Question about Refrigerators
I shut the door on my Frigidaire frig and it pops open again eventually it will stay shut but it is not a very tight seal
This may not be the complete fix (did it work correctly before?) - but I would make sure the frig is level side to side and front to back. I've swapped the swing on ours and had to re-level it for the door to work properly.
Posted on Aug 31, 2010
My freezer door used to **** shut now it easily pops open
What you are talking about sounds like the magnets in the door seal are weak.
Mar 10, 2014 | Frigidaire Freezers
When I close my side x side frig the freezer door pops open
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Oct 17, 2012 | Kenmore Side by Side Refrigerator
Seal around door is not tight. there are no breaks in the seal but the door doesn't seal properly. you have to make sure that you close the door tightly and when you close the freezer door it causes the...
Is this unit new? Is it new to you? Has this problem just developed? I need the history to help you. If it is new, you have a year warranty. All units built today are as air tight as possible. When one door is opened and closed. The other door can pop open. To alleviate this issue the unit's front levelers must be adjusted to tilt the unit back slightly. The door or doors might still pop open but will close by themselves. If I can help you futher, let me know.
Mar 30, 2011 | Whirlpool 17.6 Cu. Ft. Top-Mount...
Freezer door stays ajar after closing the refrigerator door.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Oct 16, 2009 | GE GTS22KBP Top Freezer Refrigerator
Frigidaire FRT17G4BW9 doors not staying closed
Adjust the front legs of your refrigerator slightly to raise the refrigerator. and and store items on the freezer door shelves to add weight. This is a problem of pneumatics and a testament to how tight newer refrigerators are. When you close the large refrigerator door it compresses the air in the refrigerator compartment. Both compartments are connected by air passages and thus the pressure change is transferred to the freezer causing the freezer door to pop open.
Raising the front of the refrigerator a tiny bit will help both doors close from the 90 degree point, which is desirable. Adding weight to the shelf will just help the process.
An additional aid in self-closure will be to use vegetable oil on a paper towel to wipe down the hinge side face of both door seals. All these maneuvers should aid in causing the door to stay closed and re-close if it should open slightly. Good Luck
Aug 23, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Freezer door pops open
there's nothing wrong w/your dr seal. add a then layer of silcone or vaseline to the seal. this will make it sticky again.
Jul 14, 2009 | Refrigerators
Freezer door won't stay shut
This indicates that you do not have good airflow and return airflow between your freezer and refrigerator sections. That is why the pressure from closing one door is causing the other one to pop open.
Check the drain tube on the back of the machine to make sure it is not clogged or blocked with frozen water inside. Also check any return air flow vents inside the unit for clear ice.
Jan 18, 2009 | Refrigerators
INTERIOR FRIG LIGHT
replace the switch before the seal, nothing wrong with gasket., you may need to raise the refrig door a bit by , remove the door and install a small spacer to raise the door slightly for better contact
Oct 22, 2008 | Frigidaire FRT21H8 Top Freezer...
I have the exact same problem - very annoying. The only thing I found to work was to purchase one of those child safety locks. I bought the Kidco Appliance Fridge Lock S330 because it was the only one I could find that automatically relocks after you shut the door. Buy two (or more) at a time because the arm will eventually wear out and break (after several months depending on how often you use it). You can check out the product's details on eBay - that's where I purchased mine. Hope that helps.
Aug 27, 2008 | GE GTS22KBP Top Freezer Refrigerator
Could be the air pressure created from shutting the refer door is popping open the other one. There are are channels between the two so cool air from the freezer gets to the refer compartment. Try this as a test... s l o w l y close the refer door and see if that keeps the other door from popping open. If that works then it's likely an air channel is frozen up somewhere and you may need to turn the unit off for a day or so to let it thaw out. Moisture from leaking door seals, or doors that were left slightly open overnight can be sucked in and freeze up the air channels. I don't know if you are sort of slamming the door shut or not but the doors need to be shut slowly due to how air tight the new refers are.
Nov 10, 2006 | Frigidaire FRU17G4JW Refrigerator
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
