Question about Canon Powershot SX110 IS Digital Camera 9.0MP
I bought this camera on ebay for my daughter- it seemed like a good idea at the time. I have the same model (bought new) & have no problems. The ebay camera went through batteries alarmingly fast and when I changed them they were hot. On our 6th day of ownership a message appeared on the screen that said "Lens error, restart camera" We could not restart the camera b/c it wouldn't do anything - it was dead and the lens won't retract. Does this sound fixable? Does anybody know what would cause this?
  • Anonymous Mar 22, 2014
    I bought this knock off camera from ebay, and its dead, is there anywhere I can have it fixed
    Brigadier General:
  • 11,967 Answers
Of course, you now realize buying on Ebay carries some risk...why was the camera for sale in the first place...because it worked so well? Anyway, try these: Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Aug 31, 2010
My daughter took the face off the fan, held the blades still for quite some time and let go. They didn't move at all. It smells like it is burning, it's hot and I tried a new outlet still doesn't work. I...
your daughter burnt out your fan motor windings. you have 2 options.
1. buy a new fan. at today's prices, this is your best & easiest option But, you have to learn to be a comparitive shopper. start by going to amazon.com & looking at the fans ,the fan prices and if you get free shipping or have to pay and how much 4 the shipping. Next, go to ebay.com and type the name & model of the fan you are interested in. you may get an operitunity to buy a used fan there at a reduced price. note this down on paper but remember that ebay usually has only 1 or 2 of these items , and if you come back 2 days later,the add is gone . Ebay has a buy it now price and an auction price. I hate auctions, because you have to wait 7 or 10 days for the auction to be over & you might not get the item if some one else outbids you and you dont get the item for 3 weeks after the auction first started. If you really dont need something & dont mind waiting a month,that might be fun for some people,but not me. I need something ,i want it yesterday.I dont need something,i forget about it altogether. get at least 3 prices before buying because that way ,you at least have some idea of what the item is going for.SERIOUS SHOPPERS, who only want to buy for bottom $, go to google.com--or -bing.com or-yahoo.com--or ask.com & type the make & model # of the item they are looking for a deal on into the search box. You might have to go to 15 or 20 web sites, but somewhere along all that
searching, you will find your item drastically discounted.
True example, I went to home depot & looked at a 2013 homelite,16 inch, 42 cc gasoline chain saw for $179.99 plus 6.35% sales tax. after about 3 hours searching on the internet with google and bing, I bought that saw ,advertised as being
factory reconditioned for $78.65 with free shipping to first time buyers. I got a brand new ,never run, not a scratch on it anywheres gas chain saw and saved $100.00 from home depots price. It was the same year,make and model as home depot's 179.99 saw ,delevered free to my door for $78.65
that is why i dont recommend that you attempt to replace the burnt out fan motor. repair parts distrributors charge you at least twice what they paid for the part. if the motor cost them $50.00 they want between $100.00 to $139.95 for it. and then ,you still need to pay the repairman his time & labor.
If you shop like i told you to, you can probably replace the fan with a new one ,for 1/2 of what you originally paid for it, through the power of internet search engines. PS also a good place to ask questions,get answers and learn things by reading previously writen articles about whatever you are inquiring about.
customer reviews at amazon.com are good to learn about something youthink you might buy. You find out if others love it or if it is a piece of junk. read both the good reviews and the bad reviews. I like to read the bad reviews first, to get an idea whats bad about the item, I may look for a higher quality brand if the cheap one has too many bad reviews.
BE AN INFORMED CONSUMER,BEFORE PURCHASING.
Sep 29, 2013 | Lasko Dryers
Lasko fan motor overheating
BUY A NEW ONE . YOUR IS TOTALLY FRIED and not worth fixing.
read below--same problem,same advise.
*(your daughter burnt out your fan motor windings.)*
you have 2 options.
