Question about Remington 16" Electric Chain Saw
I have the 16" M30016AW Remington chainsaw. I am unable to adjust the chain tension properly. When I manually rotate the chain, at certain locations, the chain becomes very tight. If I continue to manually rotate the chain, the chain can come very loose. Is there something I am not doing correctly?
  • dontbother10
    dontbother10 Sep 01, 2010
    Have you replaced the chain or the bar? A chain of an incorrect pitch acts like this. There may also be burrs on the drive links (the part that fits in the bar groove).
5 Suggested Answers
firesnake09
  • 2923 Answers
SOURCE: Owners Manual for a Remington 2.5 HP 16 '' Chain saw, Model EL-7
Kindly check this link for manual. Please select the correct model:
http://lawnandgarden.owneriq.net/manuals/mfg/remington/remington_chainsaw_product_list.html
Posted on Apr 18, 2009
dontbother10
  • 2220 Answers
SOURCE: Cannot find replacement chain for Remington
This is an Oregon number if your bar is 16" pn 91VG058G, but kbsmiles is correct, Try a local saw seller first. Just take your existing chain for them to use as a pattern. HTH
Lou
Posted on Oct 09, 2009
dontbother10
  • 2220 Answers
SOURCE: Lost manual, need to know what size file to
Your OM, pages 15 and 16. Top of 16 says 5/32s round file.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/113005-01D/113005-01D_OM.pdf
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Apr 05, 2010
SOURCE: MY tension screw nut that
The nut may be cracked, like mine is. While I am trying to get a new one, I found I can still tighten the blade by laying the saw with the blade securing nuts up. Loosen the two nuts 1/2 turn. There is a small hole in the bar right near the case. Use a small screw driver placed in the hole and pry against the case to force the bar out and tighten the chain. While prying out on the bar, tighten the two nuts.
Posted on Oct 02, 2010
MY tension screw nut that locks the chain bar keeps bending on my Remington m30016aw. Any alternatives for that nut?
Sep 15, 2010 | Remington 16" Electric Chain Saw
I can't find a replacement saw blade for my remington M30016aw saw
Are you aware RemingtonPower is no longer in production (name purchased by MTD)? I am not certain whether you need a bar or chain so I provide both. I ask you retrace my steps to verify the part numbers I supply.
A link to an OM for your saw follows:
http://www.desatech.com/manuals/Chainsaws/model_m30016aw_manual_113005-01g.pdf
A parts listing is near the end of the manual. Items 2 (bar, pn EL16SB if 16" $22.99) and 3 (chain, 16SC if 16" $17.99) apply.
Both are available here:
PartsFor.com (authorized parts supplier)
http://www.partsfor.com/
Please use the phone and a credit card to protect yourself should problems arise; get the name of your service rep.
Please count the drive links (the part that fits in the bar groove) and verify there are 58 (16" chain).
You can likely take your existing chain to a local chainsaw seller/mechanic where it can be duplicated cheaper in about 5 minutes.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Sep 06, 2010 | Remington Electric Chain Saw
Lost manual, need to know what size file to sharpen chain for Remington M30016AW chainsaw.
Lou
Apr 05, 2010 | Remington 16" Electric Chain Saw Assembled...
Unable to find place to buy chain adjuster.
Lou
I have a Remington 16" (107625-01)
The nib broke off of the block adjustment and it was bent anyway.
Where did you find item 26 and 27 above?
Thanks Daryl
Jan 29, 2010 | Remington Electric Chain Saw
Cannot find replacement chain for Remington Electric Chain Saw M30016AW
Lou
Oct 09, 2009 | Remington Electric Chain Saw
How do you adjust chain tension? I have the 16" Remington electric chain saw, and the chain will not stay tight; it slips off the rear sprocket as soon as I try to use it. I don't feel everything is...
Here is a link to instructions for EL-8 series saws ... http://www.desatech.com/pdf/115499-01_EL8_Series_Chain_Saw_Tension_Adjustment.pdf. For series LNT-2, LNT-3,EL-1, and EL-7 according to the manufacturer... "WARNING: The cutting edges on the chain are sharp. Protective gloves should be used when touching the chain. Unplug the chain saw from the power supply. Allow chain to cool. Loosen the guide bar nuts until they are finger tight. Ensure the adjusting block is in the adjustment hole in the guide bar. Turn the chain tensioning screw clockwise to increase tension. Turn the chain tensioning screw counterclockwise to decrease tension. Check for proper chain adjustment by pulling down on the chain at the bottom center of the guide bar. You should see no more than a ⅛ inch gap between the chain cutting links and the guide bar. The guide (or drive) links should not come out of the guide bar grooves. The chain should rotate freely around the guide bar. If it does not, chain tension should be decreased. When the chain is properly adjusted, tighten the guide bar nuts securely." On the M series if your chain keeps slipping off your sprocket... The Sprocket cover tab (located on the round part of the sprocket cover) isn’t inserted into the saw body tab slot. I hope this helps you!
Jul 01, 2009 | Remington 16" Electric Chain Saw
Oil
While Bar Chain oil will probably work, the owners manual (sitting in front of me) on page 9 says to "use SAE #30 motor oil". This is the owners manual for Models: M12510US, M15012US, M15014US, M15014AS, M30016US, M30016AS, M30016AW, M35016UW, M35016AW. Remington Electric Chain Saw
May 25, 2009 | Remington Electric Chain Saw
How do I attach the saw to the pole for a Remington M30016AW?
Remington did not make a pole for this saw and any pole that are out there cannot support the size and weight of the 16" chain saw you have.
Apr 24, 2009 | Remington Polesaw Wizard
Apr 18, 2009 | Remington Garden
What type of oil do I use for a Remington Electric Pole Saw?
Mar 13, 2009 | Remington 16" Electric Chain Saw
Remington 16" Electric Chain Saw Logo
212 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
