Question about Microsoft Windows XP Home Edition
Wave on master volume keeps decreasing on its own
Hi there and thanks for your time!
When I double click on the volume icon in Windows XP I get the 'Master Volume' control. Is there any way to lock these levels so they don't decrease on their own? I keep having to go in and raise the volume of the Wave because something in my system keeps lowering the volume!
Thanks!
Jim
  • Windward May 12, 2008
    Hi Mark,
    It 'appears' it is connected with shutting my external hard drives on and off. I opened the master volume window and played songs in Media player and on youtube. The 'Wave' volume was not disturbed. When I shut off my computer for the night and turned it on the next day, the wave volume was turned down. As I had one of my external drives on, I suspect that is what is doing it.
    I'll do some more experimentation.
    Thanks for your comments.
    Jim
    Honolulu, HI
  • jwmbp Jan 18, 2013
    [RESOLVED] Hi Friends, I had a same problem with this issue, I tried Installing many anti-viruses or anti-trojan viruses, but it didn't worked, then I create my own script to make wave volume up If I have a problem, so If any one interested I would send him those file on his email.
  • 472 Answers
I have nver come accross a setting that will lock the volume to a set level before, but here are a couple of possibilities that you may want to investigate for the cause.
  1. Not all programs use the master volume control, so do, but most adjust the sound by the wav output. Put the mixer onto the desktop, open things like winamp, media player etc and adjust the volume controls on those to see what is doing what.
  2. If you have a multimedia keyboard with a volume control on it, make sure when your typing it's not adjusting the volume at the same time. Again, put the mixer on the desktop out of the way and type as you would normally. It could even be just the vibrations from typing setting it off.
See how you go and post back your results
Posted on May 09, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
Here is where the volume setting is stored for my SoundMAX digital audio device:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\DeviceClasses\{6994AD04-93EF-11D0-A3CC-00A0C9223196}\##?#PCI#VEN_8086&DEV_24D5&SUBSYS_019D1028&REV_02#3&172E68DD&0&FD#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\#Wave\Device Parameters\Mixer\ 2\Controls\ 0
Mixer\0 = volume control
Mixer\2 = wave
Mixer\3 = sw synth
Mixer\6 = cd player
Mixer\8 = line in
Wave on master volume keeps decreasing on its own - wave-master-volume-keeps-decreasing-its-hoeyi0ms024jii13vb1kttfa-2-2.jpg
If you adjust the wave slider and then click out of Mixer\2\Controls\0, and back into the setting, you will notice the data value can range from 0 - 65535.
You may be able to set the permission for System Read to Deny and uncheck inherit from parent setting. That may prevent the system from changing the setting.
Posted on Nov 11, 2014
The Wave On Master Volume does not keep decrease when I uninstall "Asus Porbe II " .
Posted on Jul 16, 2010
If U reduce volume in winamp wav volume is reduced to. If U run winamp and by default volume in winamp se reduced your system volume be also reduced.
Posted on May 31, 2008
Ha i have the same problem except, i cant raise the wave volume control at all, once i raise it and close the master volume dialoug box the wave setting goes back to zero?
one question, do u have any games from EA (electronic arts)?
i heard that alot of those games come with a program called securom which can disable any hardware\software on its own.
Posted on Nov 25, 2009
    New Friend:
Posted on Jan 18, 2013
Volume icon missing
Which operating system ??
In Windows and on a Mac, you can use an icon shaped like an audio speaker to adjust the computer's volume or mute the sound output completely.
Whichever operating system you are running, it is possible to remove the volume icon from the screen.
If you have removed the volume icon accidentally, you may not have a convenient way to adjust your computer's sound volume.
Restore the sound icon to resume using it to adjust the volume or mute your computer's sound output.
Click the "System Preferences" icon on the dock.
If you have removed this icon from the dock, click the Apple icon at the top of the screen, then click "System Preferences."
Click the "Sound" icon in the "System Preferences" window.
Place a check in the box at the bottom of the window labeled "Show volume in menu bar."
The sound icon appears at the top of the screen.
Close the window to resume using your computer.
Restoring the sound icon in Windows 7
Click the Windows Orb (Start button), then click "Control Panel."
Click "Taskbar and Start Menu."
If you do not see this icon, click the "View by:" drop-down menu at the top of the window and select "Small icons."
Click the "Taskbar" tab, then click the "Customize" button.
Click the drop-down menu next to "Volume" and select "Show icon and notifications."
