Can not get disc drive to open - Computers & Internet
  • mjshorty316 May 09, 2008
    I tried to press the eject button and went into tools and clicked ejsct and it still wouldn't open.
    Sergeant:
  • 221 Answers
On the front of the drive there should be a tiny hole. This hole is a release mechanism that allows you to open the drive bay when it is stuck. You will need a safety pin or something else small enough to fit in the hole in order to open the bay.
Posted on May 09, 2008
I have satellite C50D-B-10q. How do I open the CD/DVD drive?
Removing discs
To remove the disc, follow the steps as detailed below:
Do not press the eject button while the computer is accessing the optical disc drive. Wait for the optical disc drive indicator to go out before you open the disc tray. Also, if the disc is spinning when you open the disc tray, wait for it to stop before you remove it.
1. To pop the disc tray partially open, press the eject button. Gently pull the disc tray out until it is fully opened. When the disc tray pops open slightly, wait a moment to make sure the disc has stopped spinning before pulling the disc tray fully open.
2. The disc extends slightly over the sides of the disc tray so you can grasp it. Gently lift out the disc.
3. Push the center of the disc tray to close it. Press gently until it locks into place.
How to remove disc when the disc tray will not open:
Pressing the eject button will not open the disc tray when the computer power is off. If the power is off, you can open the disc tray by inserting a slender object (about 20 mm) such as a traightened paper clip into the manual eject hole near the eject button.
Manual eject hole:
Turn off the power before you use the manual eject hole. If the disc is spinning when you open the disc tray, the disc could fly off the spindle and cause injury.
See page 4-8 of the user manual:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&cad=rja&uact=8&ved=0CB0QFjAAOAo&url=http%3A%2F%2Fwww.mytoshiba.com.au%2Ffile%2Fdownload%2Fresource%2Ffile%2F25248%2Fsatc50-satpro%2520c50%2520userguide.pdf&ei=hP8qVL7FH8jygwSZtIDwDw&usg=AFQjCNG3BeuYjMmp05rKf6DHmKe2CwfZxQ&sig2=5VtO-__wyjN_V8vBe9na3g&bvm=bv.76477589,d.eXY
Jun 05, 2015 | Toshiba Computers & Internet
How do I get the disc drive of a dvd recorder to open after getting out the disc and resetting the machine?
Go back through the release process you did the first time to remove the stuck disk. it appears that part of the mechanism that moves the drive did not engage again.
Apr 25, 2015 | Panasonic Televison & Video
I have an acer aspire x1200-b1601a with a cd/dvd drive that will not open without putting the tip of a knife along the edge and prying it open. the "magic" pinhole is behind the case's cover and cann
CD-ROM, DVD, or other disc tray not opening Locking device or software installed First, verify no locking software installed that prevents the tray from opening. If you are unsure, reboot the computer and as it is booting up, eject the tray. If the tray can eject as it is booting, but stops working after loading your operating system, something is being loaded that is preventing the drive tray from opening. Programs used to burn CDs are a common culprit.
Bad eject button If you are running Microsoft Windows, open My computer, right-click the disc drive icon and choose the option to eject. If this ejects your CD-ROM drive tray, the button on the disc drive is defective, and it is recommended that the drive be replaced.
No power to computer or disc drive If you have recently installed a new optical drive or you have moved the computer, the power cable to the CD-ROM may have become loose or disconnected. Reseat the power cable to make sure this is not the problem.
CD stuck within drive If you suspect that a CD may be stuck within the drive, the tray needs to be ejected manually. Look for the small manual eject hole that ( not the head phone jack) located on the front of the drive. Unwind a paper clip and place one end of the paper clip into the hole to eject the CD-ROM tray.
If CD-ROM tray opens part of the way, pull it gently to see if you can get it to open fully. If it cannot be opened any further, it is likely that the gears within the CD-ROM drive have become damaged or dislodged. But usually, a stuck CD is blocking the way.
Caution: If you are able to open the CD-ROM drive using a paper clip, we do not recommend continuing to do so. This is meant to be used as a temporary solution; the drive should be replaced.
What to do if CD or DVD stuck in drive? Note: This document is for disc drives with a disc in the drive that prevents the tray from opening. See our CD-ROM, DVD, or other disc tray not opening document, if the tray is not opening at all or doesn't seem to be getting power.
If the CD or DVD is not set into the disc tray correctly, it could be sticking up above the surface of the tray, causing it to get stuck with then tray tries to open. In this case, it may be possible gently shake the computer and move the CD or DVD into the correct place in the tray, allowing the drive to open. However, use caution when doing this, as you do not want to shake the computer too much, or you could damage other components.
