Question about Gateway (4000531) Motherboard
Motherboard problem I have a gateway gt series 5220 computer the problem is that when I push the front pannel switch to turn the computer on the things that will turn on is the dvd-cd rom and the fans only. The hard drive won't turn on and I do not heard the bip and there is no monitor signal. I change the power supply and still won't work The motherboars is a NVIDIA geforce 6150 am2 ubtx 1394 and the proccessor is an amd athlon 64 x2 38800
  • 2 more comments
  • dia12345 May 09, 2008
    Thank you for you help
  • Anonymous Jan 13, 2009
    I was working on a client's computer yesterday that exhibited this symptom. No BIOS beep and no HDD activity. However, the power comes on and the fans in the chasis operate. The CPU needs to be replaced. May not be worth the time and aggrevation to replace the CPU with another AMD chip.
  • edved10062 Jan 13, 2009
    If you replaced with a different CPU, which one did you use? I'm having this same issue too and I'd like to try and determine if I need a new motherboard/CPU or both.
  • wolfetrain Mar 19, 2009
    HI. My brother has the same problem with his gateway gt 5220. Motherboard is fried. Anyone know where I can get a new motherboard?
  • 35 Answers
If you are getting no beeps then this would usually indicate the motherboard is fried. If you have a test video card that you can put into the machine I would try that and seeing if you get a signal then. If you still don't get anything and you want to look at getting it fixed I would take it someplace to have at least a diagnostic run on it. Some places will do a test of the video card for you at no cost.
Posted on May 09, 2008
Replace the CPU with another, compatible, AMD chip.
Posted on Jan 13, 2009
I experienced a similar problem. I have a pci diagnostic card that I used to check the motherboard for post codes. It stopped at FF. This indicates it is the CPU. I do not have an AMD Athlon XP X2 to swap with but even so, the motherboard could be bad as well.
Posted on Dec 17, 2008
DX4300-05 How to open Gateway panels
1) Jaws of Life.
2) Acetylene torch
Gateway Support > DX4300 series of Desktop PC > Main Support page,
Looking at the Front of the computer, is how you determine Right side, and Left side.
The Right side removes with two screws, as far as I can see.
The Left side is a little harder to tell.
Gateway Support is of no help on this one. At least that I have found. Not in User Manual, because it's generic. One size fit's all.
However looking at the Rear View, it looks like the usual style to me.
Hard to make out though, because it's painted Black.
ON the back edge of the Left Side Panel, appears to be a Thumbscrew.
Even with centerline of Power Supply fan.
But there also appears to be a type of flip lock.
Or should state; push over to the inside; a little.
Then using the Fingerpull molded handle on the Left Side Panel, pull the side panel back.
Usually there are Slots in the metal frame, of the computer case.
The side panel has Tabs that stick out, with hooked end.
Along the top, and/or along the bottom.
You pull the side panel back until it stops, then move back forward about an inch, or so. Then bring the side panel straight out.
Then post back what you see, and we'll try to figure it out together.
Post back in a Comment.
Mar 22, 2013 | Gateway Computers & Internet
Gateway Gt 5220 computer will not connect to internet
Open the Device Manager, Network Adapters, Is the Ethernet adapter enabled? Do ALL your Windows and Gateway updates. Your Ethernet driver can be found here, select your OS, 32 or 64 bit :
Feb 13, 2013 | Gateway GT5220 PC Desktop
My power switch on gateway desktop, GT5404 does not turn on it only flashes briefly then goes off.
1) FOLLOW Anti-Static Precautions
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE reaching inside your unplugged from power computer.
Computer on a table, computer unplugged from power, computer case open;
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
The front of your computer is the Front Panel. The area of contact pins, that the main wires from the Front Panel go to on the motherboard, is the Front Panel header.
There are two contact pins that the Power On switch wires connect to.
I would like you to jump across those two pins, and see if the Power Supply comes on;
Gateway Support > GT5404 Desktop PC > Main Support page,
Click on the Support Documents tab.
(Driver / BIOS / Applications / Patches / Support Documents / etc)
Click on -> 1009371 - Support Documents
Click on Components in the list.
Scroll down to the Motherboards subheading.
Click on the blue -> 4006158R - Intel (Coryville) 945G Motherboard
In the list click on Product Views
Click on O - Front Panel Connector (Front Panel header)
Pins 6 and 8, which are the two pins in the Red areas, is for the Power On switch.
The above ATX power on switch is used a Lot.
It is inside the plastic Power On Button assembly.
