Question about Makita Tools & Hardware - Others
My Makita 9901 belt sander is used but very slightly and now is just frustrating to even use. What is the most common cause for tensioning roller to keep pulling the sanding belt over against the housing? It will run balanced in the center for 15 seconds then jam over to the side and now has worn grooves in the housing. Of course it tears up belt edges which are not free. I am ready to toss it and buy another. Is this a bad design flaw by Makita or do all models share the same problem? Thanks Rick
  • 43,501 Answers
There is a screw that changes the angle of the roller to change the tracking of the belt... this is very sensitive and probably if you are having trouble is more a reflection of the belt quality then the sander...try different belts before you toss the sander... I have had one for years and love it... although the belt tracking is tricky sometimes anss your have to keep after it...
The adjust ment is very touchy only turn it maybe 1/8 turn at a time...
heatman101
Posted on Aug 31, 2010
I have a Makita belt sander,just replaced belt tensioner system including springs and roller but belt drive roller still keeps stopping on relatively light load even though the motor is running
very good trade tool
how quickly is it getting hot
slowing motor could be the cause
motor bushes and bearings can be replaced
did the motor drive belt under the cover get replaced
Jun 02, 2016 | Makita 9911 Compact Lightweight 3" X 18"...
How to install drive roller on my makita 9401 belt sander
DONT forget to order and replace also allways the sinter bearingbus on the machine because to protect you from a dissapointment because otherwise the belt will turns off and cant be (good) controlled again , replace the drive roller allways and clean the front roller axle if its only dirt on the front roller use a little sillicon grease film on the front behind can use a little bit more sillicon grease between the axle rings and new bearing bus. remove the dry grease in the driving gear space and renew the lubricant in it with a multipurpose grease .
Sep 04, 2014 | Makita 9404 4'' x 24'' Belt Sander
Makita 9901--How to remove and replace motor bearings
Do you have a bearing splitter? If so I have used one and then gently tapped the end of the shaft to remove the bearing. The rubber pins fit into holes next to the bearing bore in the housing. You can use a vise and a soft hammer to tap the bearings on. Put the bearing on the vise and tap the opposite end of the shaft. You are on the right track for all these methods.
Nov 13, 2009 | Makita 9901 3 inch x 21 inch Belt Sander...
How do you replace the drive belt on a Porter Cable Belt Sander
There is a lever on the side at the front right near the roller that you can use to release the spring tension on that roller (moving it slightly to the rear).  Once the tension is released you can slip the sanding belt onto both rollers from the side.  Release the lever and the spring will put tension on the belt to hold it in place.  Use the knob on the left side to center the belt on the roller if it starts to slip sideways when in use.
May 28, 2009 | Porter Cable 361 3" X 24" Sander
Belt sander-belt coming off in use.
Have you tried adjusting the tracking slightly to the opposite side to which the belt comes off this has worked for me on my Bosch
Apr 19, 2009 | Makita 3 x 24" Belt Sander
The belts on my Makita 9304 belt sander are wearing unevenly
check the wear plate on the bottom and also check the front roller for being out of round is where I would start. Let me know if doesnt help
Feb 17, 2009 | Makita 9404 4'' x 24'' Belt Sander
Slipping belt
OK the belt tensioning mechanism is spring loaded. First what is the quality of the belts are they real flimsy or stiff. You say the rollers spin but my question does the rear roller still spin and the belt remain stationary. If so the rubber belt on motor is bad. I would take a look for excessive wear on the rear roller. Does the yoke mechanism snap forward or move slowly, look for a build up of sawdust in this area that might be restricting movement on the yoke. The wear plate in still good condition. One other thing on the belts are they directional? Do they have an arrow on the inside if so that has to point toward front of tool. I looked at a breakdown and could not see anything else to suggest. I never had this problem except with belts when I was at Makita.
Jan 18, 2009 | Makita 3 x 24" Belt Sander
Looking for a manuel for a makita belt sander model #9401
There is a black metal ******** one side that is actually a lever and with the tip of a screw driver or the like, pops out and releases the front roller.
Dec 26, 2008 | Tools & Hardware - Others
Tool is cracked, is it PVC or another type of plastic
I dont know what kind of plastic these sanders are made of. Your best bet is just to try a strong 2 part epoxy. If the epoxy doesn't bond then you should be able to just scrape the glue off and try something else.
Oct 22, 2008 | Makita 9901 3 inch x 21 inch Belt Sander...
Tools & Hardware - Others Logo
349 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
