Need to know what my out door unit tonage is. it is gone from the out door unit . so i can get a new compressor
  • 455 Answers
Hello TIMMY I guess the sticker erroded off the unit because the model# is the easy way.Plan B is get all the info off the COMPRESSOR plate/sticker for correct replacement.Brand name of the compressor is needed NOT the make of the unit doing it that way.Good luck.
Posted on Aug 31, 2010
LRA how to convert in tonage so 10 LRA How many ton and 145 LRA Copland scroll compressor tonage value pleas give me answer
LRA on the data tag stands for "locked rotor amps" and has nothing to do with tonnage. In the model # there should be a number to use. And divide that # by 12 (12,000 btu/ton). So if I had a PFG24H200 it would be the "24"and a 2 ton unit
Jul 06, 2015 | Heating & Cooling
I have a luxaire condenser and its so old that model # is gone but i have the serial# efrm155233 can anyone tell me the tonage?
It is not measured in tons. measured in BTU'S British Thermal units. there is a plate on it telling all this info.
May 15, 2015 | Heating & Cooling
I have a model # 9530A601 and the frieon seems to be empty, what kind and how do I recharge it? my name is Toby
unless you are HVAC certified you will not be able to purchase freon. The type of freon and tonage are printed on the side panel of your outdoor unit. Charging an a/c system is not simple task you will need to call a technician unless you know someone in the field. Overcharging or Undercharging can do damage to your compressor rendering your unit worthless.
Jul 25, 2012 | Coleman Heating & Cooling
Hi, I have a goldStar GA 1866VHR split Airconditioner, (5050w cooling and 5040w heating capacity). Today I noticed that compressor/condenser unit was still running after I turned off the aircond: from the...
Thanks for your detailed information. But solution is very simple. The compressor contactor in out door unit. Struck. And hence, when you power on, without indoor commanding, the out door starts running.
Replace same type Contactor relay (In out door unit) immediately. Hope, it's helpful.
Jan 19, 2011 | Heating & Cooling
No problem.....only want info. on the unit....I can buy one and need the tons, etc.
should be able to read the model number right off of the compressor......(the big black dome shaped thing). That model number tells the btu/hp which translates to tonage. It also lists the electrical data such as voltage.
Oct 06, 2010 | Heating & Cooling
Light is on, temp is set to cool, but the unit is NOT cool. The unit is 10 years old.
as old as the unit is the compressor has most likley gone bad. For this size compressor the replacement should not cost that much. You can call an appliance repair shop and let them know you unit and that you need a new compressor installed they should be able to quote you a cost on replacement.
Good luck hope this helped
Dave
Feb 22, 2010 | Marvel (6SBARBSG) Wine Cooler
SIZE, TONAGE
hey there, you hace a 2 and a half ton unit there.
seth
Jul 29, 2009 | Heating & Cooling
Tonage or BTU/hour rating from Ruud name plate
See this link
http://www.epinions.com/specs/pr-GE_Zoneline_AZ55H07D_Air_Conditioner
Its say 7100 BTU/hr
Jun 05, 2009 | GE Zoneline AZ55H07D Air Conditioner
A\c unit
it cold be different problems.
1-check for any air leaks around the house.
2-check the return box and see if have any opening and seal the holes.
3-check the insulation on the attic or any motor that takes the heat out the attic.
4-check if the unit is under tonage each tonage mean a 400 sf per ton.
5-check if the air handler coil is not dirty and enought air going thru the coil.
6-check the pressure of the condenser unit if have the rigth presures.
7-check thermostat if is set-up right.
Jul 22, 2008 | Heating & Cooling
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
