Question about Logitech Cordless Mouse
The mouse There is no pointer registering on my pc monitor. I don't know how to access anything without the mouse.
  • 172 Answers
Hello deeber,
First off you should retart your computer and see if the pointer returns. To do this simply hold your power button in for 5 seconds and your computer will restart. Your pointer will return assuming you have a mouse installed. Good Luck and I really hope this will FIXYA,
Mike Anderson
Posted on May 09, 2008
  • Michael Anderson May 09, 2008
    You may also use press the wiindows button then use your arrow keys to navigate, then you can use the control button press it and you can navigate through your icons. Save all information you need save and restart. your Pointer should return.
    I hope one of my answers will fixYa. Good luck to you
    Mike Anderson
    Sergeant:
    Novelist:
  • 166 Answers
Hello there.
I recommend doing the following:
1) Shut down the computer (you can hold down the power button on the front of the computer base unit or laptop power button for a few seconds instead of using the mouse)
2) Unplug the mouse base station.
3) Plug the mouse base station in again
4) Turn on the computer and let it start up as normal.
5) Watch for any system messages appearing, like found new hardware.
These steps will verify that there is not a problem with the mouse's base station plugged into the computer. Another thing to check is if the mouse requires batteries, this is often overlooked.
If after doing this there is still no pointer registered, i would suggest trying the mouse in another computer, and if possible trying a different mouse on the same computer.
If the mouse works on another computer then it could be a software problem, which we can help you with.
If the mouse doesn't work on another computer, but a different mouse works fine on the same computer, then im afraid your mouse has to be replaced.
Please post back after trying the above steps and let us know. Telling us which mouse you have exactly will futher help.
Hope this helps.
How to change view size in windows 8
You can change the view size in Windows 8 in the following ways:
1) By changing the size of text and other items on the desktop
You can change the size of text and other items (like icons) on your desktop without disturbing your current screen resolution settings. To do this, follow the steps mentioned ahead:a)Open Screen Resolution by swiping in from the right edge of the screen, tapping "Search" (or if you're using a mouse, pointing to the upper-right corner of the screen, moving the mouse pointer down, and then clicking "Search"), enter "Make text larger" in the search box, and then tapping or clicking "Make text and other items larger or smaller".
b) Drag the slider until the items in the preview image are the size you want them to be.
c) Tap or click "Apply".
You'll see the change the next time you sign in to Windows.
Also, you can change the text size for specific items (such as Window title bars or tooltips) without affecting the size of anything else on your desktop. Follow these steps to do this:
a) Open Screen Resolution by swiping in from the right edge of the screen, tapping "Search" (or if you're using a mouse, pointing to the upper-right corner of the screen, moving the mouse pointer down, and then clicking "Search"), entering "Make text larger" in the search box, and then tapping or clicking "Make text and other items larger or smaller".
b) Under "Change only the text size", choose the item you'd like to change and pick a text size. If you want the text to be bold, select the "Bold" check box.
Note: To view a pictorial description of the above process, refer to the link:
http://nvidia.custhelp.com/app/answers/detail/a_id/3153/~/adjusting-windows-8-display-size%2Fscaling-for-high-dpi%2Fppi-monitors
2) By changing screen resolution
You can change the view size on your desktop by changing screen resolution settings. To do this, follow these steps:
a) Swipe in from the right edge of the screen, tap "Settings", and then tap "Change PC settings" (If you're using a mouse, point to the lower-right corner of the screen, move the mouse pointer up, click "Settings", and then click "Change PC settings").
b) Tap or click "PC and devices", then tap or click "Display".
c)Tap or click the resolution slider and drag it until you find your desired resolution.
d) Tap or click "Apply".
To know more about the best screen resolution settings for your desktop, refer to "Set your monitor to its native resolution" section on the following link:
http://windows.microsoft.com/en-IN/windows-8/get-best-display-monitor
GuruAid.com
Jun 01, 2014 | Computers & Internet
Mouse pointer disappers
I've seen this happen a couple of times when Word uses the initial preview "Read Mode" or Protected View . Try changing the mode by clicking on the View tab and changing the mode to Print Layout. When it happens to me, that seems to do the trick. If you don't want Word to use the Protected View, go into the Trust Settings for Protected View and uncheck the options in there...this may also keep it from happening in the future...good luck! :-)
Apr 24, 2014 | HP Pavilion 23xi 23" LED LCD Monitor -...
