Question about Microwave Ovens
My microwave was working fine on Sunday 100% power, on Monday light & fan work, tray rotates but will NOT HEAT at all? The unit is exactly 4 years old this year, what could the issue be? The microwave we replaced was 16 years old & still worked. Any help would be greatly appreciated. Model is SMH7174WC
  • 3 more comments
  • G.k. Mahendran May 09, 2008
    Now a days hot summer, due to voltage problem may not to be heating, try to put stabilizer and try again.
    G.K.Mahendran
    Date: 09.05.2008
    ph: 97910 55855
  • bqb17 May 09, 2008
    THere is no addition noise, it sounds like normal just NO heat. I called Samsung, & they cannot help without the serial #, which is located on the back of the unit, which is mounted on the wall, r u kidding me? The magnetron is warranteed for 10 yrs, but does that include labor? They will not even send someone out without the #. Any advise? Is it worth it? It's only 4 yrs. old.
  • Anonymous May 09, 2008
    My microwave was working fine at 3:00 p m. then at 5:00 p m I was going to use it, and the start button would not work when I touched it. My microwave is a Kenmore
    Thanks,
    Doris
    The time was on May 8th, 2008
  • nepatobins Dec 01, 2008
    My Samsung SMH7174WC failed with same symptoms after spouse boiled down an entire glass of water by mistake. Everything appears to be normal, but not heating.
  • William Miller
    William Miller May 11, 2010
    Since the fan, light and try work, it's most likely a failed part or bad connection in the high voltage section, such as at the magnetron terminals.
    Is the noise it makes when it's supposed either quieter or louder than when it was working?
  • Microwave Ovens Master
  • 9,086 Answers
To bqb17:
Samsung will only cover the cost of the magnetron (if that's the trouble) but they will require you to pay the service call labor (maybe $75) and on-site repair labor (maybe $50-90).
You can save a little by removing it from the wall yourself and taking it to the servicer. They would likely charge a bench fee of about $25 to check it out.
Are you sure the serial # is not located on a tag around the door frame or inside?
We're happy to help and we appreciate your thoughtful rating of our answer.
To guest:
Your oven's failure to start isn't the same problem bqb17 is having. His starts, it won't heat. So it would have been better to post a new thread.
But even so, I would suspect you have a bad door switch or door switch mount. Forget any talk about a "voltage stabilizer".
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on May 09, 2008
Kitchenaid Superba KEMS307D Microwave buzzes, looks like it works, but doesn't heat. Full normal display, tray rotates, but fan doesn't sound normal.
Most likely causes - shorted high voltage rectifier, or failed high voltage transformer, or shorted high voltage capacitor, or shorted magnetron. If an odor accompanied the failure, high voltage rectifier or transformer most likely. All of these components operate on 4000 v, or more - with enough current to kill you. Make sure the unit is unplugged, and the high voltage capacitor is fully discharged before testing.
Apr 10, 2014 | KitchenAid Microwave Ovens
GE Spacemaker XL1800 Microwave
see for the turn table obstacle of any screw or something else.
Aug 04, 2008 | Samsung MW1030WA Microwave Oven
Water damage to microwave
There is a small sensor in the micro wave that controls the heat. You probably got water on the connections and shorted it out.
May 01, 2013 | GE Microwave Ovens
I have a JVM1850 that was installed 4 years ago. The unit was working fine, then a day ago I received an error display requesting a charcoal filet replacement. No filter is needed since it is vented...
I have a JVM1850 White microwave-over the oven-installed 3 years ago. Last evening the unit would not turn off. The inside light and fan continued to run, however, the microwave was not working.
All the controls and functions seem to operate, but when completed, the unit remained working, as stated above, with the door opened or closed.
Sep 18, 2011 | GE JVM1850 1000 Watts Microwave Oven
Yesterday the microwave was working fine, this morning nothing at all...No power at all. I have checked the circuit breaker and everything is fine. The oven below it is on the same breaker and it works...
it sounds like the internal fuse has blown. if your handy, it can be done , however,,MAKE SURETO
DISCONNECT THE POWER SOURCE BEFORE BEGINNING. if your not 100% comfortable
have a trained technition service the unit...
Nov 20, 2010 | Whirlpool GH7208XR Convection / Microwave...
Microwave doesnt heat, power is on fan is working
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
klgjlgk
Jul 06, 2010 | GE JVM1540SMSS Microwave Oven
Do not heat any longer, lights, clock and fan work
In situtions such as these it can be considered that the Magnatron has passed on. Co0t of repair often exceeds the value of replacement.
No fuse controls the magnatron separately from the rest of the unit so deem it dead
With the availability of good second hand models on the market via pawn shops like Cash Converters etc one can find a very good unit with 30 day warranty for $50-100 and its already been checked over for defects
Please rate my help++++Thanks for using FIXYA
May 08, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Viking 1100 watt Microwave will not heat food
heatman101
fjj
Jan 05, 2010 | Viking VMOC205SS Microwave Oven
I have a GE Spacemaker II microwave: JEM25GY that died. It seems less expensive to replace rather than fix. Power works; it doesn't heat. New models all apparently have turntables; mine didn't and I...
YOU CAN TRY REMOVING THE GLASS TRAY AND TURNTABLE AND REPLACING IT WITH YOUR OLD GLASS TRAY (IF YOU HAD ONE) OR JUST ANY GLASS MICROWAVE TRAY. WITHOUT THE TURNTABLE, I CAN'T SEE HOW IT CAN ROTATE.
Nov 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have an overhead microwave oven/exhaust fan combo unit. Everything works but the microwave won't heat anything. It worked Sunday but not yesterday.
thats a tipical microwave problem they just pop off like a light bulb, it could be turminal or it could be a fuse, what ever it is dont try to fix it yourself there are over 1000 volts kicking about inside the thing and 1000 volts will kill you out right, call a guy in to fix it, look at it this way,, whats your life worth in £???
Oct 20, 2009 | Microwave Ovens
Microwave Ovens Logo
163 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
