Question about Garden
Ryobi plt 3043yw, wont start. has new carbie kit & new spark plug
  • 3 Answers
Hey www_mike350,
Just fixed my Ryobi 3043YW. I got this given to me not working and didnt even need it. I already have one. I decided to have a look over it, see if I could get it going.
To my surprise everything looked clean. I checked for spark, that was good, compression seemed good. I took the spark plug out and tipped some fuel in the cylinder, put the plug back in and tried to start it.
If it started I would have suspected the carby, but it still didnt start.
I was really annoyed because everything looked clean but it still wouldnt start. There was fuel, spark and compression, I didnt know what else could make this thing not start.
I pulled it completely apart and found the rotor assembly was the problem. It was causing a timing issue, meaning that it was sparking at the wrong times, when there was no gas in the cylinder.
On the inside of the rotor is a pin or a key that lines up on the shaft and gives the spark its timing. That key was made of cast iron and had broken off, causing the rotor to spin on the shaft out of alignment. This through the timing out.
I lined it up and tightened it and its working again. I couldnt believe it when it started, I have spent hours on this thing.
I will have to try and replace the rotor (Part no. 300952001), otherwise it will slip on the shaft again sooner or later and do the same thing.
Unfortunately I need to replace the gaskets too now as most came apart when I was pulling it apart.
Hope that helps someone out there!
chris12456@hotmail.com
Posted on Apr 30, 2011
Have a ryobi chainsaw 33cc Model RY74003D it starts revs and then stops any ideas how to fix
indicates insufficient fuel supply
most likely a problem diaphragm in the carby-- gone hard
check the price of a carby kit against the price of a new carby (e-Bay) as the kit price is close to the carby price
Oct 26, 2016 | Ryobi Garden
Problems 790r
Carby needs overhauling..
Oct 04, 2013 | Ryobi Three Trimmer Combo
Klx250 wont run it has spark new battery and cleaned carby but wont fire up will occasionaly start and run fine
Remove the filter or filter connection to the back side of the carb and spray it with starter fluid. If it starts when you do that each time, the carbs still have a problem and need to be cleaned out again or adjusted correctly.
Jan 17, 2013 | 2005 kawasaki KLX 250
My 5.5 honda engine on my lawnmower will start but wont stay running already cleaned the carb out didnt help there is no restrictions in the fuel lines im lost please help
it sounds like a fuel problem.
first drian fuel out of tank.
i know you have already cleaned the carby but dis assemble carby and clean with carby cleaner.
re assemble carby & fill tank with fresh fuel.
also clean air filter & check oil level & check spark plug,if the spark plug is black and the tip is blocked with oil build up, then replace.
Oct 22, 2010 | Honda Garden
New Ryobi petrol c/saw wont start.
If it is brand new, sounds like you should return it for the retailer to have repaired.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Dec 05, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Cannot start ryobi 3043 yw grass edger
Check the spark plug and sheck the gap on it then check the wire
Oct 19, 2008 | Garden
Garden Logo
523 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
