single lever Series 1400 single lever bathtub fixture. The bathtub has a shower nozzle that looks like it has been used. I cannot find where there is a button,...
Is there a button on the tub filler? How about the spout on the tub, does it lift up? If there is not a tub spout then it should be shower only, if it has a tub spout it has to have a lifter of some sort, the foto I found showed the little button lifter. Hope this helps.
May 29, 2010 | Delta & Single Handle Shower Faucet
Moen Tub Filler Can't Remove Spout
It should lift off gently twist as you lift maybe tap spout lightly back and forth with a rubber mallet
Oct 14, 2009 | Moen Kingsley Two Handle Roman Tub Faucet...
Need to know how diverter works and which way insert in same shou
When you pull on the handle a flap or little valve blocks the flow of water to the spout, making it run to the shower head
Long story short, since I've spent the entire day at different hardware stores, and websites looking for the answer, and figured it out... before taking the advice of so many and replacing the entire spout..
The little black rubber washer is the value. When water pressure pushes against the hole, it actually pushes this black valve out just enough to stop the water from flowing, and the water flows to the shower head. If water is pouring out, try cleaning this black valve with toothpaste, as someone on another website recommended, and reinsert the valve. But don't push it all the way in. Water need to get behind this valve in order to function properly.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 05, 2009 | Plumbing
Pull down shower diverted works, but allows bypass into tub
The diverter is supposed to leak a little bit, so it will disengage after you turn off the water. If the water is leaking out a little, that's normal. But if it is really leaking out you may need to replace the entire spout.
Aug 11, 2009 | Delta RP17453SS Standard Diverter Tub...
Sprayer loosing presure
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)
Here are the instructions:
  1. Turn off water to faucet.
  2. Remove handle.
  3. Remove top cap.
  4. Turning spout back and forth gently lift and remove.
  5. Remove and replace diverter.
Hope this helps and please remember to rate this!
Dec 09, 2008 | Delta 2402 Classic Single Handle Kitchen...
Water runs out out both places for spout and shower head in tub!!
try replacing spout, sounds like the old one is a lil bit worn
Oct 26, 2008 | Home
Plumbing Logo
221 people viewed this question
Top Delta Faucet Plumbing Experts
Donni Steen
Ed Mac
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
