Question about Bosch Axxis WFL 2060 Front Load Washer
Hello Expert Fixya Person. My machine fills with water when I start the wash then does nothing. I end up emptying the water from the tube at the lower right hand bottom of the machine. If I don't empty the water. The machine will do nothing. When I empty the water. It fills and stops at filling and does nothing. Thanks for your help. Greatly appreciated. Ronnie in New York.
    Scholar:
  • 91 Answers
Hi dear.Your machine's motor brushes,that needs to be change.If you are not handy call service department.If you are,you need to get acces the motor.There are two carbon brushes back of the motor on one of each side.By the time they get worn off & lost the contact on motor "rotor"Take them off & replace with the new ones.Also check the harness.I hope that helps.Thanks.
Posted on Aug 31, 2010
Crosley washer model caw9244xq2. Started normally, ended on spin, now it's full of water and won't start. I have to hold the start button for it to turn on, then nothing. Help?!
there is a micro switch in the knob of the machine that not telling the washer machine to empty the water, you need to call a repair person, or buy the part your self and buy a manual and do it yourself.
or
www.youtube.com/how to replace wash machine control knob
www.infolinks.com/replace defective washer machine knob
www.ask.com/how to replace washing machine control knob
Apr 21, 2015 | Crosley Washing Machines
Washing cycle not working. Machine can be made to spin and empty but get to wash cycle and it shows washing/cleaning but does not move. Will fill and empty though.
No agitation?
first use a meter and check ur water pressure switch? that is what sends the machine the message to start wash cycle? You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube. If the machine starts to wash. the pressure switch is more than likely good. now take the original hose tube and plug one end and blow into it the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ?
sometimes they get busted open or a pin hole and release air causing the water switch diaphram to not open.
If both check ok then next CHECK the motor coupler or belt if belt driven.check with a multi meter for continuity the door switch, and if there is a little movement on wash cycle in 1 direction only then check the cam dogs in agitator.
Mar 28, 2015 | Electrolux EWFLW65H 4.7 Cu. Ft. Washer
The cold water continues to fill the tub and not shut off
There is a pressure switch fitted to all washing machines.basically a tube outside the drum that has air inside it which responds to water going into the drum.as the air in the tube compresses it activates the switch to shut off the water and sends a new command to controller board to turn the drum and start washing.when it doesn't switch off tells me that the tube has too much water in it and won't shut off supply.you can locate the tube and empty it so it just has air in it reconnect and see if that fixes it.if it doesn't then next place to look is the switch itself and controller board.
Dec 23, 2014 | Washing Machines
Skips "soak/prewash" function and moves from "add garment" to "wash" function. never fills with water. all hoses connected and water turned all the way on.
It sounds to me like the fill level switch is stuck, so it thinks the tub already has enough water. Since water pressure and flow vary at different installations, fill is controlled by a level sensor switch, not a timer. Typically there's a tube with one end connected to a fairly low point on the outer tub. The other end is connected to a diaphragm switch in the control panel. As water fills in the tub and tube, it forces the air in the tube into the switch, causing it to indicate a full state. If the switch is stuck in that full state, you would get the symptom you describe.
Find the parts drawings from one of the many internet parts suppliers to see where the switch and fill tube are. Take the tubing off at the top end and blow through it, in case the bottom end is clogged with lint. Then use that tubing or another piece to blow lightly into the switch, You should be able to hear it click and clack as it switches from low to full states and back.
If you know how, use an ohmmeter to check that the switch is actually changing states. Usually these switches have three terminals, Common, NO (Normally Open), and NC (Normally Closed).
--When you don't blow, there should be conduction ONLY between Common and NC. (This is the empty state which must reached before Spin will start.)
--When you are blowing, there should be conduction ONLY between Common and NO. (This is the full state which must be reached before Wash starts.)
Nov 25, 2014 | Washing Machines
How do i drain the washer for moving it
Mike,
I cannot tell whether you are talking about (1) the little bit of residual water in the machine after it's done, or (2) about a machine that's stopped mid-cycle with a good deal of water, so I'll respond to both cases.
