Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
The freezer is cold on our Kitchenaid side by side but the refrigerator is not. When the freezer door is open, cold air comes into the refrigerator. When I close the freezer the cold air stops coming into the refrigerator. Help!
  • KitchenAid Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Posted on Aug 31, 2010
I have a kitchenaid superba ksrs25ilwh side by side fridge. The freezer is working fine but the fridge wont get cold enough even at the lowest temp
check the damper vent door for proper opening and closing as if this door is frozen shut or broken and jammed it cant open to let cold air in from freezer it will be behind a plastic grille between the freezer and fridge compartments and you should hear a fan in there running to move cold air too
Jul 02, 2011 | Refrigerators
Kenmore side by side freezer is working and air flow is ok with freezer door open...when close freezer door cold air flow to fridge stops
fan sometime runs when doors open only. if freezer is set too cold then a little door leading to refrigerated compartment freezes shut with frost and then the cold air cant get from freezer to refrigerator. good luck
May 07, 2011 | Refrigerators
I have an Amana side by side refrigerator. Last night I noticed water running from underneath and the ice cream in the freezer melting. I found dog hair clogging a vent and cleaned it. This morning the...
usually when the bottomof the freezer is cold and the top isn't it's the evap fan motor isn't working and all the cold air sits at the bottom.when you open the freezer door you should hear the fan running inside the freezer,also tried to look up your model but it didn't come the fridge door,look up on the right and hear the cieling and you'll see a tag with the model and serial numbers,i just need the model number and i can help you better
Jan 30, 2011 | Amana ARSE66MB Side by Side Refrigerator
Refridgerator side is getting warm
the refrigerator side of most modern day units only gets cold by cold air being blown over from the freezer side so check the fan in the freezer to make sure it is working as well as check the damper that opens and closes to let cold air over to the refrigerator side
Apr 05, 2010 | KitchenAid KSCS25FKSS Side by Side...
Fridge not cooling
your defroster seems to be out. This is located in the space between your freezer and fridge where your temp. control is. This defroster can be purchased at an appliance parts supply take model number and serial number with you in order to get the correct part. Once part is obtained follow instructions and unplugg unit before servicingf
Jul 13, 2009 | KitchenAid KSCS25FKSS Side by Side...
Freezing in refrigerator
Inside the fresh food compartment on top left there is something called an air baffle. It runs between the freezer and fresh food compartment and its purpose is to electrically control the amount of cold air coming from the freezer. Sometimes they freeze open and will not close. So you may need to turn off the refrigerator during the time you examine it. Look for ice blocking the movement of the baffle damper. Sometimes just one time clearing the problem is all you need to fix it. Let me know what you find and if you are able to get it going again, Thanks, Sea Breeze
May 20, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Freezer works fine but fridge side stays at about 45 degrees
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system.
Jan 10, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Kitchenaid refrigerator w/bottom freezer french doors
please check the air flow to the refrigerator side. it could be a stuck damper motor or damper thermostat. if the fan inside the freezer is running, you should be able to feel cold air coming out off the vents in the refrigerator side. you might have to press the button light switch on the panels to run the fan.
Feb 19, 2008 | KitchenAid Architect KBFA25ERSS Stainless...
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
146 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
