Question about Fisher and Paykel DEGX2 Dryer
Cloths take excessive time to dry, no blockages, heating element is hot.
  • Fisher and P... Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Posted on Sep 12, 2010
My dryer heats up but does not dry clothes. I check ventilation and lint trap, there is no buildup. what could cause it to take forever to dry clothes?
If the drum gets hot to a real degree it has to be a blockage between the drum to where the air exits the home.
They do make a brush designed to go into the area where the lint trap is and be long enough to come out the rear of the unit---A lot of places will come out and professionally clean from trap to vent outlet
A blockage can be dangerous as hundreds of fires happen each year from the lint catching fire in the dryer.
The tube to the outside may seem clear but if blockage anywhere from lint trap to it, that will cause this problem and present a possible fire hazard.
Its not unlike having your vac not pick things up very well...except there is rarely a fire with that.
Dec 16, 2012 | Kenmore Dryers
Dryer putting out hot air but clothes not drying
You have some blockage between lint trap and where the unit vents outside.
Dec 16, 2012 | Kenmore Dryer Sears Elite
Hot tub won't get hot enough
Low Heat -
This problem is not usually associated with the heater element but more often a result of water flow issues. Specifically blockages such as dirty filters, partially closed valves etc... But... excessive scale/mineral build up on the element is on uncommon and can result in reduced heating. The fix is easy, use chemical treatments to reduce scale build up.
No Heat
No heat or water is only heating to 60F- 80F? If you are getting a low reading this is because the water is only being heated by the friction caused by running through the plumbing system and pump. Assuming there has not been a dry fire (visual signs of burn/overheat marks/ damage to the heater tube) and your temperature sensor and hi limit are in working order.
A bad element. Like a light bulb, spa heater elements will burn out over time & there are many factors which affect their longevity.
Nov 25, 2012 | Home
Dryer not drying in alloted time
there is a thermostat. it usually is located on the heating element housing
May 26, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My Maytag model LDE312 dryer heats up but doesn't seem to get hot enough. It takes 2 hours or more to dry. Is this a thermostat or heating element problem?
Could be a blockage in the exhaust. If the clothes are coming out hot but still damp after the first cycle then there is a blockage in the exhaust in the dryer. This blockage could be where the lint filter is or in the exhaust vent to the outside of the unit. The best thing to do is pull the unit from the wall and access the back panel. Remove the back panel and with a wet/dry vac clear out the inside of the unit. Then check for a lint blockage in the hose that is connected to the back of the dryer. That should have corrected your problem If an element goes out there is no heat at all and I doubt the thermostat would go out like that Maytags are rare to have a thermostat just go out
Hope this helped
Dave
Mar 21, 2010 | Dryers
GE DWSR463EGWW electric dryer takes forever to dry clothes. Heating element comes on but then goes off. Where do I locate the thermal fuse if that is the problem.
The thermal fuse only shuts off the elements if the proper air flow isn't acheived. If the clothes are hot but still damp after the drying cycle then you have a blockage in the dryer exhaust either at the hose at the back of the machine or in the lint filter area. Check both and clean and your problem should be solved.
Hope this helped you
Dave
Jan 14, 2010 | GE DWSR463EGWW Electric Dryer
Dryer heat cuts out after 10 min. please help tested thermostats and element. cleaned out lint where eve i could. what else could it be
Pull the dryer out , and remove the vent hose from the dryer . Dry a load of clothes , and see it it dryes in a suitable time . If so , then a vent problem , either kinked hose , outside vent blockage , or if an up vent thru the attic , then possibly blocked . A dryer either heats or doesn't , and excessive time , indicates a venting problem .
Nov 20, 2009 | Whirlpool Dryers
Hotpoint aquarius ctd40
most likely, there is a blockage in your exhaust. take it apart and check every inch from your dryer to the outdoors. i clean mine once a year, it keeps the dryer running efficiently. when lint backs up in there, the heat cannot get out and there is a sensor that will shut off the heating element when it gets to a certain temp, so your clothes will take a long time to dry
Oct 27, 2008 | Hotpoint TDC32 Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Fisher and Paykel DEGX2 Dryer Logo
112 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
