Question about GE WHRE5260E Top Load Washer
WHRE5260E1WW (GE washer) will not empty after wash or advance to spin cycle..then after a while shuts down
I I unplugged the machine to reset the electronics...no help. This thing works fine up to the point where it needs to pump out water and spin. Just sets there till the darn thing finally shuts off. Is it anything short of replacing the expensive electronic controller? One last thing anyone know where is the cheapest plase to purchase parts?
Thanks in advance for all ypur help,
sam
  • 2 more comments
  • onlysamiam May 09, 2008
    I removed the pump, it checks fine. I applied a external voltage and it pumps out water. I checked the input voltage at the pump when it should be running and no voltage detected. I checked the lid switch and it is fine. Any other suggestions?
    Thanx...Sam
  • nancy wandler Dec 24, 2008
    Our washer is doing the same thing as one above please send anwer the question to nwandlers@hotmail.com Thank-you
    cycle..then after a while shuts down problem, and notify you when a new
    solution is offered.
  • mdnygirl Apr 16, 2009
    How do I get access to the drain motor pump?
  • 975 Answers
Try this , open washer do you can look inside , theres a DRAIN MOTOR PUMP with 2 hoses connected to it , have a bucket ready and some rags , your gonna take out the drain motor, that could be clogged and not able to continue with the drain rinse cycle. clean the impellers of drain motor , reinstall , and try again , hope this helps , please rate and thanks AJ
Posted on May 09, 2008
Bad lid switch
GE front load washer shuts off mid cycle
you will need to contact manufacturer to get it repaired
Jan 03, 2013 | GE WCVH6800J 27" Front-Load Washer with...
GE washer won't complete cycle
there are contacts inside timer which may not be working properly. in any case they are not repairable.
Oct 28, 2009 | GE Washing Machines
Washer won't wash
Hi!
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 30, 2009 | GE Washing Machines
GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
Apr 24, 2009 | GE Profile WPRE6100G Top Load Washer
How do you reset the washer?
I have a GE WBSR3000GWS Model and it stopped spinning at one point as well. My service guy came out and did the procedure below and reset it with in minutes.
How to Reset your GE Washer :
1. Turn the dial like your going to wash a load but do not pull the knob.
2. Unplug the washer from the wall and wait for 30 seconds.
3. Plug the washer back into the wall.
4. Lift the lid 5 times to at least 6 inches high. Open/Close within 15 secs.
5. Pause… You should here a click. If you do not, then repeat 1 – 5 again.
6. Insert a towel or garment into the washer and then pull knob to start the wash cycle.
7. Check the wash cycle to make sure the washer is agiating and spinning during its cycle.
GE Answer Center : 1-800-626-2000 opt 3 - for more information
Lale
Jun 20, 2008 | GE WBSR3140DW Top Load Washer
GE Washer stuck on final spin cycle
when i start my washer it stays on the spin cycle
any tips on what might be the problem
Apr 06, 2008 | GE WBSE3120B Top Load Washer
GE Washing Machine
Saragary,
It sounds to me like the safety switch for the washer lid is faulty or just out of adjustment (you'll find an arm sticking out of the lid that corresponds to a similarly shaped but larger hole in the jam of the lid and that is where the switch actuator should reside).
Or, your timer might be at fault, since it completes cycles once you manually advance to the next one.
Eliminate the safety switch as the possible fault before moving on to the timer itself, as the timer is more costly.
Good luck.
Mar 16, 2008 | Washing Machines
GE WHRE5260E Top Load Washer Logo
769 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
