Question about Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402
Installed new rheem 40 gal elec water heater. model ge40m06aag. no hot y already checked breaker and am getting. 240v to the wh
    Scholar:
  • 122 Answers
Did you turn the power on BEFORE you filled it with water???
this is a pretty common mistake. you will need to check the upper element to make sure its working.
most water heaters have an upper and lower themostat. the upper thermostat is the one we need to check.
use your volt meter...
turn the power off, test with your volt meter to make sure! remove one wire from the element, not the thermostat, and check resistance on the element. if no resistance, you burned the element, and will need to replace it.
replace with same wattage, usually 4500watts. it will be written on the element.
also, I like to push the reset button on the thermostat to make sure it wasn't tripped.
Posted on Aug 31, 2010
I purchased a GE 40gallon water heater model: GE40M06AAG. What type of circuit breaker do I need and it says that its a 240/208 volts AC only. Can I use it and what do I need if I can use it?
You need a 2pole 30 amp breaker that will fit what ever style breaker panel you have....then you will need to run 10/2WG wire from the breaker to the hot water heater...
heatman101
Aug 28, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
My rheem hot water heater wont stay lit and its brand new.
The top thermostat is kicking out and it may me a short or bad part.
New can be bad also.
I would take it back and get another unit.
Now if you wired it check your wiring and the breaker for proper voltage and amperage , wire size and so on.
Feb 04, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
No hot water
You posted under Rheem 40 gallon electric water heater, which is two-element 240Volt heater.
If this is not your heater, add a comment.
If you suddenly have no hot water, that narrows the suspect list.
Step1:
Check for tripped circuit breaker.
Open top cover on water heater and push in reset button on upper thermostat.
If reset button is tripped out, and will not push back in, then replace upper thermostat.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Put ear against tank and listen for bubbly-fizzing sound that says heater is ON.
If reset is not tripped, then move to step 2
Step 2: use tester or multi-meter and test across top two screws on upper thermostat for 240Volt.
If heater is not getting 240V, then test circuit breaker.
Move water heater wires from 240V breaker to another same-amp 240V breaker and see if that restores power.
You may need to replace breaker:
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
If problem persists, then you might have a line problem between breaker and water heater.
Open cover on top of heater, and check connections on top of heater.
Step 3:
If heater is getting 240V, then upper thermostat or upper element is bad.
I suggest 30 minute troubleshooting which could save you a service call, and will be valuable information in the future:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 08, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
My water is not heating in my Rheem 40 gallon electric. I pushed the reset button, but when I turn off the breaker and then on again, I do not hear the elements heating up.
Electric water heater can be repaired by homeowner
If I understand correctly, water heater is producing no hot water.
Reset button clicks in, but still no heat.
Three initial things can be causing this:
1) No power to water heater. Test across top two screws on upper thermostat for 240V. Red and black wire are attached to these screws. Screws are marked 1 and 3. Upper thermostat is same that has reset button. If power tests 120 across screws, then breaker may be off on one leg. If no power, then start testing at breaker.
2) Upper thermostat is bad. Replace thermostat with generic upper thermostat available at hardware store.
3) Upper element is bad. Test and replace element using Rheem 4500 watt element available at hardware store. Image shown below. Look at label on side of tank for element wattage. Rheem puts 4500 watt elements into all their 240V electric water heaters.
http://waterheatertimer.org/How-to-test-water-heater-element.html
If upper element is burned out the tank will not heat any water.
http://waterheatertimer.org/How-it-works.html
Rheem 4500Watt element
Upper thermostats are generic and interchangeable:
Nov 23, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Brand new no hot water
Turn off the power check all your connections. Check for a tripped breaker. If can use a volt meter check for power and check continuity of your elements.
Oct 07, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Not getting the amount of hot water I used to get
Remove power from WH Remove heating element covers and, insullation you will see two screws and, a red button (reset) for each element; push the button for each element to reset them; put everything back repower and, test. If the problem is still there: Remove power, test element screws with a meter set for resistance; if no continuity drain WH and, replace element(s)
Apr 25, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
No hot water
If you checked the reset, then the next thing to check would be the breaker in your breaker box. If that doesnt work start checking the elements. The reset, the thermostat and the elements are pretty much all that can go wrong with an electric water heater, short of a leaky tank or faulty t&p valve. Hope this helps.
Sep 24, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
No hot water
You need to check that you still have 220 volts to element. Take reading . Sounds like you may need to change breaker out for new at breaker panel, look for 30-40-or 50 amp suggest qualified electrician only or you could have deathly results. Please Rate. Thanks
Mar 25, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402 Logo
352 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