(1) The lowest point in the washing machine is the drain outlet at the back to which the drain hose attaches. First remove the free end of the drain hose from the drain pipe and place it in a bucket sitting on the floor. That will get most of the water. Then place a towel on the floor and remove the other end of the drain hose from the machine. Remaining water will spill out from the outlet and hose onto the towel. You might get a little more if you lift the front of the machine, tilting it backward.
(2) If you can't drain the machine and it's full of water, you will need to siphon it. Take a piece of tubing, at least five feet long. You could use a piece of garden hose if you have nothing else. If you don't have a door or window nearby, you will need TWO buckets. Place the buckets on the floor in front of the machine. Place the siphon hose into the washer tub starting with one end to fill it with water. When it's completely in, cover one end, take it out, place it into a bucket. If the siphon doesn't automatically start, get down low on the floor, place the hose into your mouth and inhale. You may have to do this several times, possibly covering the tubing end with your tongue between inhalations. When the bucket is nearly full, switch the hose to the empty bucket and empty the first one. You will probably have several buckets of water. (Of course if your washing machine is near an outside door, you can simply start the siphon outside and omit the buckets.)
Oct 02, 2014 | Washing Machines
Clothes washer will fill with water but will go into wash cycle
The heater or the pressure switch are faulty. Cannot tell you more without knowing the make or model number. You can empty the washer by pulling the drain tube out from behind the drain filter flap located at front bottom. Get a bucket and empty the drain tube into the bucket by removing the hole plug at the end of the drain tube.
Sep 20, 2014 | Washing Machines
When switching on the washing machine the water doesnt enter. it gives an 1E error as well
HELLO THERE AND THANK YOU FOR CHOOSING FIXYA
E1 : washing machine has exceeded a check time for fill, heat or empty.
Common causes for this are fill and empty problems, heater fault (or the wiring
to it broken), water pump open circuit (although that would stop the water draining too) Pressure chamber blocked or pressure tubing pipe looped below the pressure bottle, or a sticking eco ball in the sump hose (sludge and grease build up) I WOULD FIRST CHECK THE PUMP AND SEE IF IT IS CLOGGED AND IF THE FILTER IS CLOGGED THEN CHECK OUT THE PRESSURE LINES THEY ARE LOCATED UNDERNEATH THE MACHINE AND BEHIND THE BACK PANEL
kEEP ME POSTED ON HOW THIS IS GOING OK SO I CAMN CONTINUE TO HELP YOU ON THIS UNTILL IT IS SOLVED
bEST REGARDS MIKE
Mar 04, 2011 | Samsung Washing Machines
F&P washing machine:GW709 doesn't cut out when filling
could b pressure switch tube is blocked or your control board with the pressure switch attached is faulty. empty water from machine, remove pressure switch hose from control board, blow thru tube to remove any blockages, refit tube. turn on cycle, select low water level, push start, after about 30sec"s push start again, that should stop it filling straight away. if the water stops push start again to continue filling. if it doesnt stop filling after restarting the cycle then it is your control module.if the water doesnt stop filling after the 30 sec stop it is the water valves. by the way what country do u live in because $120 seems to b alittle too expensive. please reply 4 more help.
Apr 29, 2010 | Fisher and Paykel Fisher & Paykel Washer
My LG Washer 0642h doesn't always dispense the bleach. I notice that the dispenser fills up with water and doesn't empty. I have to empty it in the next wash. The dispenser doesn't appear to be clogged.
If the dispenser comes with a siphon tube, it is always this tube that is clogged. When the dispenser receives water from the machine, it fills up, the water/softener mix starts to go through the tube, at first by just draining because it has sufficient head, and then as the dispenser gets lower, siphon action in the tube takes place. . This tube must be clear for this dispenser to work.
Nov 25, 2009 | LG Washing Machines
Aquarius wf541 model
The sypon tube needs cleaning, you need to poke it clear with something, the tube is part of the dispenser , thouroughly clean every part.
Sep 06, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
56 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
