Question about Makita 108v Compact Lithiumion Drill Driver Kit
My daughter inserted a phillips screw bit into my impact drill. The screw bit is the short kind that you have to insert into an extension first but my daughter just inserted the head without the extension. So now, there is only a small part of the screw bit sticking out and I can't get a good grip to pull it out. How can I pull it out?
  • 43,501 Answers
A very strong magnet or a needle nose pliers...
heatman101
Posted on Aug 31, 2010
The Drill came with a phillips/screwdriver bit. I don't know how to insert it. I don't know what drill bits to buy and how to insert them either. My model doesn't have a chuck key or side handle.
Most new cordless drills don't have a key. Put the drill in reverse and hold tight to the chuck barrel, pull trigger and the chuck will open. Opposite to close/tighten Best I can do with info provided
Apr 15, 2015 | Drills
How to insert bit for Black and Decker 3/8 Variable Speed Reversing Drill.
Most new cordless drills don't have a key(keyless chuck). Put the drill in reverse and hold tight to the chuck barrel, pull trigger and the chuck will open. Opposite to close/tighten Best I can do with info provided
Apr 15, 2015 | Speed Drills
How do you insert a drill bit?
Grasp the ring at the nose of the drill. It has knurling around it. Pull it forwards and insert an impact rated driver bit or hex shank drillbit. Let the bit slide into the recess until it bottoms out. Release the knurled ring. You should hear the little keeper bearings spring back into place. Your toolbit should now be captive so you can go to work.
Apr 28, 2014 | Ryobi Impact Driver Kit: 18-Volt ONE...
How do you Insert a Ryobi One+ impact driver drill bit?
don't think there is much to it. See page 4 in this manual
http://www.ryobi.com.au/Ryobi/files/e0/e029b72d-32ec-4e92-a555-2a3caac4fa92.pdf
Pull the chuck out to unlock it and push the drill bit and chut back in to lock it.
Hope this helps.
Replace shower door
Hi
You did not mention any additional information about your problem except replacing shower door.However use basic hand tools to complete the job.
Try this following general steps :-
1. Remove the doors by lifting up on one door at a time and then pulling each out. The top of the door has rollers attached to it, and the rollers rest on the inside of the top rail of the frame. Set the doors aside.
2. With your drill, remove the two screws on each end of the top rail, located on the inside of the shower frame. Then lift off the top rail of the shower frame.
3. Use your box knife to cut the caulk on the side and bottom rails of the shower frame. Shower frames are caulked on the outside where they meet with the walls and floor of the shower.
4. Use your drill to remove the screws from the side rails. There will be two screws on each rail, securing it to the shower stall. Then, take the rails out. Remove the screws from the bottom rail and take it out.
5. Use your tape measure to measure the old side rails, top rail and bottom rail. With a pencil, mark the lengths on each new rail. Use your hacksaw to cut each rail. Hold a side rail in the exact location where the old rail was located. With your pencil, mark the screw holes on the shower wall. The new shower frame screw holes may not line up with the old shower frame screw holes. Use your drill and 3/16-inch drill bit to drill new holes if necessary. If the shower walls are ceramic, use the concrete drill bit. If the shower walls are fiberglass, use the multipurpose 3/16-inch drill bit.
6. Insert the 3/16-inch anchors into the holes that you drilled. Put the side rail into position and insert the screws into the holes. Use your drill and Phillips head drill bit to tighten the screws. Place the bottom rail into position and mark the holes. Drill new holes if necessary and install the anchors. Insert only one screw at the end where you installed the first side rail. Lift up the loose end of the bottom rail and slide the second side rail into place. Mark the holes. Remove the side rail and drill the new holes using the 3/16-inch drill bit. Insert the anchors and put the side rail back into place. Insert the screws and tighten with your drill using the Phillips head drill bit.
7. Set the top rail directly onto the side rails. In each end of the top rail, insert the two self-drilling screws until the top is secured to the sides. Insert the tube of clear caulk into the caulking gun. Cut the end off of the tube with your box knife. Caulk the side rails and the bottom rail to the shower walls on the outside of the shower. Re-hang the shower doors by lifting each door and placing the rollers on the inside of the top rail.
Also giving you some links from where you can find a detailed information regarding replacing shower doors.
http://www.diynetwork.com/how-to/how-to-replace-a-shower-door/index.html
http://www.thisoldhouse.com/toh/how-to/intro/0,,214441,00.html
Thanks for contacting fixya.com
Please do get back to us for further query.
Jan 20, 2012 | Home
I have the aeg phe 19rl impact drill. I bought it at a garage sale, but now I realize I don't know how to insert the drill bits and make them secure. They have notches along the side at the base of...
both answers are wrong above.With the chuck end facing you make sure the chuck is shifted to the counterclockwise position. You can now insert the bit by lining up the slots on the end of the chuck with the hollowed out area of the bit shaft, not the grooves in the bit shaft. Now when you have the bit inserted, shift the chuck to clockwise to lock in the bit.
Jun 30, 2011 | Garden
Have never used a hand dill, how do i change the drill bit. i need to drill a small hole. thank you anne
Typically, the end of the drill where the bit is inserted (called the 'chuck') rotates to loosen or tighten the arms holding the bit in place. Grasp the top of the drill with one hand and rotate the end the bit is inserted into counter-clockwise if the bit end is pointed towards you to loosen the arms and release the bit.
If it is an older drill it may have a 'key' that would look similar to end of a phillips screwdriver on a tee that can be inserted into where the chuck and the rest of the drill assembly meet and twisted to loosen the bit.
If neither of these work post what type of drill you are using as not all hand drills are the same. Hope this helps.
Dec 10, 2010 | Garden
Makita 6405 3/8
according to my breakdown its a drill. do you checked if there is a screw inside the chuck. if there is one remove it by turning clockwise.open the chuck fully & insert allen key 5/16 or 3/8 short side to the chuck.tighten the chuck & wak the allen key with a hammer counter clockwise. do it again if required.putting back together the other way.
Jun 06, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Makita 108v Compact Lithiumion Drill Driver Kit Logo
46 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