1. buy a new fan. at today's prices, this is your best & easiest option But, you have to learn to be a comparitive shopper. start by going to amazon.com & looking at the fans ,the fan prices and if you get free shipping or have to pay and how much 4 the shipping. Next, go to ebay.com and type the name & model of the fan you are interested in. you may get an operitunity to buy a used fan there at a reduced price. note this down[fan info] on paper but remember that ebay usually has only 1 or 2 of these items , and if you come back 2 days later,the add is gone . Ebay has a buy it now price and an auction price. I hate auctions, because you have to wait 7 or 10 days for the auction to be over & you might not get the item if some one else outbids you and you dont get the item for 3 weeks after the auction first started. If you really dont need something & dont mind waiting a month,that might be fun for some people,but not me. I need something ,i want it yesterday.I dont need something,i forget about it altogether. get at least 3 prices before buying because that way ,you at least have some idea of what the item is going for.SERIOUS SHOPPERS, who only want to buy for bottom $, go to google.com--or -bing.com or-yahoo.com--or ask.com & type the make & model # of the item they are looking for a deal on into the search box. You might have to go to 15 or 20 web sites, but somewhere along all that
My daughters 350d will only take pictures in manual focus mode, in auto focus it all seems good but it won't actually take the picture? Any ideas?
Shutter Assy, Mirror Assy or Shutter Button taken a coffee breaks.
You did try using a new battery?
Or your battery is not over 3 years old?
If I can help, just send me an email.
atdlee@netzero.com
Dec 30, 2012 | Canon Rebel XT / EOS 350D Digital Camera
My daughter just turned 16 and we bought her a beautiful 2005 nissan maxima se. We all love it. It has 71,000 miles on it and looks brand new. When I was driving it home tonight I noticed jerking and...
it might be a good idea to have the transmission serviced by a qualified transmission specialist then you will know if there are any problems with it,seeing as it is your daughters car you want her to be safe when she goes out & not have to ring mum or dad to go & fetch her........hope this helps......cheers.
Sep 05, 2011 | Nissan Maxima Cars & Trucks
Hi i have a sony dcr-pc3 my wife bought it in 2000 and it never holds a charge the longest we get is about 10 minutes we bought a new battery and have just bought a new charger same old...
Well if you have bought the right battery and the proper charger this sounds very odd, did the amp hr and every say the same details on the battery & charger as the old one? when you charge the camera how long was it till you used the camera? as Sony cameras lose around 30% charge per week, I know because I have a Sony still camera and movie, both lose charge, my still camera goes flat in 3 weeks after a full charge with no use at all, so they are never good bits of equipment with batterys.
Jun 20, 2010 | Sony Handycam DCR-PC3 Mini DV Digital...
Hi, We bought our daughter th Smoby interactive
Normally with a digital camera there is a cd following with the purchase !
You need to put the cd in the cd/dvd drive and "install" the software. After that you should bee able to see the picture taken with the digital camera.
Normally you inport the pictures to the computer and then you can see them. For inport the picture you need a cable that normally follow with the purchase, if not then you need to buy one cable compatibel to your digital camera.
The cable you put in the computer and then in then camera on the other end.
Hope thats help
Aug 24, 2009 | Computers & Internet
Casio exilim digital camera 7.2 mp
I bought a non functioning camera like mine on ebay and put the new screen in. Not a project for the faint hearted. Requires magnification, a really good jewelers phillips and some soldering skills. The most practical solution, for what it will cost to have it done, is get another camera, there are some pretty good deals on ebay on demos and used cameras.
Mar 08, 2008 | Casio Exilim EX-S600 Digital Camera
Nikon coolpix 2100 camera won't stay on
I've been having problems with the batteries and the camera refusing to start even with fresh batteries. I bought loads of new rechargable batteries and have finally found some that work. Duracell rechargables. Theyr'e brilliant and keep their charge for ages despite continuous use of the camera! Last summer I managed to take 975 photos before the batteries finally decided to give up!
Jan 27, 2008 | Nikon Coolpix 2100 Digital Camera
Canon Powershot SX110 IS  Digital Camera 9.0MP Logo
81 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
