Question about Frigidaire FAC084N7A Air Conditioner
I have a brand new frigid air cinditioner and it is not cooling, i got it 2 days ago and it's on 24/7
  • Frigidaire Master
  • 43,501 Answers
If you have a unit that has stopped cooling in a couple of days... tkae it back and get another one...you got a lemon...
do not mess with it or tear it apart... just put it back in the box and return it for another one...
heatman101
Posted on Aug 31, 2010
Just put in brand new alternator 2 days ago. Now it wants to stall when slowing down and at intersections.
Have car scanned at autozone or similar. My guess is egr valve or IAC. Egr exhaust gas recirculating valve, IAC idle air ?ontrol valve.
Dec 22, 2015 | 2004 Chevrolet Chevrolet TrailBlazer EXT
Got hot no heat blowing cold air
Heater core blocked or its bad but make sure u have antifreeze and not water in the radiator this will make it blow cold make sure radiator is full check fluid
Jan 06, 2014 | 1992 Geo Tracker
No heat when car sits idol, only when moving.
is this your first car?
I will presume the fan is running at full speed and heat max is set and the that you tried recirc lever. fresh air is less heat...
Cab heat bad. right?
only when moving, what?
Ill guess that no heat sitting idle for 30mins. TIME MATTER.
as does time of day and if first start of day and if the ambient temperature (out door temp counts, and guess what no country or stated told so i cant look it up, me fail)
first off,
the modern engine can take a huge long time, to heat up dead cold and not driven , that is why the op guide tells you,
start car ,wait 45 seconds and drive off slowly,
the warms the engine fastest , saving 90%of all engine wear.
this is proven fact by Germany long ago and now with SAE.org.
hard fact.
now if you know the car warmed faster before.
then this is possible 2 ways.
1: bad thermostat. (slow)
2: or the engine is running so bad, that the heat to the water jackets are weak.
the cab heat will be the same as the engine water coolant
if the engine is cold, so will you be. hard fact.
there are no electric air heaters here...
here is a frozen air page.
http://www.fixkick.com/Cooling-engine/Frigid-motor-cab.html
2 tests.
1: does the engine hit 180F or more and hold?
2; does it do that , at the same speed, as when new?
if not we trouble shoot that first. (fan works, and blows)
Sep 23, 2013 | 2006 Suzuki Grand Vitara
AIR CINDITIONER IN A 2000 BUICK LASABRE
The first thing to do is have the system pressures checked to see if you have a leaking compressor, repair as needed.
Aug 29, 2012 | 2000 Buick LeSabre
Haier esa410ke manual
my haier air conditioner won't blow cool air just took it out the window like last 5 months ago it was blowing cool air now i put it back in the window now don't blow cool air just hot air.
Jul 14, 2012 | Haier ESA410K 10,000 btu ECO-Friendly...
HI MY NAME IS TONYA WE HAVE A AIR CINDITIONER PROBLEM COMPRESSOR WAS MAKING NOISES LIKE SQUEAKING SO WE GOT A NEW COMPRESSOR, EXPANSION VALVE, ACCUMULATOR PAG OIL46 (10 OZ) 134A FREON (4 CANS) REMOVED...
HI there #1 before you put freon in did use a vacuum pump and pull too the right vacuum
specification if not you have air in the system.
#2 if you put 4 cans of freon you over charged the system must vehicles a/c systems use 1lp 5oz
you must remove freon first and use vacuum pump and put system in vacuum for abut 1hour
too mack shore system is air and muster free.
ones that is don you can charge system be careful not too over charge OK
good luck
ziggyone
Jul 03, 2011 | 2006 Dodge Grand Caravan
Air-cinditioner problem
Yes,there is a actuator motor that is bad that controls the air flow,the dash will have to be removed to repair
May 28, 2010 | 2003 Suzuki Aerio
Will not go into defrost
Did you change the thermostat in heat pump? or did you change it when you replaced the board?
Dec 06, 2008 | Goodman CLQ36AR49 Air Conditioner
Frigidaire FAC084N7A Air Conditioner Logo
41 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
