Question about Kenmore Refrigerators
What is the normal operating temp of a kenmore side by side
  • Kenmore Master
  • 43,501 Answers
0-10 on the freezer and 38-44 on the fridge...
heatman101
Posted on Aug 31, 2010
A kenmore side by side model 106 5661 2500 has warm refer and cold freezer
If the freezer temps are normal and the refrigerator is warmer than normal, the the air flow from freezer to refrigerator is being hampered either by ice on the evaporator or the freezer is stuff in such a way that normal airflow between freezer and fridge is hampered. If the auto defrost is not working properly you will have warmer freezer temps and a relatively warm refridge. Check the defrost timer and defrost heater element.
Nov 26, 2013 | Kenmore 56612 Side by Side Refrigerator
Temp display reads 92 (hi temp) but the interior temp is 0.
No. Sounds like the intern temp sensor is bad, missing, or not connected. 92 is probably the max reading it can display. The unit will probably operate continuously, be much to cold, and cost a ton to operate. I assume you bought this from Sears. Call them to replace the freezer. Should be no problem.
Oct 24, 2012 | Kenmore 20.6 cu. ft. Upright Freezer 2809
Reset kenmore dishwasher
The most common "reset" key sequences are:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry).
On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
Jun 15, 2012 | Kenmore 24 in. 17482 / 17484 / 17489...
I came home from work and my alarm was on. The temperature on both the refrigerator side and freezer side was going up. The food in the freezer is thawing and the refrigerator is barely cool. I thought...
Let it unplug for an hour and set temp to your preferred setting and then plug in again. This will resume to normal operation.
Be sure that electricity in your home is not fluctuating or surging as it will cause false alarm or your fridge. It can intermittently operate your fridge.
Thanks for asking
Jun 24, 2011 | Kenmore 76582 / 76584 / 76589 Side by Side...
Kenmore Side-Side Refrigerator not cooling
That is the SN on the bar code. Make sure outlet is hot, unplug the unit and turn all controls off, temp etc. Let sit for 30 minutes, plug it in, then turn unit on with temp setting control. Goood Luck
Nov 21, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer temp
No, these fluctuations are a sign of a unstable control unit. test the control unit for its operational value and , replace the thermostats as well.
May 22, 2009 | Kenmore 64722 Top Freezer Refrigerator
Kenmore side by side fridge/freezer.
The ideal temperature for the freezer is zero degrees farenheit.
Feb 06, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Side by side refrigerator model # 51562103 center wall - very hot
if fridge and freezer temps are normal, what on earth is your problem?
Nov 14, 2008 | Kenmore Refrigerators
Kenmore side by side MD 363.58261896 Not cooling
sounds like a sealed system problem. if it is, its expensive.
Oct 19, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore Chest Freezer
Believe it or not, but it is normal. Especially when just turned on. As the internal temp. gets colder so will the temp. on the side get cooler.
Apr 20, 2008 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Refrigerators Logo
27 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
