Question about Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Toner set Alarm will not clear
The machine alarms "toner not set Insert toner"
The toner is relatively new, and is in place, (in fact the toner was removed and reset several times), the alarm will not clear.
Help
  • 2 more comments
  • Anonymous May 13, 2008
    I have a similar problem says to open printer door b/c paper is jammed and now the alarm light will not go off
  • cvaknin Sep 16, 2008
    the toner is new and can not get rid of the error message
  • nrichman398 Dec 17, 2008
    Faxes not going through, line fine, shut down and cleared board, still not going through. Reading most numbers as busy
    NR
  • jeffreybuch Jan 20, 2009
    same problem my toner cartridge says its not set so we bought another one and it says it not set right it only goes in one way what do you do
I clean the copper -coloured roll and took out all paper and it reset thanx for your suggestions
Posted on Jan 20, 2009
Yes it was paper in tray slightly ahead of pack. Paper jam?
Posted on Nov 26, 2008
  • 3 Answers
Turn off the machine, take out the toner, clean the copper-coloured roll, place it back in, ensure the paper is not jammed in anywhere.
I had the same problem. I done that above, now its fine
Posted on Sep 18, 2008
How to clear toner alarm indicator
change the toner sensor on the toner catridge
Jun 07, 2014 | Sharp AR-5516s
What code do i use to clear toner alarm indicator
it can't be cleared until you change the toner sensor
I change toner but alarm still on saying toner low
You may have to go into settings to clear the fault of low toner, depending on the year and make of printer. If that doesn't help then make sure that all packaging on the toner was removed and that it is the right cartridge
Oct 10, 2012 | Office Equipment & Supplies
Waste toner canon imagepress c1
if it is the 2nd transfer cleaning waste toner, you have to clear copier-counter-misc-2TC-Box
Jun 10, 2012 | Canon Office Equipment & Supplies
Alarm button flashing says install cartridge. I put new toner cartridge in but after reset, unplugging etc the alarm light and message still come on? Thanks
first of all, check if the triangle on toner tube and toner insert is alligned. Eaven the smallest gap can cause the problem's because the nose on toner tube presses the sensor flapper and signals that toner is inserted.
Also the problem can be in broken sensor flap, or hardened toner in toner station.
If the toner station is faulty you can try to dismantlle the toner station and vacume it.
Hope that helps!
Sep 11, 2011 | Canon imageCLASS D761 Copier
Have changed toner cartridge but alarm says check cartridge cannot clear the alarm or use the machine
The toner tube has a small nose on front side that when you place toner in, and turn it, that nose and little triangle on copier cover needs to be one against other. If it is, then should work, but if the sensor flaper on sensor for toner is broken it would not work.
hope that helped.
Pls. rate
May 12, 2010 | Canon imageRUNNER 1670F Grayscale Copier
Muratec mfx 1600 drum replaced alarm will not reset
Ignoring the Toner Empty Message
When the toner cartridge is empty, the machine shows a “Toner Empty”
message and stops printing.
You can set the machine to ignore the message when it displays and to
continue printing the pages.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button (�� or ��) until “Ignore Toner” appears on the
bottom line and press Enter.
3 Press the Scroll button (�� or ��) to select “On” or “Off.”
Select “On” to ignore the Toner Empty message.
Select “Off” to stop printing when the message appears. This is the
default setting.
4 Press Enter to save the selection.
Jun 18, 2009 | Muratec F320 Plain Paper LED Fax
Toner error message on copy machine
Is "CH" steady or flashing? If it's steady, the door is not shut properly.
If it's flashing, the machine doesn't detect the presence of the toner cartridge (defective toner cartridge). Try another toner cartridge (an empty cartridge will do).
To get the blue handle to stay locked sometimes takes fiddling with it when the cartridge is in.
Dec 07, 2008 | Sharp AL 800 Copier
Printer won't print
According to the operation manual: If alarm light and data light blink every 5 seconds- TONER LOW (purchase more toner and have it ready when the 'toner empty' is indicated). If alarm light and data light stay lit- TONER EMPTY (replace toner cartrige with new one).
Apr 21, 2008 | Brother HL 1440 Laser Printer
1,170 people viewed this question
old marine
old marine