Click "OK" twice and close the Control Panel.
Restoring the sound icon in Windows Vista
Double-click "Taskbar and Start Menu."
If you do not see this icon, click the "Classic View" link.
Select the "Notification Area" tab. Place a check in the box labeled "Volume."
Click "OK" and close the Control Panel.
Restoring the sound icon in Windows XP
Click the "Start" button, then click "Control Panel."
Double-click the "Sounds and Audio Devices" icon, or click "Sounds, Speech and Audio Devices," then click "Sounds and Audio Devices."
Place a check in the box labeled "Place volume icon in the taskbar."
Restoring the sound icon in Windows 2000
Click the "Start" button, then click "Settings" and "Control Panel."
Double-click "Sounds and Multimedia."
Place a check in the box labeled "Show volume control on the taskbar."
Restoring the sound icon in Windows Millennium Edition (ME)
If you do not see this icon, click the "View All Control Panel Options" link.
Restoring the sound icon in Windows 98
Double-click "Multimedia."
Click the "Audio" tab.
Dec 04, 2013 | Computers & Internet
My dell volume icon is deleted
By default, the Volume icon is not displayed when you initially install Windows XP on your system.
To enable the display of the Volume icon, follow these steps:
  1. Click Start, and then click Control Panel.
  2. Double-click Sounds and Audio Devices.
  3. Click Show volume control on the taskbar.
  4. Click OK.
When you have the new desktop features of Windows XP enabled, follow these steps:
  2. Click Sounds, click Speech, and then click Audio Devices.
  3. Click Sounds, and then click Audio Devices.
  4. Click Show volume control on the taskbar.
  5. Click OK.
Thanks, Hope this Helps
Please Rate;)
Gary
Jul 30, 2013 | Microsoft Windows XP Professional
Hello, im using sony vaio VPCEB3J1E,speaker is not working but head is working,what is the problem?
For Vista/windows 7
Check with volume settings.
Right click on the speaker icon in taskbar and select volume control options.
Put a check mark on "All devices currently playing sound".
Make sure you have "The default communication device unchecked".
Place a check mark on both speakers and headphones.
For Windows XP
- Speakers, Headphones
In "Control Panel", select "Switch to Classic View", and open "Sounds and Audio Devices".
In "Sounds and Audio Devices Properties", click the "Audio" tab, and click the "Volume" of "Sound playback".
On the "Master Volume" screen, click "Properties" in the "Options" menu.
Add a check mark to "Playback" of "Adjust volume for" on the "Properties" screen, and check marks to "Master Volume" and "Wave" for the control to be displayed, and click the "OK" button.
On the "Master Volume" screen, remove the check marks from "Mute all" of "Master Volume" and "Mute" of "Wave".
Note: The settings may differ depending on the PC you are using. Please check items such as sound in the manual for the PC you are using.
May 22, 2011 | Computers & Internet
Sound icon not here
To place a volume icon and sound icon in the taskbar follow these steps.
For Volume icon:
1. On Control Panel, double click Sounds & Audio Devices icon.
2. Select Volume tab
3. Check the box for "Place volume icon in the taskbar"
4. Click OK.
For Sound Icon"
1. On Control Panel, double click Sound Effect Manager
2. Select General tab.
3. Check the box for "Show icon in system tray"
4. Click OK.
I hope that solves your problem.
Please comeback and rate this answer. Thank you for using Fixya.
Aug 16, 2010 | Microsoft Windows XP Professional for PC
Sound output is low nowadays even at full volume whereas before it was ok. I didn't change anything with my computer nor did I change my speakers.
Two possible causes.1) Vol Settings changed in windows2) Bad hardware
1) Check your system's sound settings:
For Xp
  • Goto Control Panel
  • Double Click Sound and Audio devices / Sound, Speech, and Audio Devices
  • In device Volume Click Advance
  • Master Volume Control Window will open
  • Increase all the volumes to max, also make sure that Mute us UNCHECKED.
OR
  • From the bottom right corner of your screen in system tray, double click a small speaker icon and open Master Volume Control.
For Vista and Windows 7
  • From system tray (its at bottom right corner of your screen) double click on small speaker icon, it will open Volume mixer
  • Increase the volume to max.
2) If this does not work, then test your speakers by connecting it to some other system and vice versa.
If you get desired sound volume when you connect some other speakers to your system, then you have to change your speakers. And if your speakers are working fine on other system then you may have to purchase a new sound card.
