Question about Maytag Dryers
My gas dryer does not come on when you push the button and it has a burning smell .
  • Maytag Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Posted on Aug 31, 2010
A burning smell inside the drum when I use the gas dryer
The burning smell is usually one of two things. If it smells like burning rubber the dryer belt is on its last leg and is slipping or stuck. If you are a diy'er the replacement of the belt is more time consuming than difficult. If it just a burning smell, then it is most likely lint built up inside the exhaust. You'll need to scoot the dryer out and get behind it to take off the dryer hose that vents from the dryer to the outside. Take off both ends for the most convenient and thorough cleaning. You'll need to blow out the hose with an air compressor and/or push a cylindrical brush through the hose or a rag on the end of a long stick. Be care not to puncture the hose! Once done, you are not finished cleaning. The back panel of the dryer needs to be removed to access the exhaust's internal pathway. You can try to clean it from the lint trap and the place in the rear where the dryer hose attaches, but be aware that cleaning cannot remove all the lint stuck to the exhaust pathway lining. At Home Depot, Lowe's or Menard's they sell brushes on wire, etc to clean the dryer's inside exhaust pathway.
Hope this helps!!
Jun 13, 2016 | Dryers
Amana gas dryer Model #ALG866SWB: When pushing
The motor is bad and needs to be replaced.
Jul 23, 2010 | Amana ALG643RB Gas Dryer
Burning smell, Loud noise when start button and doesn't turn on
Belt, and skid plates very easy to change and not much money
Aug 12, 2009 | Maytag Neptune MDG5500AW Gas Dryer
When I push the start button on my maytag neptune dryer it sounds
MORE TIMES THAN NOT, WHEN I HAVE SEEN THIS PROBLEM, IT TAKES A NEW MOTOR TO CORRECT THIS SITUATION. MAKE SURE EVERYTHING MOVES FREELY BEFORE CONDEMNING THE MOTOR THOUGH.
Jan 29, 2009 | Maytag Neptune MDG5500AW Gas Dryer
KENMORE DRYER WILL NOT START
It sounds like the motor has burned up or is burning up is why you are getting that smell. There could at the same time be a wire that has come loose or burned off that is causing it not to come on.
Jan 26, 2009 | Kenmore 73952 Gas Dryer
LG Gas dryer doesn't dry clothes in one cycle
Have you checked your outside vent while it was running to see if the dryer was venting 100%. If your clothes are hot and humid I would say clean your vent pipe has a blockage and needs to be cleaned out. Also as far as the burning smell you could take the front off (unplug first) the dryer of by removing 4 screws one above and one below the latch and two at the bottom and there are two clips one at the top left and right push in with a puddy knife and lift the top up a couple inches and lift the front up off the bottom holders. Then you will have access to vacuuming the lint that is floating around the burner.
Dec 01, 2008 | LG DLG5932W Gas Dryer
Maytag mde9206ayw
HI WHEN YOU PUSHED THE BUTTON TO START DID IT HUMM IF IT DID YOUR MOTOR IS THE PROBLEM ESPECIALLY THE BURNING SMELL
May 24, 2008 | Maytag PYE2300AY Electric Dryer
Dryers Logo
48 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