If this is a desktop computer, you can prevent damage to the computer by opening the computer and removing the disc drive in order to shake or rotate the drive. When the drive is out of the computer, you can manually release the tray by inserting a paperclip into the manual eject hole.
In the case of a laptop computer or a slot load disc drive, since the CD or DVD does not sit in a tray, it cannot be shaken in order to adjust the disc. If the disc is visible you may be able to move the disc a bit by hand, enough to allow the drive to eject the disc. Again, be careful in doing so, as you could damage the disc or drive in the process.
If you're still unable to get the disc out of the drive after following the above steps, it may be a damaged drive and should be replaced. If the disc in the drive is an important disc and you believe the drive is bad, the drive can be disassembled in order to remove the disc. In the case of a laptop or computer with a slot load disc drive, the computer needs to be serviced in order for the drive the be replaced and the disc to be removed.
reference: http://www.computerhope.com/issues/ch001487.htm
Jan 03, 2015 | Acer Computers & Internet
I put a disc in the drive and it stayed in the computer when the disc drive was opened
I am assuming that when the disc drive tray came out, the holder was empty, and you had placed the disc in the holder prior to this. Did you use the disc? Did it operate properly? Has your PC been tilted for any reason before trying to remove the disc? My feeling is the disc has to be SOMEWHERE! Take a flashlight and take a peak in the opened drive. Can you see the disc anywhere? Perhaps tweezers can be used with scotch tape wrapped around the points to keep it from scratching the disc. Grasp the edge of the disc and pull it out, if possible. If you can't find the disc, you should open the case and do a search. You might need to remove the drive itself, but hopefully you will get the disc back without needing to go to that step.
Jul 14, 2014 | HP 19-2014 All-in-One Desktop PC - ENERGY...
Why won't my packard bell's cd disc or floppy disc drive won't open
CD / DVD and most optical drives - Manual eject by sticking a straightened paperclip in the tiny hole and gently push open.
Apr 02, 2013 | Packard Bell Computers & Internet
How to open driver door
Do you mean the disc drive tray won't open? Or do you mean you have a front panel cover on your computer that won't open? If the disc drive tray won't open it could just be stuck, if you look closely at your disc drives front panel you'll see a small hole, take a paper clip our some thing about 3 inches long that will fit in the hole insert it into the hole you'll feel it bottom out if you push on the paper clip firmly your disc drive door will open, ( I would do this with the computer turned off) If there's a disc in there take it out if not just push the try back closed don't force it completely closed it will do that itself, now turn on your computer let it completely finish booting and see if it the drive works. If it does not it's probably time for a new disc drive. I hope this helps
Jun 22, 2012 | eMachines EL1360G-UW11P Desktop PC
The discs won't get go into the playstation3
If your ps3 disc drive still makes sound maybe the top lid of the disc drive is not in the correct spot. Have you opened it before? Thats how the disc drive will get out of line. If you havent opened it before it might just need a good cleaning and lubricated. How to fix it if its out of line is to take ps3 lid off take disc drive lid off hook it up and place a cd in it and let the drive accept the disc then put everything back together with the disc in the disc drive. Now it should work right.
Nov 24, 2010 | Sony Playstation 3 (PS3) Console
Well it won't read any disc and the tray keeps opening and closeing
Does it say it keeps opening and closing or does it literally open and close if so its probably something wrong the motor acting or somthing inside of the disc drive if thats the case then i'm sorry to say but you might have to get a new disc drive. If your 360 is under warranty send it into microsoft if its not under warranty go online and find a disc drive but make sure its the same one you have currently inside of your 360.
Have you ever had to replace that disc drive before or no?
if so then your disc drive is the wrong one for that 360
Jul 01, 2009 | Microsoft Xbox 360 Console
Problem with disc reader
the motor that drives the laser is broke solution get a new drive or motor
May 04, 2008 | Microsoft Xbox 360 Console
Xbox 360 disc drive
To april23
what has most likely happened is that the magnet which holds disks in place has dis-lodged and is now stuck to the roof of the dvd drive. Unfortunately the only way to resolve this would be to open up the xbox 360 and open up the dvd drive to fix.
So if you're not confident at this or in doubt in any way I'd contact Microsoft first if it's still under warranty, if not then it's a case of opening up the drive yourself I'm afraid.
Note. Does the drive attempt to spin up when you put a disk in?
Or does it just make small noises then nothing except "open tray" on screen?
Oct 07, 2007 | Microsoft Xbox 360 Console
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
