Duel fuel range installed in Jan 08 worked fine until we unplugged it and pulled it out onto the kitchen floor to install a tile backsplash. Plugged it back in and the display is dead.We have reset the circuit breaker and know we have power with a circuit tester. Is there something we can do to get this working?
The cord may not be securely fastened at the terminal block when you pulled the unit out it could have pulled one of the connections loose check the cord for good connection at the terminal block and if the top is working like mrappliance asked then you have a problem with the board or wiring to it but with the recent movement of the unit I would start with the power cord
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
does anyting else work? burners
