Question about Garden
How do I replace and adjust the cones on a Dixon ZTR3014 Z drive riding mower
4 Suggested Answers
wadembly
  • 448 Answers
SOURCE: i need a repair manual for a scotts riding mower.drives a few fee
it could be the axel they have spider gears in them & the teath could be sheared or the the rearend is low on fluid
Posted on Jun 05, 2009
SOURCE: How do I adjust blade drive belt tension on
Belt was excessively worn and after replacement and adjustments made all ran well. Thnaks.
Posted on Sep 03, 2009
SOURCE: How do you change the
Click on the link below and follow the "step by step" instructions to change the battery in your Dixon 8500 lawn mower
http://www.ehow.com/how_4965607_change-lawn-mower-battery.html
Posted on Oct 24, 2010
Mower blades start an stop on Dixon zero turn 42 in deck
PDF]OM, ZTR 5421, 1994, ZERO TURN: CONSUMER - Dixon
www.dixon-ztr.com/ddoc/DIXO/...USen/DIXO1994_USen_5421_.pdf
The information in this operator's manual applies to all Dixon ZTR Model 5421 Mowers. .... Before backing your Dixon Mower; stop, turn around and look. 13. ... startsvibrating, and any damage should be repaired before restarting and ... 13 GA stamped steel construction, 3 blades, 42" cut width, cut height approximately.
Sep 17, 2015 | Garden
Removing clutch cone from cox stockman ride on mower
Old question, but maybe this will help others:
Here is the answer for all Cox Stockman machines fitted with a single large bolt through clutch cone. Below it you'll find a VERY GOOD REASON WHY YOU SHOULD NOT DO IT!!!
1. Disconnect the negative (-) lead from the battery.
2. Loosen the four bolts that secure the engine and slide engine backwards.
3. Remove the 'R Clip' on the link rod at the front of the clutch carrier, then disconnect the link rod.
4. Loosen all four grub screws on the drive plates and slide them as far out as you can.
5. Raise the rear of the machine and secure with axle stands or some other method that will leave you with a SAFE WORKPLACE!
6. Remove the 9/16" locknut on the clutch pivot bolt (under the rear of the machine), then unscrew the pivot bolt. Do not try to drive it out with a punch, as it is screwed into the adjusting plate.
7. When bolt is removed, slide the rear of the carrier across to one side and the front of the carrier to the other side ( to clear the bracket at the front of the carrier) and work the whole assembly forward enough to clear the rear chassis rail. Then drop it down and remove the assembly from the machine.
To replace the cone, lock the large bolt head into a vice, then use a 2 or three pronged lock bar to unscrew the pulley from the bottom of the bolt. Then, fit a new cone onto the bolt and reverse teh entire process.
Now, here's why you should NOT DO THIS AT HOME!!!!!!!!!!!!!!!!!!!!!!!
If you don't read this part, I absolutely guarantee that it will end up costing you far more money than if you'd sent the machine to a Cox Service agent ( I am one).
About the only thing on any Cox machine that requires specialist knowledge and tooling to correctly repair, is the drive cone clutch system. Removing and replacing the drive cone itself is the easiest part of the process and I have seen it done by plenty of people. I've also spent plenty of time then fitting another new cone to their machine, because the one they put on is now stuffed. The drive cone is just one part of an assembly and if the entire job is not done correctly the FIRST TIME, the new cone can be destroyed in a very short time. And the only way to do the entire job correctly is to have the special tools and knowledge. No if's, no but's and no maybe's!
Oct 21, 2014 | Garden
Dixon 5020 mowerhow do i install drive belt on 5020 dixon
If, and I'm sure it is, like all other riders, remove the deck, turn the mower up on it's side and supported with a lawn chair or the like, it won't hurt the mower, remove the electric deck drive unit from the crankshaft by taking the center bolt out and pull it off, remove the clutch tensioner far enough to get the belt off it, then remove the belt from the motor pully and the hydrostat drive pully and pull the belt out towards the front. replace the belt with new one and put it back together.
Oct 15, 2014 | Garden
What weight of hydraulic fluid is used in a dixon lawn mower
The motor takes 30 SAE. the drives take 20/50 SAE motor oil. I contacted the manufacturer of the hydro gear drives to find out what was used when I rebuilt one. There is only one manufacturer of all hydro gear drives. Their recommend Mobile 20/50 SAE.
Apr 05, 2013 | Dixon Ticonderoga NEW 61" DIXON ZERO TURN...
Looking to buy Drive Cone for Deckson ride on mower
Can't help you with the source, but I also want one.
The old part on my machine has a one inch hole (25.4mm) and I suspect yours has this also as back then B&S engines sported a one inch shaft. I'm thinking that I might have to get one machined, but finding that thick fibre material to start with will be a problem also.
Dec 13, 2012 | Garden
Garden Logo
247 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
