I have an Amcoraire model AOS091HX that also displays an F1 error code. Fuses were blown on the outside unit. I read about the fix by replacing the capacitors in the middle of the circuit board. I contacted Pridium and was told the circuit boards from China have been on order for six months, so I have nothing to lose by replacing a capacitor or two. Any other advise would be greatly appreciated.
2 Suggested Answers
SOURCE: Amcoraire AOS091HX Dead
had the samething. 2 blown capacitors on that middle board. got new capacitors and system was back online. check out digikey electronics and order your new capacitors. hope nothing else is wrong with the board.
Posted on Jul 19, 2010
Flashing F1 display on status window. Unit will not start. It will chirp in response to remote control,but takes no action.
What model do you have, the UCHW model is a 13 SEER and only displays error codes starting with the letter ' E '
Email: Support@Pridiom.com
Nov 09, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
I have an F1 error code. The manual states that this means the inside and outside units are not communicating. What should I look for
F-1-No communicationbetween indoor and outdoor. Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Sep 09, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Hello unit has been running then just stop with F1 showing how can i fix this thanks cameron
The F - 1 error code shows a failure of the PFC & IPM circuit boards inside the outdoor unit.
We stock a complete line of Amcor parts.
Support@Pridiom.com
201-266-8234 option 2
Aug 03, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Trying to fix an AmcorAire AMD243HX system F1 code, not working.
We stock parts & have tech support for Amcor Mini Split Systems
Support@Pridiom.com
May 06, 2010 | Inverter AMD243HX ThruWallWindow Air...
WE have Amcoraire Mini split unit heat pumps. One is
P 4 code means problem with the outdoor unit, Most likely low on refrigerant. Check all copper pipe connections for leaks first, then add refrigerant after checking pressures.
Jan 17, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Jan 02, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Error code F1 displayed on unit
We had the exact problem with our unit at work. What we did was turned the unit off at the panel and grounded L1A (or B depending on which fan is displaying the error code) at the condenser and then verified that L1 was grounded at the air handler. In our case it was not, so we rolled L1A and L2S at the condenser. This fixed the error code on our units. Evidently the units need the same sequencing on the fans that the condenser has.
Jun 25, 2009 | AmcorAire UCHW-H12AF2 Split System Air...
Low cool air
Because the model numbers are based on the country in which you bought the unit, you will have to do the research yourself on the error code for your unit. Once you find out what the error code is you can determine if low refrigerant caused the problem. Here is the contact info website to download your manual.
http://www.amcoraire.com/index.html
Apr 03, 2009 | AmcorAire UCHW-H12AF2 Split System Air...
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
