Question about Zebra Eltron LP 2824 Thermal Printer
We have Quickbooks Pro multi-store POS and a zebra LP2824 tag printer. The Zebra printer just stopped printing when given print command. The computer print bar pops up and says it printed but nothing prints
SOURCE: Slow printing to LP2824
This appears to be normal operation.
Posted on Nov 06, 2007
SOURCE: LP2824 feeds a label but wont print on it?
can you give more info? it sounds like you driver is set to thermal transfer mode but you have a direct thermal printer (LP not TLP)
Posted on Nov 09, 2007
SOURCE: LP2824 Zebra printer software
Try downloading ZebraDesigner Pro here.
It should have a familar MS-Paint type interface. A small learning curve.
Posted on Oct 02, 2008
  • 6 Answers
SOURCE: Zebra label alignment
you can adjust this in the template file for your price tags. how did you create your basic price tag label? in the zebra label creator? if so, make the adjustment there. if you have a .ejf file for your price tag label, you should be able to open it in notepad and add the height in pixel dots with the "q" or "Q" command from the EPL programming handbook. This can be a little tricky, but with some trial and error, you can get it.
EPL2 programming guide:
http://www.zebra.com/id/zebra/na/en/documentlibrary/manuals/en/epl2_manual__en_.DownloadFile.File.tmp/14245L-001rA_EPL_PG.pdf?dvar1=Manual&dvar2=EPL2%20Programmers%20Manual%20(en)&dvar3=2746e
Posted on Apr 28, 2009
Joed911
  • 4338 Answers
SOURCE: Zebra LP2824 Printers user guide
I just uploaded it to this site for you.
Click on this link, then select "free" on the right hand column. Then let the timer timed out. Put the security code in the box and then download it.
http://rapidshare.de/files/48142380/2824UsersGuide_1_.pdf.html
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Aug 17, 2009
I use a LP2824 with Quickbooks POS, and every day i will print something and the printer will stop halfway throught the job. The only solution i have found is reinstalling the drivers, then an hour later...
its usually clogging within the printhead, remove the roller and give it a clean, also download fresh drivers incase there is some kind of corruption within the driver you are using, . finally clean the print head by opening the lid and cleaning the upper inside of the lid. (it is black in colour)
May 18, 2011 | Zebra TLP 2824 Printer
Tags cannot be printed properly in QB POS Version 8. Printer Argox OS 214-TS
The tag printer used by Qb POS is the Zebra LP 2824.
The argox is not compatible.
Jul 04, 2010 | Intuit Quickbooks POS Tag Printer PC...
Problem with my Zebra LP2824 printer
You have to calibrate the printer to solve this problem
Check following to solve this problem
1)Press the feed button and hold it for 1-2 seconds switching printer on.It will calibrate the labels.
2)Install Zebra Designer driver from CD.After installing Zebra designer Add printer Zebra Designer LP2824.After installing driver right Click the printer Zebra Designer LP2824 and go to printing preferences then select advanced option and calibrate printer.It will calibrate printer
3)Check the label size is properly set in printer or not.Label width and label height in printer settings should be same as label which you are using .
Aug 22, 2009 | Zebra Eltron LP 2824 Thermal Printer
Printing a 2.25 in label on Zebra LP2824. Prints
Recalibrate the printer and you should be good to go. Do this by turning the printer off, press and hold the button and turn on the power. When the light flases red let go and it will calibrate, at the end it will do a printout. Reboot the printer and your fixed.
Jul 28, 2009 | Zebra Eltron LP 2824 Thermal Printer
Zebra LP2824 not printing
Sounds like you put your printer into line mode. Line mode prints code so you can see what is sent to the printer to look for possible mistakes in the code.
To switch from line mode back to page mode.
  1. Turn printer off.
  2. Press and hold the feed button down. And switch printer on.
  3. Release the feed button when the LED flashes red.
  4. When the LED flashes green, press down the feed button.
  5. When the LED flashes amber release the feed button.
  6. Try printing now that the printer is back in page mode which is used for print your labels; line mode prints the labels code.
  7. Do this fast or else it wont work if you are slow.
Jan 13, 2009 | Zebra LP 2824 Printer
Zebra LP2824 Not Printing
I had the same problem and could not fix it but called Zebra headquarters and they gave me this solution and it works! It sounds crazy but it works. Turn off the printer on the switch on the side. press and hold the button on the front of the machine while you turn it on. The light will turn red then release the button the light around the button will then turn a solid greed then blink green. While it is blinking green press and hold the button again until it the light turns orange and then release the button. This apparently puts your printer into line mode or something but anyway it works!
Oct 02, 2008 | Zebra Eltron LP 2824 Thermal Printer
Aug 14, 2007 | Zebra Eltron LP 2824 Thermal Printer
Apr 24, 2007 | Zebra Eltron LP 2824 Thermal Printer
Zebra Eltron LP 2824 Thermal Printer Logo
49 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
