Question about Rowenta DE851 Iron
The top plastic piece that runs the length of the top of my Rowenta DE 831 broke. Can I get a replacement part for this? Can an exploded view of the parts be obtained, or a manual? Thanks.
  • 17,129 Answers
Only if you check up with Rowenta this part will be available but if you can search around in service shops you may be able to salvage one from a coil damaged iron that was discarded.
If not fabricate the top with a fibreglass or plastic repair shop and it can be doe to suit the top after a paint job.(If broken use good glue and then paint on top)
Posted on Aug 31, 2010
Rowenta steam iron fell down and top part is broken can it be replaced
Rowenta Iron Parts - eReplacementParts.com
www.ereplacementparts.com/rowenta-iron-parts-c-180639_180647.html Fix your Rowenta Iron today with parts, diagrams, accessories and repair advice from eReplacement Parts! Worldwide ... DE0554 Rowenta Steam Iron Parts.
Aug 08, 2015 | Rowenta Irons
Parts for Model DG8030
Google Rowenta repair. They have stations all over the US.
Jul 25, 2014 | Rowenta DG8030 Expert Pressure Steam Iron
Where can I get replacement parts for Rowenta irons?
Fixya is unable to advise parts sources.
Aug 15, 2017 | Irons
Where can I order the steam trigger part that is broken. I need the part number. It is a Rowenta DG980. Thanks
Rowenta RS-DG0123 Knob Trigger, Blue
http://www.smallappliance.com/product.asp?pid=4477&cur=USD&cam=GA_B_rowenta_part
Carefully pry off blue handle cover on top with a popsicle stick.
A quick (maybe permanent) fix while waiting for your part: you can "weld" the plastic trigger back together. It doesn't have enough surface area for glue. Position the break back together. Secure parts so they don't move. Heat a medium-small flat blade screwdriver until it will just melt the plastic with a gentle touch. Touch the tip parallel to the break and melt a shallow groove about 1/4 of the way into the break. You should be centered on the break so you melt a bit of each piece. This will be the start of melting the two pieces together. Now, as you do each side of the break, use the flat of the blade to "trowel" the curled up plastic back into the groove you just made. Be careful not to distort the side that activates the switch. Ours is holding so well that I keep the new part in case this ever breaks again.
Less is more: use only enough heat to melt the plastic with a gentle touch. If it's red-hot you went WAY too far. You can always try more heat, but if you fry the part, you are done until your new part comes.
Sep 14, 2011 | Rowenta DG-980 Iron
How to disassemble a Rowenta DE-871
First remove screw the on the back of the iron. Next pull out on the fill tub on the front of the iron. Pliers might be needed. Another screw will seen at this time. Remove this screw and the sole plate will separate from the top portion of the DE 871.
Oct 02, 2010 | Rowenta Professional DE871 Iron
A PIECE BROKE OFF OFF THE MAIN BODY WERE THE
Try filling the hole with some fibreglass resin ( the stuff that motor car shops sel for fixing car bodies). This would provide a quick setting, hard filler.
Dec 14, 2009 | Rowenta Commercial Garment Steamer - White
My grandson knocked my Rowena Iron model DE-87.1b
go to the store get a 2 part epoxy glue follow the directions and mix the glue put it on both the knob and the part the knob goes on wait untill the glue gets tacky then put the knob back on wait 24 hrs. before you use the iron so that the glue can set
Apr 24, 2009 | Rowenta Irons
Rowenta problem
mY de 87.1C WAS WORKING AN ABOUT TWENTY MINUTES OF IRONING, THE CORD & PLUG IN BLEW & IT QUIT.
Dec 26, 2008 | Rowenta Professional DE871 Iron
My Rowenta Garment Steamer will not steam up.
Ok. This thing is caused by scaling. If the steam generator runs out of water the sensor thinks the tank is empty and causes the machine to go to standby (basically switch off -- orange light comes on). The solution: Open the machine and clean it.
MAKE SURE THE POWER CABLE IS UNPLUGGED BEFORE ATTEMPTING TO DO THE FOLLOWING:
1. There are six screws ( phillips - you will need a long screwdriver). Two of them are hidden under the wheels (just pop off the rollers and you will see the screws)
2. Open the steam generator (there are four screws) and be very careful with the 'O' ring -- you damage it and you can say good bye to the machine. Clean it if you see scaling. The amount of scaling present would indicate how hard your water was. This itself may not be cause of the problem but now that you openend the machine, you might as well as clean it for better efficiency.
3. Disconnect the hose to the steam generator (it has two circlips) and clean it. Mine had hard deposit of scales preventing the water reaching the steam generator.
Re assemble it.
Good Luck
Alex0714
Dec 23, 2008 | Rowenta Commercial Garment Steamer - White
Rowenta DE851 Iron Logo
168 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
