Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer won't go below 18 and gets warmer when refigerator door opens
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 01, 2010
Kelvinator Cyclic 330 not getting cold enough
Empty the refigerator and freezer, unplug it for about 8 hours, leave freezer door open so it will completely defrost. Plug it back in for 4 hours and close doors before you fill it back up with food. If you have a thermometer, check the interior temperatures before you fill it back up. Refigerator should be around 42 degrees F.
Mar 19, 2014 | Refrigerators
Freezer works but refigerator won't get cold
IF YOU HAVE ALOT OF FROST ON THE BACK PANEL OF THE FREEZER IT IS A DEFROST T-STAT THAT CAN BE BAD IF THERE IS NO FROST FELL UP IN THE LEFT UPPER CORN OF THE FRIG SIDE SEE IF YOU CAN FILL THE AIR COMING OUT OF IT
Nov 01, 2012 | Frigidaire Ffhs2313Ls 23 Cu Ft Side By...
GE Monogram series side by side model zisw42em I had a "de" defrost system alarm and both sides (refrigerator and freezer) were warmer than usual. I manually rotated the defrost timer which...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
The opening should be at the top probably behind the plastic removable cover.
Aug 07, 2011 | GE Monogram ZISx420DR 42-inch Side by Side...
WONDERING WHY MY GE GSS22SGRB SS REFIGERATOR ISN'T GETTING COLD, ALTHOUGH THE FREEZER SEEMS TO BE WORKING PROPERLY.
you should have a dial or knob that says freezer colder or warmer if so turn it for freezer to get warmer thast should allow cold aiur from freezer to enter into ref. that should make ref. colder. if to cold then dail it back a little at a time till ref. is what u like. ok try that. later gator.
Feb 15, 2011 | GE Monogram ZISS420NRSS 42" Built-In...
I have a freezer that does not keep tempreture. When I set it to -18 it will not get any warmer than -13 and if I try a super freeze it will take it the best part of all day to get to -18 and then it falls...
That you can get down to -18 suggests the compressor works and there is enough gas to get on with. Check the seals of the freezer for a heat leak- it should be able to grip a piece of paper in the door when it's shut. If the seal is bad then the paper will fall out or come with a gentle pull - order and replace the seal.
Sep 11, 2010 | Bosch Freezers
Late model freezer below maytag refigerator leaking water out the bottom where is the drain located?
drain is in the back behind the plate . and below the evap coil . if its covered with ice you cannot see it .. mm
Aug 06, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Refigerator is freezing food
Hi, this problem is going to be with the running thermostat. It has gone bad and stays open which in turn will keep the compressor running continually. It can normally be located in the control panel inside the fridge. Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Sep 18, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Maytag refigerator dripping water internally from freezer on top
you have a drip pan under the frig dump it.. yes its defrosting
Mar 24, 2009 | Maytag PTB1553G Top Freezer Refrigerator
Water won,t dispence from the freezer door. the water pumps to the bottom of freezer door,but don,t come out of the nozzel.
Water line in door is frozen. Set frzr warmer and leave door open an hour or so so it thaws out.
Nov 27, 2008 | GE Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
41 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
