Question about Meade DS-2114 ATS (325 x 114mm) Telescope
Bracket that holds moter drive - Meade DS-2114 ATS (325 x 114mm) Telescope
  • 3,186 Answers
Some parts are available from Meade. Call their customer service department here:
http://www.meade.com/support/index.html
Posted on Aug 31, 2010
How do i get the hard drive out?
Gateway GT5056 Desktop Hard Drive Caddy Bracket Holder Mount HDD 2JB35 005
Look at this picture. It should look like the bracket your drive is mounted in. You must remove this caddy to get at the other 2 screws. above where you removed the 2 screws from the side of the drive, there should be a screw that holds this bracket to the frame. You must remove this screw. ALso there may be a spring loaded clip that stops the bracket from sliding out, you must lift or press this before sliding bracket.
good luck
May 03, 2014 | Gateway GT5056 PC Desktop
Starter motor solenoid wont engage
There is condenser shaped part attched to the starter moter this is the part which makes the starter moter to spin and when it is stuck the moter does not spin you can check it by one person sitting in the car holding the key to start position and another one hit it softly with some spanner or something The starter moter will move there is a small gear in it which requires replace ment Or the other possible reason can be the carbon brushes in the starter moter are worn out or the place where these brushes touch on armature the place is worn out that Y ou will only come to know when you will take the moter away from the engine Lastly I hope you might have checked your battery that it is giving sufficient current to the moter
Aug 16, 2012 | 2003 Volkswagen Jetta TDI
Rear passanger electric window keeps falling down. buick century 2000. Have it taped up, is it the moter or just off the track? What do I have to do? to tell what is wrong?hanks
either the cable is worn or broken, or the window has come off the old down bracket that holds the glass in place,, remove the inner panel of the door and look to see that the window is attached to the mechanism and that the window glides in the door haven't come loose
Jun 01, 2011 | 2000 Buick Century
How to change the alternator on my 2000 grand voagear
This is for a 3.3L motor
Hope this helps, it it does please leave feedback and vote Thank You and Good Luck
REMOVAL
  1. Release hood latch and open hood.
Removal/Installation of Battery Cables 81929864
  1. Disconnect battery negative cable.
  2. Remove windshield wiper housing, refer to the Windshield Wipers and Washers for proper procedures.
  3. Remove accessory drive belt.
Generator Mounting Bracket 81929870
  1. Remove bolt holding top of generator mount bracket to engine air intake plenum.
  2. Remove bolts holding outside of generator mount bracket to generator mount plate.
  3. Remove bolt holding top of generator to mount bracket.
  4. Remove generator mount bracket from vehicle.
  5. Rotate generator toward rear dash panel.
Generator 81929868
  1. Disconnect the push-in field wire connector . from back of generator.
  2. Remove nut holding B+ wire terminal to back of generator.
  3. Separate B+ terminal from generator.
Generator Pivot Bolt 81929871
  1. Remove bolt holding bottom of generator to lower pivot bracket.
Generator 81929872
  1. Remove generator from vehicle
INSTALLATION
  1. Place generator in position on vehicle.
  2. Install bolt to hold bottom of generator to lower pivot bracket.
  3. Place B+ terminal in position on generator.
  4. Install nut to hold B+ wire terminal to back of generator.
  5. Connect the push-in field wire connector into back of generator.
  6. Rotate generator forward away from dash panel.
  7. Place generator mount bracket in position on vehicle.
  8. Install bolt to hold top of generator to mount bracket.
  9. Install bolts to hold outside of generator mount bracket to generator mount plate.
  10. Install bolt to hold top of generator mount bracket to engine air intake plenum.
  11. Install accessory drive belt.
  12. Install windshield wiper housing, refer to the Windshield Wipers and Washers for proper procedures.
  13. Connect battery negative cable.
  14. Verify generator charge rate.
Jan 02, 2011 | 2000 Plymouth Grand Voyager
How do i replace heater moter
For 4.0L, inside the engine compartment, on the passenger side firewall, remove the coolant overflow bottle retaining strap remove the coolant overflow bottle and bracket. Unplug the blower motor. Remove the 3 blower motor bolts.Remove the blower motor. Remove the blower motor fan from the motor shaft for access to the motor attaching nuts. For the V-8, you just need to unbolt the blower motor to remove.