There is no pointer and don't know how to get it back, can get into mouse options but can't do anything without the pointer
Shut down, unplug from AC, remove battery, plug into AC reboot, Have you tried a USB mouse?
Dec 13, 2012 | Computers & Internet
I have a hitachi 51f500 and I plugged my computer directly to the tv using the dvi port on the back of the tv. But I don't know how to get my computer to display the screen onto the tv, all i can do is...
I cannot tell you without knowing your type of pc and make and model including OS, however as a pointer,
Laptops there is normally a Function (F) key with 2 monitors on it , that when used in conjunction with the FN key (bottem left), will allow you to enable external monitors
For Desktops its can be in a few places, if you "Right mouse click" on the desktop and select personalise on vista and win 7 or properties you will find some options there to play with that allow you to enable dual displays and additional adapter settings, these vary from PC to PC, however if you cant find it and can provide me with those details I will have a look for you.
Please rate me to allow me to improve.
Regards
Andy
www.pcbee.co.uk
May 12, 2011 | Televison & Video
Curser turns to circle with black line through it
Hello, Try changing the cursor's color with these detailed instructions:
No. Mouse actions Keyboard actions 1 To open the Ease of Access Center, select:
  • Start.
  • Control Panel.
  • Ease of Access.
  • Ease of Access Center.
To open the Ease of Access Center, press:
  • Windows logo key winkey.gif+U.
2 Under Explore all settings, select:
  • Make the mouse easier to use.
  • Make the mouse easier to use by pressing TAB, then ENTER.
3 Under Mouse pointers:
  • Select a cursor and pointer combination.
  • Select Save.
Under Mouse pointers, select a cursor/pointer combination by pressing:
  • ALT+R for Regular White
  • ALT+U for Regular Black
  • ALT+G for Regular Inverting
  • ALT+L for Large White
  • ALT+B for Large Black
  • ALT+I for Large Inverting
  • ALT+X for Extra Large White
  • ALT+K for Extra Large Black
  • ALT+N for Extra Large Inverting
  • Select Save by pressing ALT+S.
May 06, 2011 | Compaq Computers & Internet
I have a Dell studio laptop. Recently, within the
1. In order to fix this, you go to control panel > mouse
the last tab is called "Device Settings" click it and make sure you have "static tray icon in taskbar" selected.
(You can always remove this later.) Apply the changes and click the red coloured icon in your task bar. An option will be available called "Tap to click." Clicking it will enable you to tap with your mouse pad instead of the keys! Hope this helps you out, I know it helped my friend.
2.
In the Control Panel open Accessibility Options Icon and click Mouse Tab and than Setting.
To move the mouse pointer by using MouseKeys
If you have not already done so, turn on MouseKeys.
To turn on MouseKeys, open Accessibility Options, click the Mouse tab, and then select the Use MouseKeys check box. Use the buttons on the numeric keypad to move the mouse pointer. If MouseKeys doesn't function, press NUM LOCK, and then try MouseKeys again.
To move the pointer horizontally or vertically, press the arrow keys on your numeric keypad.
To move the pointer diagonally, press HOME, END, PAGE UP, or PAGE DOWN on your numeric keypad.
Notes To open Accessibility Options, click Start, click Control Panel, and then double-click Accessibility Options.
To specify whether NUM LOCK must be on or off for MouseKeys to function, on the Mouse tab, click Settings, and then for Use MouseKeys when NumLock is, click On or Off.
To change the pointer speed and acceleration when using MouseKeys, on the Mouse tab, click Settings, and then move the sliders to adjust the pointer speed and acceleration.
To temporarily increase or decrease the pointer speed, on the Mouse tab, click Settings, and then select the Hold down Ctrl to speed up and Shift to slow down check box.
Jul 27, 2010 | Dell Studio 1737 Laptop
Monitor does not display picture,only the mouse pointer
If you're seeing only the mouse pointer it means there is likely a problem with your hard drive. Perhaps windows has a bad file. Has anything changed recently? Any new programs? A short? a strange smell?
Jun 09, 2009 | E-Machines eMachines Desktop PC
Wireless mouse lags
It may either be that your mouse is due for new batteries (this happened to me and I know what you mean, it is pretty tough to use when it lags around like that), or your mouse settings are messed up. To change your mouse settings go to start > control panel > mouse > pointer options. In pointer options there should be a button you can slide to either increase or decrease the speed at which your mouse moves across the screen.
I hope this helps, let me know if there is anything else I can do to help.
Sep 19, 2008 | Computers & Internet
Logitech Cordless Mouse Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
