Question about Fisher and Paykel GWL11 Top Load Washer
Wont power up - Fisher and Paykel GWL11 Top Load Washer
    Scholar:
  • 91 Answers
Hi dear.If you know what you are going to do,follow those steps,other wise call service department.(If you like,you can also contact me via icatci@hotmail.com I'm in Sydney 2144 I might help you to solve the problem) Phase 5 Only. The pump is used as part of the power supply if it is not connected Smartdrive will appear dead. Check the pump ~motor resistance is 33 ohms. If the pump is open circuit, has the thermal onnectlon cut out tripped? This should reset within 15 minutes after tripping once the pump has cooled down. If the thermal cut out has tripped, check for a blocked pump.
Check that the resistance of each of the water valves is 15 ohms 64 ohms (Phase 5).
Replace the Motor Controller, if none of the above faults are found. I hope that helps,thanks
Posted on Aug 31, 2010
My packard acer wont turn , power light comes on when pluged it , but wont power up
Packard Bell, Acer? Which manufacturer? Remove the power, remove the battery, remove hdd and RAM. Plug in the power supply and press On. It will complain that is has not any RAM etc. If it does, insert one RAM chip and try again gradually if not you have a motherboard issue.
Oct 05, 2016 | Acer Computers & Internet
My rci2980wx wont power
the diode is located near power cables and trace from power switch, the diode is quit big and something like IN4001 to 6 Re: Jeff
Dec 01, 2012 | Radio Communications
My automatic windows wont roll down
Click the link below to troubleshoot the problem:--
Power windows not operating?http://whoisbyme.blogspot.in/2012/05/car-window.html
Thanks.
Jun 07, 2012 | Spyder 03-05 Chevy Silverado Vertical...
My cda-9813 wont power on,how to take of faceplate?
sure it will the face eject button should be either on the upper or lower left corner of the face.
Mar 26, 2010 | Alpine CDA-9813 CD Player
Power windows and power locks wont work
Check your fuses first. Then check for power at the switches, and power from the switches to the respective solenoid and motor. Most likely it's fuses. Also check where the wiring runs through the door into the car for bare spots in the wiring that might have blown the fuses.
Jan 21, 2010 | 2004 Mitsubishi Endeavor
Car wont start and there is no power to it at all. The security light is on?
do you know if you have an anti-thieft device in your car. sounds like it may be armed and connected to your battery.
Oct 18, 2009 | 1995 Jeep Grand Cherokee
My inspiron laptop wont turn on after I replaced
Verify that you obtained an exact replacement power adapter for the Dell. If it is an exact replacement then try this. Disconnect power adapter. Remove battery. Reconnect power adapter without the battery. If it turns on, then power off and place battery back in. Then try again. If problem returns, there could be a problem with the battery itself.
Sep 28, 2009 | Dell Inspiron B130 Notebook
Phone wont power on
i have a change my password and many time i type wrong password then my handset not work
its show jvm error 513
Oct 24, 2008 | AT&T Blackberry Curve 8300 Smartphone
Fisher and Paykel GWL11 Top Load Washer Logo
148 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
