Question about Google Computers & Internet
Won't start. put new starter on. put new computer on. put new ingtion on . still nothing on the ingtion.won't turn over can turn it over from underneith.
  • 1 more comment
  • larrybundy Aug 31, 2010
    SORRY I forgot to tell you the lights comes on inside of the van when the key is on. head lights comes onBattery light Scurity light.When it is in park gear shift lights park nurtal drive they all light up.where usual when it is in drive just drive lights up.
  • larrybundy Sep 01, 2010
    yes we are talking about my car. yes after changing these parts the engine does not start. you said please clarify. thank you larry bundy
  • larrybundy Sep 10, 2010
    hi. I take it that your not auto machinc . I'm Sorry to bother you. all of what you said did not work. the van still does not run. do i still get my money back? Thank You Larry Bundy
  • 4,924 Answers
Please explain what you are talking about ..cause from your post there isnt clear about what kinda device you are talking and what you are trying to do ..
Here is what appears on the problem post ..written by you ..
from this ...we can not figure out about what you are talking ..
Please
add a comment and explain all..and be specific about
Posted on Sep 02, 2010
  • 2,973 Answers
Larry, I think you are talking of your car. I was not sure as the question happens in the Google Internet. Anyway, please tell me the exact problem clearly. What I understand is that even after changing all these parts the wngine does not start. And it does not even turn with the starter. Please clarify.
Posted on Sep 01, 2010
  • Rinoo Kumari Sep 02, 2010
    New starter means the complete starter assembly or just the motor???
    If it is just the motor then it could be the Bendex that has gone. It is the small part placed on top of the starter to pull and push the starter pinion. This pinion has to engage the flywheel and turn it. Once the engine starts this pinion retracts when you release the ignition key. If this is bad then the engine will not turn. It can be repaired or replaced depending on the damage caused to it. But it is a professional job that should not be undertaken at home unless you are well conversant with it.
    Most likely it is this part causing the problem.
  • 11,800 Answers
It appears that the key contact is broken - nothing is connected there, it's like the key isn't turned. Simple test - remove all the wires to the key switch and hotwire them.
Posted on Aug 31, 2010
  • 1 more comment
  • Azrael SRL Sep 01, 2010
    In that case the key switch is probably fine (test it anyway). The wiring is completely messed up - start by checking the harness under the dash.
    azraelsrl. Yes I'm Talking About My Car. Yes after changing all these parts the engine does not start. You said Please clarify. Larry
    As i said you must check the wiring harness under the dash - some wires are broken or disconnected there.
I need to know whats the problem my car wont start but eveything is on wen key is in the ingtion. wen turning i hear nothing.
does all lights go off when u turn the key to start the engine ?
if so then its your battery.
if not then its your starter motor.
Dec 29, 2015 | 2006 Sienna Xle Sunroof Motor
I have 2002 pt . I have no problem with it, started it and put in gear, went to pull out and it shut off, now it won,t start back up, put new battery in, new switch, still nothing,
Possible starter failure if the engine doesn't crank. You can try tapping on the starter motor using a blunt object while turning the key to see if it starts. If it starts, suspect a defective starter motor. If it is a manual transmission, you can push start it in gear
Nov 21, 2015 | 2002 Chrysler PT Cruiser
Car won't start and starter is only making clunking noise
You can take out the spark plugs, keep track of your spark plug wire order, try to crank it over see if the engine turns over.
Check voltage on your new battery, some need to charge when new.
check for corrosion on the battery and starter cables.
Sep 29, 2012 | 1991 Saturn SL1
Where is the starter relay located on a 2006 Mercury Grand Marquis
Check under the surge tank near the battery or in a box with all other relays.
Jun 26, 2017 | Cars & Trucks
2000 Pontiac Sunfire won't start
Try checking the oil, the low oil sensor will disable the ignition
May 29, 2017 | 2000 Pontiac Sunfire
85 Chevy Surburban 6.2 diesel. Won't start. We charged the dead batteries and tried to start it. It started cranking then made a loud thud almost grind sound. We replaced the starter solenoid and Still...
Could be internal damage. Put a socket and wrench on the crankshaft pulley and see if engine is seized up. The thud is worrying, suspect major damage if the crank won't turn all the way round. If you can't turn the engine by hand, you will need a new engine (or new vehicle- that is a pretty old suburban, almost ancient to be needing a new engine!)
If engine still turns by hand, have your starter tested.
Oct 15, 2017 | Chevrolet Suburban 1500 Cars & Trucks
Have a 2004 tahoe z71. engine wont turn over. igition lights come one but when turn key to acctualy start engine nothing happens tryed cleaning and tighting battery cables but didnt help.. checked fuzes...
the only thing i can think of is test the small wire to the starter if the wire has power then its the starter if it dont the the ingtion switch
Mar 07, 2011 | 2004 Chevrolet Tahoe
I have a 1993 Ford Explorer. I have tested the starter and put a new solenoid on it. The battery has also been tested good. But when I try to start it all I get is a click.
try replacing the starter sokinoind costs 16 dollars and i conneted to the positive side of the battery ahs two battery wires connected to it and has one small wire wih two bolts that holds it on, and hard to change.takes about 5 minutes if that does nt fis it you have a problrm with the ingtion switch or the starter.
Jan 11, 2010 | 1993 Ford Explorer Limited
Computers & Internet Logo
15 people viewed this question
Top Google Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
David Payne
David Payne
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
