D-Link AirPlus G DWL-G710 Wireless Range Extender Logo
Posted on Aug 31, 2010
I have configure my dap-1150 but the problem is limited laptops only can connect on it.. as only 3 laptops... other laptops cant, and even when connected no internet access.. whats the best solution for this.. tnx and more power
2 Related Answers
Anonymous
  • 32281 Answers
  • Posted on Sep 28, 2009
SOURCE: configuration dap 1150
You cannot configure the DLink by the URL address http://dlinkap?
You connect a LAN cable from your computer to the DLink.
Then open Internet Explorer and enter the URL http://192.168.0.1
the default login = admin
the PW is blank (just press Enter)
You can now configure the DLink.
crashdr
Matt Gleeson
  • 4 Answers
  • Posted on Apr 05, 2010
SOURCE: configuring DAP-1150
the dlinkap address is the netbios address to access the AP, if you happen to not have netbios enabled on your PC for the network adapter you are using to access the AP, then that address will not work.
The easiest option is probably to use the blue cable that comes with the AP and connect via ethernet to access the AP web interface rather than trying to do it via wireless, at least initially until you get the AP set up.
The default IP address for the AP is 192.168.0.50, so if you set the network adapter on your PC (ie. the one you are going to use to connect to the AP, most likely called "Local Area Connection" if you are using the blue cable) to an IP on the same subnet that isn't already used by another device on your network (for example, 192.168.0.51 - let me know if you'd like more clarification on how to perform this step) and then type into your browser: http://192.168.0.50
You will then be presented with the AP's web interface login screen, if this is the first time you are setting up one of these brand new, or freshly reset to factory defaults, then the username is (all lowercase): admin
...and the password is blank, just press enter or ok/login.
How can I assign IP of my access point Dlink DAP-1150 on my lap top. I want to add adapter network DAP-1150 on my pc
there are 3 ways of setting it up as an Access Point, Wireless Client, Wireless Repeater mode. Would be easier if you explain what you want to use it as?
Choose what you want to use it as, you can set it up plugged into the router or over the wireless , so just plug it into your router and follow the instructions in the manual, you will then be able to unplug it and it will automatically connect to the router over the wifi. manual can be found here ftp://ftp.dlinkla.com/pub/drivers/DAP-1150/DAP-1150_A1_Manual_1.10%28B%29.pdf
How to assign static IP of my access point DAP 1150 to my pc
From your computer, get the MAC-address of your network adapter.
Configure the router to always give out the same IP-address for that MAC-address.
Why i can not go to sit for configure DAP-1360
Go to this link http://support.dlink.com/ProductInfo.aspx?m=DAP-1360 and download the user manual for your DAP-1360. Configure it in the WISP mode following the manuals instructions.
2answers
I configure a DAP-1150 and can connect via a laptop but my iphone and ipad fail to connect it. However, when I reset the DAP (with no security), the opposite happens! It means that my iphone and ipad can...
That is because your laptop has the saved connection history that you need to delete. Since your acces point does not have security which is not the same as the one that saved from your laptop. Therefore, your laptop won't be able to connect. Go to network and sharing center and from the left side of the page that came up look for change wireless adapter settings and click it. You will be able to see the connections that was saved and the top one would be your connection name. Delete that and close everything. Try connecting to your wireless network again and that should resolve the issue.
3helpful
3answers
I have DAP-1160 wireless G access point. My pc won't rekognize it. it worked befor reseting, after that the STATUS led does not blink.Not even when it's connected to the pc. What is the problem?...
I had the same problem with a DLINK DAP-1160, it did not seem to reset and I could not connect, nor PING it. It turned out that the box WAS resetting, and although the default IP address 192.168.0.50 and subnet 255.255.255.0 was being set, my computer was assigning itself up a private IP address and subnet 255.255.0.0. In the manual, it does say that you must be on the same subnet, so I changed my alternate IP address for my ethernet to be static and set the subnet to 255.255.255.0 and everything sprung in to life.
To summarise: make sure the computer you are using to configure the DAP-1160 has its subnet to 255.255.255.0.
Cant open the link to setup the router
Refer to page 3 of the Quick Install Guide listed on the web site below.
There are multiple ways to configure this router and do not wish to provide HOW TO without knowing how you have it set-up.
www.dlink.com/products/default.aspx?pid=DAP-1522&tab=3
5helpful
Can't open DAP-1150 configuration utility
The DLink URL WEB configuration uses an IP address not //dlinkap
Try http://192.168.0.1
The default ligin = admin
The default PW = blank ie. nothing
4helpful
2answers
Configuration dap 1150
1helpful
Dlink dap 1522
I think I was having a similar problem with my DAP-1522 ... FW Version 1.10 being used as an access point. I recently discovered that I was not able to connect to the configuration pages using a web browser by typing in it's IP address (192.168.0.50). When I originally set this up device up on my network, it worked just fine, but at some point in time, it stopped working. My solution to this problem was to set the switch on the back of the 1522 from Auto to AP, then re-boot the DAP-1522 by removing power, waiting 10 seconds, then plugging power back in. Once the AP re-booted, I was then able to access the configuration login page by typing 192.168.0.50 into my browser. My DAP-1522 access point is connected via port 1 to my D-link router, a DGL-4100, via a DGS-2208, 8 port gigabit switch. Hope this helps!
32helpful
10answers
Configuring DAP-1150
address to access d-link DAP-1150
http://192.168.0.50
you have to make sure that your ip address is around 192.168.0.xx
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
