Question about Sony XL-2000U Projector Lamp for XBR800 serie
Lamp bulb where do you get the round bulbs from?
    Problem Solver:
  • 7 Answers
I have a Sony WEGA 40XBR800, my lamp went out not to long ago. I contacted Projector Lamp Services (relampit.com) They hooked me up with a brand new unit with an Osram bulb. It works great. Give them a call, they are very nice and informative.
Posted on Jan 13, 2009
  • 563 Answers
Hi shanoo
I've learnt that most Projector brands can take Osram lamps - try finding a Osram agent near you and remember to keep the wattage of the lamp the same as the previous.
Posted on May 13, 2008
Need to replace passanger side low beam lamp
Lift the hood, on the back of the headlight outter you will see a large round rubber cap. Remove the cap and you will see the back of the bulb, rotate the bulb counter clock wise and pull the bulb out. You may have to unhook the wire harness if it is too short to remove the bulb..dont forget to use the bulb grease to protect the socket.
Nov 25, 2011 | 1998 Buick LeSabre
My Eliminator E-144 runs but won't light up. I have replaced the bulbs, replaced the fuse, the fan runs, the sensitivity dial and mic work, it spins but the bulbs won't light up?
A very common problem with the small Halogen lamps at this power level is the socket contacts burn up and no longer contact the lamp pins. Check the resistance between teh slip rings (lift one brush as the motor will be in the circuit if you don't) and look for a real low resitance since you have 6000 watts of bulbs, they will draw 5 amps total when running so they are about 24 ohms hot and since incandescents are about 1/10 that when cold expect around 2.4 ohms or so. Make sure you do not handle the glass of the bulbs. I have found sockets if yours are bad at an online source as
http://www.divinelighting.com/round-multibase-socket-g4-g53-gy635-lamp-holder-p-263.html
Check which base your bulbs have though as I replace other lamps here and this may be different than yours.
May 02, 2011 | Eliminator E144 Mini Double Derby Dj Club...
Just replace my lamp with a new one, when i start my projector, everything seems to work fine but the lamp doesn't light up. the lamp light flashes green for 30 second, theres a ''motor'' sound in the same...
HI,
You can visibly inspect the lamp to make sure the bulb behind the glass is intact & the round part of the bulb is clear & round. Otherwise if possible return the lamp for exchange. If the same thing happens then the lamp ballast is likely bad. I have many in stock I can diagnose it.
Apr 14, 2011 | Sharp XR-10X Multimedia Projector
How do I replace a headlight bulb for a 2004 chevy malibu classic?
Change headlights in 2004 Chevy Malibu Classic
Open the hood and pull up on the two black tabs on either side of the lamp assembly. Pull the lamp assembly forward gently and unclip the wiring harness. Twist the socket counter-clockwise and remove it. The bulb should be removed by wiggling it.
Install new bulb in its place and turn the socket back into place. Reconnect the wiring harness and return the lamp to its original position. Line up the holes in the lamp assembly to the round ends of the mounting pins, and press down on the two black tabs to hook the lamp assembly into place.
Nov 22, 2009 | 2004 Chevrolet Malibu
Need to change a turn signal & back brake
PLEASE DON'T FORGET TO RATE!!!
Rear Turn Signal, Brake, & Marker Lights
  1. Disconnect the negative battery cable.
  2. Open the trunk.
  3. Unfasten the nuts or other retainers from the rear trim.
  4. Unfasten or release the housing cover retainers.
  5. On some vehicles, you may have to remove the rear fascia/body panel and light assembly to get to the sockets.
On some vehicles, such as this 1986 Grand Am, you must remove the rear body panel with the lamp
Depending upon vehicle application, remove the lamp socket either by rotating it counterclockwise (approximately 1/4 turn) until the plastic tabs disengage, or by squeezing the metal tangs while pulling the socket from the light assembly
Remove the lamp socket assembly by turning it counterclockwise, then pulling it out
Generally, side marker lamps use small bulbs with flat, blade-type bases, and tail lights/turn signals use larger, round-based ("bayonet") bulbs.
  1. Remove the bulb from the socket using the appropriate method. Bulbs with blade-type bases pull straight out, while those with round bases and protruding pins (bayonet-type bulbs) must be depressed, then rotated counterclockwise (approximately 1/8 turn) before pulling out.
Remove the side marker bulb from its socket by pulling straight out
To install:
  1. Secure the bulb in the socket using the appropriate method. Bulbs with blade-type bases push straight in, while those with round bases and protruding pins (bayonet-type bulbs) must be inserted, then depressed and rotated clockwise (approximately 1/8 turn).
  2. Install the lamp socket using the appropriate method. Depending on the type of socket, either engage the plastic tabs, and rotate the socket clockwise (approximately 1/4 turn), or push on the socket until the metal tangs engage.
  3. Install the housing cover nuts.
  4. If removed, install the rear fascia and light assembly.
  5. Install the rear trim.
  6. Connect the negative battery cable, then check the operation of the rear lights.
Oct 17, 2009 | 1995 Buick Skylark
How do you replace the brake bulbs in a 1996 dodge ram pickup
open the tailgate and y ou should see two to three screws along the edge of the housing, remove the screws and then the housing will pop off. behind the housing will be the wires leading up to the socket, twise the socket counter clockwise and it will pop out.. pull the bulb out... reverse to reinstall
Aug 19, 2009 | Dodge Ram 1500 Cars & Trucks
REPLACEMENT OF [LOW BEAM] HALOGEN BULB IN 2004 Buick LeSabre
I just Replaced a Low Beam Light bulb on a 2005 Buick La Sabre.
If You use a Metric socket and Remove the Two Silver bolts Attaching the headlight Assemble onto the metal surrounding the the lamp assembly it comes out to the front. This makes it much easier to access the bulb. Twist it counerclockwise & it comes out by pulling gently on the bulb. Then by realeasing a tab that is the socket holder bulb can be removed & replaced with a New #9006 low beam halogen light bulb. Wrap a Paper towel around the bulb & do NOT touch it with your bare hand as this wiil ruin a halogen bulb,
Jan 22, 2009 | 2004 Buick LeSabre
Zenith replacement bulb
I would suggest to remove the lamp from your TV and check it. You can also just buy the lamp without the other hardware.
This site seems to have good prices.
Let me know if you need any more assistance.
Mar 26, 2008 | Zenith E44W46LCD 44" Rear Projection...
Replacement lamp
The lamp you received is correct. I own a lamp replacement company. It may of been pakaged incorrectly or maybe you received just the bulb and not the housing or vice versa (housing included). First, unless housing is damaged NEVER buy a new one...just the bulb will do. Housings are the biggest markup on replacement lamps. They are manufactired at a low cost and usually retailers drive up the lamp price because they include an uneeded housing. The bulb itself (XL-2100U) should be a round bulb. Check out my listing and compare this to what you received:
http://rearprojectionlamps.com/2000u-lamp-p-2277.html
Dec 12, 2007 | Sony XL-2000U Projector Lamp for XBR800...
Sony XL-2000U Projector Lamp for XBR800 serie Logo
109 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