If this is the correct style of Power On switch, and yours is bad, you can use a hair dryer to gently soften the plastic of the Power On Button assembly, and replace the Power On switch.
Do Power On switches go bad? Yes. A LOT.
Those who do not know how to diagnose usually wind up replacing the motherboard, or Power Supply.
For additional questions, or to have me clarify any of the above, please post in a Comment.
Oct 12, 2012 | Gateway Computers & Internet
Need diagram for connection on motherboard 4006272r
Gateway 4006272R motherboard;
Foxconn (Bengal) RS780 motherboard.
[ In otherwords the motherboard chipset is an AMD RS780 series,
Scroll down to the bold black subheading - IGP (HD 3xxx, HD 4xxx ]
This motherboard,
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
In the list click on -> Product Views
Now click on -> S - Front Panel Connector
Motherboard installed in the computer case, the Front panel header is at the Bottom/Right corner.
It has -> F_PANEL <- silkscreened in white underneath it.
Two rows of pins.
The pins on the Top row are numbered EVEN.
The pins on the Bottom row are numbered ODD.
Starting on the LEFT side, coming across to the Right;
Top row;
Pins 2, 4, 6, 8, No pin, 12, and 14.
Bottom row;
Pins 1, 3, 5, 7, 9, 11, and 13.
Pins 11, 12, 13, and 14 are NOT USED.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
These pins are in the Orange blocks.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
These pins are in the Blue blocks.
C) Pin 9 is N/C. Not Connected. Reserved for factory use.
Black block.
D) Pins 2 and 4 are for the Power On LED. (Light)
Pin 2 is for the Positive ( + ) wire.
If the PWR ON LED is dim when the computer is on, switch the wires around.
These pins are in the Green block.
E) Pins 6 and 8 are for the Power On switch.
These pins are in the Red block.
F) There is NO Pin 10.
Black block.
Again, Pins 11, 12, 13, and 14 are Not Used.
B- CPU Power Connector is at the upper left corner of the motherboard. This power cable is power for the Processor.
MUST be plugged in.
A general example of a 4-pin ATX +12 Volt power cable, and it's respective connector on the motherboard,
Note the Lock on the side of the power cable's connector, and matching Lock Tab on the motherboard connector.
F- Main Power Connector also has a Lock, and Lock Tab.
General example of a 24-pin ATX main power cable, and it's respective connector on the motherboard,
D - CPU Fan Connector is above the processor socket, and near the top outside edge of the motherboard. ONLY plugs in one way.
For additional questions please post in a Comment.
Aug 10, 2012 | Gateway Computers & Internet
Where does the power switch connect on a Gateway GT5056?
the power switch is in the front pannel of the motherboard if you have multitester the power wsitch will indicate 5v the power switch is to be conected to the 5v and the ground normally the front pannels details will be given in the motherboard
Mar 27, 2011 | Gateway GT5056 PC Desktop
Panel1 power sw i need to no how to wire it properly
Gateway Support > GT5432 desktop computer > Components >
Motherboards > 4006157R - ECS MCP61- P AMD Motherboard >
Product View > T - Front Panel Connector,
The Power On switch connects to Pins 6 and 8.
Should you not understand the chart, or need additional info regarding this, just post in a Comment.
Jul 12, 2010 | Gateway GT5432 Refurbished AMD Desktop...
I have installed windows 7 series now my
Your front audio panel needs motherboard or computer case specific drivers.
Go to the manufacturers website and get the board or chipset drivers that are compatible with Windows 7.
Mar 16, 2010 | Intel DG43NB Motherboard
Need wiring info for front pannel on6787
Hi there.
Get a strong flashlight and a magnifying glass (if you have one). On the motherboard look for the front panel, it should be marked PWR and coloured green, also the plug that connects to it should be marked PWR_SW. On some boards there are no colours but the markings are the same, so a good close look.
Have a look at these pictures for an idea >>>>>>
Please post back with the results and any more advice if needed.
Good luck and thanks for choosing FixYa!!
Jun 29, 2009 | MSI Computers & Internet
Gateway Gt 5220 computer powers on but will not boot
It's either the video card, memory, or motherboard.
I had the same problem with one of my desktop's. It ended up being the motherboard. Had to turn the computer on and off, on and off until eventually it would power on.
I'd start with reseating the memory and video card. Is your video onboard?
Let me know what happens and I'll keep throwing ideas your way.
Best of luck!
Feb 26, 2009 | Gateway GT5220 PC Desktop
Gateway (4000531) Motherboard Logo
809 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
