Question about Sport & Outdoor - Others
In what position is the transducer tobe pointed. straight out the back or pointed down.
    Problem Solver:
  • 15 Answers
Straight out the back with the flat or dome side facing down, so it can send and receive signals off the bottom. it should also be located about a half to 1 inch above the lowest point of the boat, so you won't tear it off if you run a ground.
Posted on Aug 31, 2010
How to install wiring
Start at the transducer, mount it then pull the transducer wiring forward using a wire snake. At the same time pull forward 14ga wire to attach to your power leads.
on most boats I've done this process takes from 90 minutes to 3 hours.
The transducer and head unit are easy to put on. Getting wire from point A to point B is the time consuming part.
Once you have your wires pulled forward route them to your head unit at your console. Drilling of access holes may be required.
Connect power, plug in the transducer line.
Black to negative at the battery, red to positive, don't forget to put in the in line fuse included in your box.
Good luck.
May 24, 2015 | Lowrance Elite-7 Hdi Sonar/Gps Combo,...
Installing transducer
I assume you're talking about a transom mount transducer. Best if the leading edge of the transducer is even/level with the hull and tilts slightly down in the back or trailing edge of the transducer. Also try to eliminate a gap between the leading edge of the transducer and the hull.
Mar 25, 2014 | Hummingbird Boating
2007 sportster gas reserve location
Hi Anonymous, if you have a carbuerator the petcock/fuel valve is located on bottom rear of the left side of the fuel tank. With the long end of the lever pointing straight back the fuel valve is in the off position and no fuel will flow to the carbuerator, with it pointing straight down the valve allows fuel flow from the gas tank to the carbuerator, with it pointing straight forward it is in reserve mode and you have roughly 1/2 to 1 gallon of fuel left in the gas tank. If you are fuel injected the is a low fuel warning light either on the dash or speedometer. If you have a fuel gauge refuel before it hits empty just like your car. Good luck and have nice day.
May 13, 2012 | 2007 Harley Davidson XL 883 Sportster
Hello- I have a Hummingbird 550 fishfinder who suddenly isn't reading depth, fish or the correct temperature. I have looked at all the settings, wires hooked up to it and have disconnected and...
Check the transducer for cracks or large amounts of growth. Also make sure the transducer is still in the correct position as when installed. Next check the entire length of the cable to make sure there are no breaks, kinks, or stress points.
If you have to send it back for service MAKE SURE YOU BACK UP ALL OF YOUR DATA AS IT CAN BE RETURNED BLANK!
Nov 12, 2017 | Humminbird Fishfinder 550
One of the transducers in my Harman Kardon Soundsticks III is loose. How can I reattach in the tube?
HI, the best way is to use a 4 1/2" long nose plier. 1. Insert the plier in to the center hole of the satellite's transducer that has come loose (small round speaker that comes in a set of four inside the clear tube) 2. Gently pull until the transducer is in position (edges aligned, wires not tangled in the rear) 3. Give a thorough pull until the transducer is flush against the tube housing (make sure not to clasp the point on the transducer's grill to roughly inorder to minimize damage to the surface) 4. Enjoy P.S. I went to the hardware store and purchased the pliers for $3.99 if you don't already have a pair handy.
Jan 19, 2011 | Harman Kardon SoundSticks Computer...
Attempted to update a single level "diamond" ball shower handle for an older Delta 600 series. Everthing seemed to go well, but when I turned the water supply back on, and when the handle was pointed...
On a single lever shower handle, when the handle is pointing straight down the water is off. The handle will then rotate 270 degrees to the right through cold - warm - hot. What has happened is when you took the other handle off the new handle didn't go into the same position as the old one. So now when the handle stops at the down position the valve is still open probable running cold water. The fix is to take the handle back off. Rotate the valve into the off position so that water stops flowing and reinstall the handle pointing down. Now when you rotate the handle to the right you will get cold then warm then hot at 270 degrees and back to off when the handle is pointing back straight down. If you are still having problems please let me know and we will examine it a little closer.
Jul 18, 2010 | Delta Home
Sonar only reading the surface
First, ensure that the transducer face is pointing down when the boat is level in flat water. You may want to do this step like a tv antenna, adjusting the angle of the transducer while watching the screen.
If that doesn't work, then try moving the transducer further into the water and repeat step one.
Sonar systems are (largely) directional, and will work best when parallel with the seabed (or lake bed etc)
Jan 20, 2018 | Lowrance LCX-104C
Raymarine a65 transducer 200kh fine 50kh not reading bottom
First do a factory reset and determine that all the setting are correct. You can get this info from the manual. Remember you will loose any saved way points when you do the reset. If that does not sort you out;Remove transducer from transom mount and duck tape it to a broom stick so that the transducer face is facing down. With the boat standing still in calm water and the ducer hooked to the DSM25 push it below the water and see if it see bottom on 50khz.The idea here is to get the ducer in another location to see that it is not getting reflections of the boat. 50Khz is very prone to reflecting of stuff around it. If you still have a problem I would send the ducer and DSM25 unit back under warrant .No need to send A65 back it should not have a problem.
Mar 30, 2009 | Raymarine A65 Combo GPS...
Setting instruction for Accurist world time wrist watch
Same just happened to me, performthe following:
The analogue hands are not precisely synchronised with
the digital time?
1. Press the lower right button to move the mode indicator
hand to CHR.
2. Pull the lower right button out one click. The hour, minute
and UTC hands will retract towards the straight up 12 O’clock
position. You will see UTC on the top half of the digital display.
3. Press the upper right button to advance the hands to the
straight up 24-hour position. Use the lower left button to go in
reverse.
4. Press the upper left button. You will see HR on the top half
of the digital display. Press the upper right button to advance
the hour and 24-hour hand clockwise until they both point
straight up at the 24-hour position. Use the lower left button to
move the hand anti-clockwise.
5. Press the upper left button. You will see MIN on the top half
the minute hand clockwise or the lower left button to move
anti-clockwise until it is pointing straight up at the 12 O’clock
position.
6. Push the lower right button back in one click.
The watch malfunctions in some way and the above
procedures do not work.
1. Press the lower right button until the mode indicator hand
points to TME.
2. Pull the lower right button out one click. Press the other
three buttons down simultaneously for three seconds and
release. You will see 8’s on the digital display.
3. Press the upper left button. You will see UTC on the top half
the hands of the top dial to the straight up 24-hour position.
Use the lower left button to go in reverse.
position.
Jul 06, 2008 | Watches
Vornado will not stay in fixed position
put some rubber washers between the floor bracket and the fan housing and tighten the knobs in which position you want
Aug 07, 2007 | Vornado Circulating Fan
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
