Question about Electrolux FGQ332ES Dryer
Ignitor lights but does not light gas for heat.
  • Electrolux Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Aug 31, 2010
There is no ignitor so dont know how t light
Steps outlined for getting gas fireplace pilot light going
www.knoxnews.com/.../steps-outlined-for-gettin...
Knoxville News SentinelDec 29, 2008 - The steps to light the pilot on a gas fireplace may vary some between ... valve that must be turned so the flat valve is in line with the pipe to be on. ... A little trick to know if the gas is on: The gas valve has two holes that line up to ... Most modern gas logs have an igniter button which will be a little red button.
Gas Stove Ignitor and Burner Not Lighting - YouTube
? 1:10
https://www.youtube.com/watch?v=1ZXz8_Md8hI
Nov 20, 2011 - Uploaded by Mike Klimek
Here is an easy fix if you hear the ignitor "clicking" but not lighting the burner. ... We don't hear a clicking sound either. ...after purchase so no warrantee. the sponge dropped crud in thereand the back ... As soon as I release the knob it dies, is this problem then within the know and if so what do I do to fix?
Furnace Ignitor Won't Light! No Heat! HELP!!! ' DIY Forums
www.diyforums.net/furnace-ignitor-wont-light-no-heat-help-6256636.ht...
The ignitor doesn't light up and no clicking noises. ... Depending on what type of furnace you have 80 or 90% there may still be a problem. A fouled secondary on a 90%, gas pressure could be too high, and so on.. you should have a .... When you see an answer you don't know if it is for your question or one of the others.
Jan 13, 2016 | Cars & Trucks
The pilot ignitor lights up but gas doesn't light off
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 25, 2011 | Speed Queen AGS28AWF Gas Dryer
Maytag dryer mug15pdaww won't light, the ignitor
heatman101
Jun 16, 2011 | Maytag Dryers
My whirpool gas dryer model number wdg6200swq, wont heat up. the ignitor lights but no gas lights
heatman101
May 02, 2011 | Whirlpool Dryers
Dryer is not heating up it runs does the ignitor heat up before gas valve opens because the ignitor never heats up
On my gas appliances, either there is a pilot light or the ignitor sparks (like a car spark plug) or glows after the gas valve opens. The ignitor does not heat up.
I've had some gas appliances that have had the valve stick. (On an oven, we tested this by tapping on the valve when the unit should have called for gas. This confirmed that the valve was bad and not the thermostat.)
I hope this helps.
Dec 07, 2010 | Amana NDG7800AW Gas Dryer
Gas dryer burner intermittently lights. Foul gas
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 17, 2010 | Estate TGDS680EQ Dryer
Not heating up Gas Dryer
Modern gas dryers do not have a pilot light. They have an electronic ignitor (glow or spark). A glow ignitor turns on several seconds before the gas turns on and should get orange hot. A spark ignitor should make a clicking or buzzing noise.
Most likely the ignitor is bad but you can check it fairly easily to make certain. The best instructions I have found are at
http://www.acmehowto.com/howto/appliance/dryer/gdryer/check/ignitor.php
If it is the ignitor it can be replaced with a few hand tools. Remove the bad ignitor. Write down the make, model, and serial # of your dryer. Call your local appliance parts store to see if they have one it stock before driving over there.
Dec 22, 2009 | Whirlpool Dryers
Oven will not light
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
iuop
Nov 19, 2008 | Whirlpool SB160PEE Gas Single Oven
GE Spectra XL 44 Gas Oven Bottom Heating Element Faulty
First look to see if the ignitor is coming on. Most common problem is the ignitor is weak or just bad. When the power is applied to the ignitor it glows and builds up resistance to open the gas valve then it lights. If the ignitor is weak or bad it will not build up enough resistance for gas to come into the burner. One sign of this would be a "woosh" sound when it trys to light. If the ignitor is coming on but not lighting it is most likely the ignitor is bad. Should have a full glow. Also, if the ignitor looks whiteish in color this is a sign of it going bad. You can compare to the broil ignitor to be sure. If the ignitor doesn't come on at all will need to see if you have power to the ignitor. Let me know what you find and let's solve it before you rate the solution.
Nov 05, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Electrolux FGQ332ES Dryer Logo
105 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
vince
JP Services
JP Services
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