May 17, 2010 | Computers & Internet
Sound/Audio went out after logging out of Skype. Don't think Skype had anything to do with it...if there is such a thing as a soundboard, I think it went SNAFU.
Just restart the computer . double click on the speaker icon and see master volume/wave is muted or not. If there is no icon, insert the motherboard cd and install sound drivers.
Dec 17, 2008 | Computers & Internet
CD Burning gets stuck
Try this: : Decreasing the burn speed If the drive is not recognizing the disc at all, skip to Step 4. Decrease the CD writer's burn speed by half to increase the likelihood of a successful burn. Decreasing the burn speed is a quick, easy way of increasing successful disc burning sessions, at the expense of taking more time to create a disc. The following steps are for Windows XP only. For Windows 98 and Me, decrease the write speed from within the software that you are using to write discs (RecordNow, Easy CD Creator)
  1. Click Start , and then My Computer .
  2. Right-click the drive icon, and select Properties .
  3. Select the Recording tab and reduce the Current Write Speed by half (for example, from 16x to 8x).
  4. Click OK and close the My Computer window. Try burning a CD. If the drive fails to create the CD, go to the next step.
Step 4: Setting up disc recording in Windows XP If the computer does not have Windows XP, skip to Step 6. If you are using Windows XP, use the following steps to ensure that native burning is enabled:
  1. Place a blank disc into the drive. NOTE: If the error <drive letter> is not accessible. Incorrect function. " opens, close it and continue using these steps to correct this problem.
  2. Click Start , and then My Computer .
  3. Right-click the writable drive icon, and select Properties .
  4. If a Recording tab is shown, select the Recording tab, select Enable CD recording on this drive , and then click OK . Try burning a disc again. Continue to the next Step if you are unable to burn a disc. If a recording tab is not shown, continue using these steps. Figure 2: Enable CD recording on this drive c00368150.gif
  5. Look for a Recording tab: If the Recording tab is not shown, Windows XP has not detected the drive as a recordable device. Use the following sub steps to enable the Recording tab:
    1. Click Start , Run , and type regedit in the Open field.
    2. Backup the registry: Select My Computer from the list, click File , Export , type a name that you will remember, and click Save .
    3. Click OK , and browse to the following registry key: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning\Drives
    4. Click the Volume key that matches the CD/DVD drive that is capable of writing discs. If only one drive is installed, one volume key is listed. If you have more than one drive, examine the data values (by double-clicking them in the right pane) to find the correct drive.
    5. With the volume key selected in the left pane, double-click the Drive Type value in the right-pane. Figure 3: Drive Type registry value (CDRW) c01367502.jpg
    6. Type the number 1 in the Value Data field if the drive is capable of recording to CDRW discs (including CD-R discs). Type a 2 if the drive cannot write to CDRW discs but can burn CD-R discs. NOTE: A value of 3 indicates that the drive is only capable of reading discs. Changing this value to a 1 or 2 enables Windows to view the drive as a recordable drive.
    7. Click OK , and close Registry Editor.
Jun 20, 2008 | Dell Dimension 4700 PC Desktop
Microphone and headphone problem
Usually when you double click the speaker icon in the system tray you'll see the volume settings for all your devices. On microphone there is usually an check box for mic boost. Set those to mic boost. Then check that all the sliders in the volumes are one increment below the top but maximum for Wave. Then set the master volume to a comfortable loudness This you can access by a single click to the speaker icon.
Next, you can go to Control Box, click on Sounds and check the settings for speakers/headphone and also for recording where there is usually a routine for checking the recording settings via your microphone made available to you.
Please do not hesitate to ask me for more information and kindly be specific if you can. I'm here to help and will get back to you in a reasonable period of time.
Hope this fixed your problem and thanks for using Fixya.
Regards,
Worldvet
May 26, 2008 | Compaq Presario 700 470024-192 Notebook
No sound on my computer
If you are using windows then double click on speaker icon in system tray near TIME display.. it will open a window, now see if there is a check box marked as MUTE or volume level set to low (in Master Volume & Wave ).. Un-check if mute is selected or level up the volume slider... if there is no icon then use control panel to go for sound settings.. if it say No Device then use your computer driver CD and install sound driver and restart your PC... please inform if it does work.
Plese Rate Me.. Thanks.
May 13, 2008 | E-Machines eMachines Desktop PC
Microsoft Windows XP Home Edition Logo
5,539 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
