Question about Estate EED4300VQ Electric Dryer
Motor humms bt will not turn, unless you help it
  • Estate Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The motor is going bad...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
Why does my maytag dryer when turned on get red hot instantly, yet the motor only humms?
quit buying parts ur motor is shot and u should be or soon be smelling a wireish burning smell.
Oct 08, 2014 | Maytag Dryers
Trades pro air compressor
Sounds like rod is seized on the crank... Oil lubed?
Apr 23, 2013 | Alton 3 HP 11 Gal Air Compressor
My kenmore washer series70 motor humms
yes there is a capacitor on most washing machine motors on a kenmore series 70 it should be on the right front panel upright leg
Dec 06, 2012 | Washing Machines
My 70 series just humms
What is the complete model number of your unit?
Dec 05, 2012 | Washing Machines
I have a kenmore 90 plus series model # 11068972892............... when i push start button the dryer motor will humm and mabey start to run or it will just humm and not run at all..if it...
Check under the machine and see if the motor turns easily by hand. It could be the motor, or it could be the bearing. The switching off after a while implies that the motor is struggling against a heavier than normal force and trips because of overheating. Most likely the bearing/s is/are ceasing up.
Sep 06, 2010 | Kenmore Dryers
Dryer humms but does not turn unless I rotate drum when turned on
HI. This is a damaged sator assembly in the motor casing. the cooper windings are damaged. this motor will need to be replaced asap, if possible.
Oct 19, 2009 | Dryers
My motor just humms and will not turn. Pump turns freely and motor shaft? Humms for a will then will kick out, but does not throw the breaker. thanks, David
I'd replace the start capacitor on this pump, I believe. Be careful with this kind of electrical device: they store power and will kick you and hard if not wairy,
Oct 18, 2009 | Emerson Threaded 1.5hp Fullrate 115/230v
My pump just humms willnot pump water
Im talking about general troubleshooting here. Usually with this size of motor 1Hp. Check if it have a capacitor, commonly if this humms the capacitor is faulty. It is a capacitor start motor. Another fault could be stuck up. Or one of the winding has a short. Hope it helps
Jun 04, 2009 | Sta Rite Dyna Glas Pump 1 Hp Ne857
Just humms when you try to turn it on,want start
Dryer motor is bad getting hot causing it to turn off
May 06, 2009 | Dryers
Motor humms and barrel will not turn
CHECK THE PUMP IT MAY HAVE A SOCK IN IT I FIT DONT THE MOTOR IT KAPLUT AND YOU CAN CHECK THE MOTOR BY REMOVING IT FROM TRANSMISSION AND PUTTING IT ON THE FLOOR AND TURNING MACHINE ON
Jan 08, 2009 | Kenmore 75944 Gas Dryer
Open Questions:
See all Estate EED4300VQ Electric Dryer Questions
Estate EED4300VQ Electric Dryer Logo
56 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
