Question about Frigidaire GLTF2940ES Front Load Washer
Wont allow me to change cycles. stuck on heavy duty
  • 139 Answers
Try some contact cleaner ...unplug .dryer pullknob off spray cleaner around the switch to see if this frees up the selector switch.../or replace the switch if it dont work..let me know..an....good luck...joe
Posted on Aug 31, 2010
I changed my fuel filters on my 6.4 l f150 2008 now won't start .I cycled engine but smelled a faint smell and saw light smoke from under hood .charge batt.still won't spin .did started go out too
F350 6.4 L 2008 Wont Start after Fuel Filter Change - Ford Truck ...
www.ford-trucks.com > ... > Super Duty & Heavy Duty
Dec 8, 2011 - F350 6.4 L 2008 Wont Start after Fuel Filter Change Super Duty & Heavy Duty. ... My only suggestions are change them again or take it to Ford. ...Rancho 9000 shocks 1992 F150 XLT 2x4 Standard Cab Long Bed 302 ... Priming it now won't help, because the air bubbles are already past the fuel return line. 2008 won't start after fuel filter change!
Aug 5, 2012
Fuel Filter change problem
Jan 7, 2011
F-350 won't start after oil change and fuel filters changed ...
Dec 10, 2010
Need help fuel filter change now it wont start
Jul 2, 2010
More results from www.ford-trucks.com
Jan 25, 2016 | Cars & Trucks
Red indicator light on the cycle dial stuck blinking
Chek that the door lock is activated if not replace the door lock the other possibility is the anti flood device is activated so chek for a leak in the bottom of the machine
Jul 06, 2014 | Whirlpool duet Washing Machines
I have a Whirlpool Duet Dryer that is locked on the heavy duty cycle, I cant switch to another setting, it wont cancel out. I've tried unplugging it for some time to reset it. It is still stuck o
when you unplug it you're resetting the computer board just like your house computer does,so if it helped by unplugging it i would have to say the board is bad and needs to be replaced.next time send the model number off of the machine
Feb 02, 2018 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Producing debris when in spin cycle
2.13.1 Scrud
If fabric softener is used regularly it will eventually cause a build up within the outer bowl. This can
result in black flakes present in the wash load that can stain garments. To remove scrud follow the
procedure below.
Step1: Add a full cup of a good quality dishwashing powder such as Active or a similar product
into the machine.
Step 2: Set the machine to a Heavy Duty cycle, select a Hot Wash temperature, High Water level
and allow the machine to agitate for 10 minutes.
Step 3: Leaving the lid closed, turn the machine off and allow to soak overnight.
Step 4: The following day, turn the machine on and advance to the spin cycle to drain the water
from the machine. After the water has drained, turn the machine off then back on again, and select
a Heavy Duty cycle, Hot wash, High Water level, and allow the machine to complete a full cycle to
ensure that all of the loose scrud and residual detergent has been flushed away.
Note: If there is an extremely heavy build up the bowl will have to be removed for pressure washing
Dec 15, 2012 | Fisher and Paykel GWL11 Top Load Washer
Washer does not allow hot water to enter machine when you press the heavy duty button. Regular warm cycle or hot works fine. Replaced the water valves, main control panel.
This is a common question we face daily. Certain washing machines allow hot water to enter only during certain cycles. Others allow hot and cold to enter intermittently. Consult your owner's manual to be absolutely sure about this. If you're sure the machine isn't working the way it used to--or should--try these tests:
Is the hot water turned on? If not, turn it on.
Is the washer getting cold water but no hot water? If so, check to see if the control panel
settings are correct.
Thanks for writing to Fixya.com and I am Aparajita. I will be assisting you today.
Mar 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
I cannot choose max spin. When I hit the spin
some lower cycles wont allow high speed spin, try heavy duty.
Nov 24, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Amana Heavy Duty Extra Large CapacityTop Loading Washer 2 speed - 10 cycle Mod. LW8413W2 Mfg. No. PLW8413W2A S/N R-9504056772 Occasionaly,At the end of a wash cycle it will continue on to the next...
my heavy duty 7 speed motor cut off because of over heating and the belt was changed can you suggest a suitable model of fan belt for it. ?
Jul 07, 2008 | Washing Machines
Frigidaire GLTF2940ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
