Question about Dryers
Heat will not come on. I've vacumed under, around, and taken off vent and cleaned it out now what? It worked before.
  • 10,319 Answers
Gas or electric dryer?
Posted on Aug 31, 2010
  • Dryers Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
GE gas dryer DSXH47GGWW- starts fine and begins to heat up then shuts off with a message that the lint filter needs cleaned. The lint filter has been completely cleaned and vacumed inside, outside and...
With no lint anywhere around the dryer the thing to check if havent already is the venting itself to see if outside it is blowing and not restricted or blocked
The control is sensing poor air flow and throws up the "clean filter" when air flow is restricted all be it from the filter clogged, or blocked/restricted vent
Gene
Aug 25, 2011 | GE Dryers
No heat comming out of floorboard vent all the rest of the vents work
sounds like you might have a vacume line that came off somewhere. check under the dash also some have lines under hood by firewall.
Jan 06, 2011 | 1998 Chevrolet Blazer
Air vents won't move nor will the heat to cool vent move
Sounds like you have a broken vacum hose somewhere or it became disconnected. I would look under the hood for very small vacum hose near the firewall or near or disconected vacum hose near evaporator case.
Oct 19, 2010 | 1995 Chevrolet C/K 2500
Floor vent will not work. only getting heat from
theres a vaule on the passenger side and it has a vacum hose on it take it off and put a new in place
Mar 07, 2010 | 2001 Chevrolet Suburban
Truck heating system changes from heat, defrost, and vent
thats normal, you are taking vacume from the heater system when you are under a load,but it returns when you let back up on pedal,if you wanted to alter this affect you might try installing a vacume ball to the heater vacume hose,
Jan 02, 2010 | 2001 GMC Sonoma Extended Cab
1991 cavalier vl model diverter dor for vent,heat,defrost. not working is this controled by cable or is it a vac controlled system thank,s
No look for vacum hose under hood that runs into fire wall, make sure it has vacum, if no vacum add vaum to it.
Dec 10, 2009 | 1991 Chevrolet Cavalier
Vent was cloged with a birds nest now it wont heat
IF POSSIBLE REMOVE THE DRYER VENT FROM THE REAR OF THE DRYER AND VACUME OUT AS MUCH LINT FROM THE DRYER ITSELF SOME LINT MAY HAVE GOTTEN BACK INTO THE BLOWER
Sep 02, 2009 | Whirlpool GEW9200L Electric Dryer
Drum rotates but does not heat. I';ve taken apart the entire vent and cleaned it. Still no heat.
You have to use a multimeter to find the component that has failed
Jul 05, 2009 | Maytag Dryers
No air from vents or defrost but fan works
You more than likely have a vacume hose that has come off at the vent switch or under the hood. Unfortunatly you will have to pull the vet switch out of the dash to see if there are any vac. lines off. You can visibly inspect the rubber and plastic vacume lines under the hood. Just be careful how you handle the plastic lines as they become brittle from the heat under the hood after a period of time.
May 04, 2009 | 1999 GMC Safari
Air vents
I was having a similar problem with the vents not redirecting air when selected. I went onto the auto zone wed site and found very helpful schmeatic diagrams for electrical and vacume systems. That lead me to investigate a possible vacume leak. There was a vacume hose broken tucked away by the battery. I repaired the hose with thick wall heat tape and now the vents move normally. The vacume starts on the P/S top of engine runs by the battery into the fore wall. Once in the P/S foot well you will see a purple hose that you can quickly check the vacume pressure. It should be a noticable vacume. If not work your way back to the engine. If you do have a good vacume there then I would suggest going to a auto wreckers and picking up a new heater control module for around $90.00 in stead of the $240.00 fro the dealer. All you need is a phillips screw driver to replace it.
Aug 04, 2008 | 1999 Pontiac Montana
Dryers Logo
Top Dryers Experts
