Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Did you ever get an answer on what is wrong with your tv
Lower, center part of screen has a 3D look and all white lettering is broken up half pink and half green. This is only on the bottom of the screen from left to right and peaks at the very center, by that I mean it projects the botton half like a roller coaster. Any I deas
I have the exact same problem. Any help would be great
  • kimz19 Jun 09, 2008
    I am having the same issue. Once I let the TV warm up, I can turn it off and wait for a "clicking" sound and then turn it back on and it works fine.
  • Richard Gorenflo
    Richard Gorenflo Jul 10, 2008
    rgflo64 YesI am having a similar problem, and also at the top of the screen has a swoop on the right side
  • Philips Master
  • 3,459 Answers
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
did you ever get an answer on what is wrong with y - 3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Oct 15, 2010
Half the screen to my flat screen tv is Pink! Whats wrong?
T'Con board fault. Contact any service technician to replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 18, 2014 | Televison & Video
Half of my TV screen is 3D all the time
It's seem to be a T-Con board problem. If you don't deal with electronics repair, call to a service center. If you deal with it, first thing is to search for service manual or schematic diagram. For more articles on how to repair this issue visit jestine's yong blog.
Cheers !
Dec 23, 2017 | Samsung UN46C8000XFXZA UN46C8000 46 3D LCD...
Half screen has white line and half screen is ok. half screen with white line has picture also shake
Hello, sit down it's bad news, the display (screen) is most likely bad. the good news, it should still be under warranty. contact Sony, and they should take care of this issue, thanks, Terry
Oct 08, 2012 | Sony XBR46HX929 3D LCD TV
Pink horizontal lines on samsung plasma tc when white background
I have this same tv and have the same problem, anytime there is a white background there is this pinkinsh tint in the middle of the screen, easily seen during those Apple commercials.
Aug 13, 2012 | Samsung 3D Plasma TV PN58C8000YFXZA...
Sharp tv has small black and white image in black and white and half screen pink
Sounds like your LCD Control board went bad. Very small chance it is your main board since you said you cant bring up a menu.
Apr 11, 2012 | Sharp Televison & Video
Our LN40A630 has three horizontal white lines across the screen on power up (center, center of upper half , and center of lower half). After about five minutes the lines go away. Tried Picture Test in...
This is a sign of your LCD panel beginning to die. Sometime soon those lines won't fade away and will become permanent parts of your TV screen.
Considering the fact that your TV is approx 3-4 years old, this is normally the expected lifespan of a TV. Once the TV becomes unwatchable, your best bet would be to begin shopping for a new one.
Mar 07, 2011 | Samsung LN40A630 40 in. LCD TV
PANASONIC TH-42PX60U 42 - half of screen not working
I had the same issue. I am going to replace my scan buffer boards. The upper half of mine works but the lower half is black so I would replace the lower Scan buffer board but in case of future issues I have ordered both upper and lower for $44.
The scan buffer boards are fairly simple to locate. Open up back of tv there are two biffer boards identical. The item or product code on them contain letters either SU or SD (Scan up and Scan down)Look up tv parts and item code you will find a place to order or just get the 1 800 number from tv manufacturer.
Jun 18, 2010 | Panasonic TH-42PX60U Television
The tv picture looks like should be wachting it whith 3d glasse
This is a very common failure on Projection TV sets. Its called a convergence failure. Here are some common symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
The other common problem is cloudy lens fluid. After many years the coolant in the blue and green lens will become cloudy and cause the screen to look dull, red/orange, bright white, etc. You may even see halos around objects on the screen.
You can see some example photos and find a solution here on Fixya.
Nov 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Toshiba 61H70
Does it look like a 3D image?
Would you be able to post a picture of the TV with the mention lines?
Aug 16, 2008 | Toshiba 61H70 61" Rear Projection...
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
