Question about Daewoo Heating & Cooling
How do i get it to plow cold air - Daewoo Heating & Cooling
  • Daewoo Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Aug 31, 2010
Western plows
Needs bleeding,got air in the line.
Dec 09, 2013 | Cars & Trucks
My KitchenAid Subra fridge. it seems like the freezer is always producing cold air. It keeps the freezer so cold that it freezes the drain plug were the condensation is suppose to drain out of the freezer...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Mar 23, 2011 | KitchenAid Refrigerators
Plow cylinders seem loose, causing plow to move back and forth. 7.5 HT plow. could this be from low hydraulic fluid? If so what fluid is recommended
Have someone operate the plow as you look for loose parts while it changes direction. Low fluid would likely result in incomplete movement and high pump wear if it continues. You may need to bleed air from the system. You will need to check with the original manufacturer of the plow to find the correct hydraulic fluid and the fluid level required. Good luck!
Jan 22, 2011 | Garden
No air coming through the vents
Sounds like the door that brings in fresh air is not closing enough so when you get to moving it is not letting the cab recirculate the inside air and bringing in some from the outside which comes from the bottom of the windshield on the outside. along with when you get to hitting the gas going down the road you might be loosing a little vacuum and that door going to your vents might close a little.. ? what you thinkin? just a few ideas might not be a fix though thanks Jerry
Apr 21, 2009 | Chevrolet K2500 Cars & Trucks
Over heat after new thermostat
hey Tim, I have a 90 F-250 w/ plow. Did u have overheating issues before, or did u just purchase the truck? As u know u really need a heavy duty cooling system to plow. A truck purchased for plowing should have the 'plow package' option, which includes heavy duty cooling (engine, which is usually a bigger radiator) heavy duty battery and alternator, trans. cooler, heavy duty front end (for extra plow weight). So, my question is, is this a new problem, or not? My truck is set up for the plow, but I still have to watch the temp. gauge. I only have temp issues when driving down the road, plow up, not doing the actual plowing (sounds like your problem too). The plow up position blocks all incoming air to the radiator, so try driving with the plow as low as possible, and angle it all the way to one side, this will let the air flow, and works well w/ my truck. Let me know if this works for u or not. Curt
Jan 06, 2009 | 1991 Ford F350
Heating & Cooling Logo
124 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
Craig Hill
Steve
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
