Question about Maytag Microwave Ovens
I ran my micro mistaking without anything in it, it just shut down and is now just blank, anything i can to reset it or something, thanks
  • Maytag Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Aug 31, 2010
I foolishly ran my nnct585s without anything in it, can I get the nne271m?
Panasonic microwave
how long was it on ?
both look different
nnct585s 1000 w
nne271wm 800 w ... you might find a used unit ....
Jul 03, 2016 | In Microwave Ovens
Tip
Microwave shuts off to soon?? REPAIRING/FIXING MICROWAVE OVEN FAN
I had picked up a very nice stainless steel covered microwave at a yard sale for 5 bucks. They had told me it worked fine but they neglected to tell me it only worked fine for 4 minutes and then it would shut its self down and then you had to wait 3 minutes for the reset to take effect and then you had another 4 minutes of cooking.
Let me tell you this got old in a hurry. I looked on the internet for expertise advice by stating my case in the google search bar. There were 20 different relays and fix this and fix and replace thats on there.
I decided to just take the back cover off and have a look for my self.
once I was inside i was touching this and poking that and noticed it was really dusty inside with plenty of left over spider homes so i used my computer air can spray and clean it all out.
I thought maybe it just might have been the problem as bad as it was in there so I plugged it in with the back still off and it shut down in 4 minutes just like before.
Something was wrong and I couldn't quit place it so I tried it again after the relay clicked back on. Then I saw it. The cooling fan was not turning.
I unplugged it and tried to turn it by hand after squirting some WD 40 on it and the plastic blade would turn but not the shaft the blade was attached to. So I got a pair of pliers and worked the shaft until it broke free. Squirted a little more oil on it and it became nice and smoooooth oh boy!!!
I then plugged it back in and set the timer to 5 minutes. By the way never touch anything inside one of these while it is plugged in.
The microwave approached the 4 minute mark and I stood there with my fingers crossed watching the fan run as smoooooth as can be.
Wallah!! it passed the 4 minute shut off mark and made it to the 5 minute mark until it quit because the timer ran out.
I did this again at 10 minutes and it made it all the way through without shutting down.
I now have a great working $5.00 microwave and it didn't cost me anything more but a little time and couple squirts of oil.
So if you experience the same early shut down time then now you can maybe good lucky like me and repair it your self by a flick of the fan blade.
I hope this will help you same some money. The Raz Shack
on Apr 22, 2010 | Microwave Ovens
Ran the microwave empty...it shut down. Is there a reset button
You could have burned something out on unit. Check fuse or contact GE. Look in manual for trouble shooting tips.
Jun 13, 2016 | GE Spacemaker JVM1640SJ Microwave Oven
Strange one here, The turntable in my Microwave wont turn off, even after timer runs out and micro shuts down when you open the door the turntable just sits there and spins without a care in the world
Power to the turntable motor is supplied by a relay mounted on the main control board ( the part behind the control panel). Sounds like the relay contacts are stuck in the closed (on) position. You can try getting to the main board and tap the small box looking parts on the board with something like a screwdriver handle and see if you can get it to unstick. If that doesn't work---board needs replaced.
Jun 04, 2015 | In Microwave Ovens
Daughter has a two year old G.E. JVM1540DN1BB that makes the right noise but will not heat anything, Seems that the Micro part (mega something) is not powering up. Is there a circuit fuse internally or...
It does sound like the magnetron is gone, there is a thermal fuse that monitors the temperature of the magnetron, if it got to hot it would cause a shutdown taking up to 30 minutes to reset automatically.
May 01, 2012 | GE Microwave Ovens
Dacor micro/convection oven flickered then the power went out on it. Looked like it reset then I tried to micro something and it immediately shut down. :'( Its absolutely dead now. Is it a goner??. Its @...
The service manual is here and the parts list is here.
You can order Dacor parts by part number from the Pros here.
If it's a problem with the controller / display, y
ou can get that repaired for $39.95 in most cases (details here) or order a control / display unit here.
Aug 25, 2010 | Dacor DMT2420SS Microwave Oven
Micro GE Spacemaker XL1400 Sunday I was warming up soup for three minutes when ready open door and I heard a click, micro shut down I tested the power outlet with the blender and It work An hour later the...
IF YOU SMELLED BURNING TAHTS BAD, IT SOUNDS LIKE YOUR MAG TUBE WENT OUT (ITS WHAT MAKES THE MICROWAVES) iT WILL BE CHEAPER TO REPLACE IT, NEW UNIT STARTING FROM $115 FOR THE SAME MODEL
Jun 07, 2010 | GE Microwave Ovens
Microwave electrical problem
Unplug, take all the screws out from around the case. Remove case. There is a fuse inside (Without Model number I can't tell you right where it's located) It looks like one of the old round car fuses only it's white colored. It's made of ceramic. Replace it and put unit back together. This is a common problem when one does what you are saying yours is. Be thankful that's all, if you had anything working it would be something major and would be cheaper to replace unit if it a counter top model.
  • NOTE: DO NOT REPLACE WITH CAR FUSE. USE ONLY MICRO WAVE FUSE.
Please rate solution
Sep 05, 2009 | Kenmore Microwave Ovens
GE JVM1650CH01 Microwave Template
You can download GE owner's manuals and installation instructions here.
Aug 17, 2008 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