Mar 16, 2010 | 1996 Jeep Grand Cherokee
Spin cycle is not working
one possible problem the lid swicth might have broken but if you hear a moter noise when it trying to spin the swictch is ok you can verify
if washing machine agitates during wash cycle
if no agitation newer design has a drive coupling between moter and transmission lean machine back
you will find debries center of machine about 8 inches back usually black rubber the drive coupling
has 3 pins on each outside peice that fit into the center bushing lean machine back have second person for safety unplug machine to change drive coupling there are two clips that hold pump to top of moter remove clips slide pump off shaft remove two screws from top of pump clips unplug wiring harness
undue clips remove moter drive coupling peices can be remove by pulling or can use large flat blade and work from oposites sides till plastic parts come off
reassembly place outside parts one on transmission one on moter install center part on transmission side
line up pins from moter to line up with 3 holes in center part normally top clip i install first so gravity assist with install of bottom clip reinstall screws plug in harness line up pump with moter shaft and reinstall clips run check if no noise from moter when lid is closed then lid switch might be bad the new style of washer is front serviceable there are two screws bottom outside corners of panel remove
light pressure pull panel forward then lift is hinged at
top back roll back there are two brass clips catch front of clip with flat blade screw driver and move top of handle toward back of machine clip will pop off wiring for lid switch on top of case needs to be unplugged outside case will tilt toward you then can be lifted off alignment tabs at bottom front there are two screws where lid switch is held to top of case can be seen when case is removed good luck ron
Dec 10, 2009 | Kenmore Washing Machines
Will fill up with water but will not spin and just makes a buzzing noise?
there are two possible problems one the lid switch might be broken there is a small tab front right corner of lid that goes down into a hole to operate the switch which i beleive is still good because you can hear the moter hum there is a drive coupling between the moter and transmission if you lean the machine back you will find black rubber debries in the middle toward the front of machine before taking apart unplug from power the pump has two clips that hold it on top of moter there are two screws in two clips that hold the moter to a metal plate next to transmission the wiring harness plugs in to side of moter the drive coupling can be worked off gently with a wide screw driver from moter and transmission each plastic piece has three
pins that line up and fit into a hard black
rubber center the trick is lining it back up and clipping the metal supports back on moter i normally clip the top one back on first gravity assist with correct placement of moter to reinstal bottom clip reattach wiring harness two screws in moter clips reinstall pump will probably have to turn moter shaft to align with pump reinstall pump clips
Dec 07, 2009 | Roper RAS6233KQ Top Load Washer
I cannot get the alternater out of my 1997 Dodge Grand Caravan. It is a 6 cylindar 3.3 engine. The Chilton manual is no help at all. I have managed to remove all the bolts holding it on, but I cannot even...
3.3L & 3.8L Engines
  1. Disconnect the negative battery cable.
  2. Remove the windshield wiper/motor module assembly.
  3. Remove the accessory drive belt.
  4. Remove the bolt securing the top of the alternator mounting bracket to the engine air intake plenum.
  5. Remove the bolts securing the outside of the alternator mounting bracket to the alternator mounting plate.
  6. Remove the bolt securing the top of the alternator to the mounting bracket.
  7. Remove the alternator mounting bracket from the vehicle.
  8. Rotate the alternator toward the dash panel.
  9. Unplug the push-in field wire connector from behind the alternator.
  10. Remove the B+ nut and wire from behind the alternator.
Alternator removal-3.3L and 3.8L engines
  1. Remove the bolt securing the bottom of the alternator to the lower pivot bracket.
  2. Remove the alternator from the vehicle.
To install:
  1. Install the alternator into position on the vehicle's engine.
  2. Install the bolt securing the bottom of the alternator to the lower pivot bracket.
  3. Connect the B+ wire and tighten the retaining nut to 75 inch lbs. (9 Nm).
  4. Plug in the push-in field wire connector onto the back of the alternator.
  5. Rotate the alternator forward away from the dash panel.
  6. Install the alternator mounting bracket in position on the vehicle.
  7. Install the bolt to secure the top of the alternator to the mounting bracket.
  8. Install the bolts to secure the outside of the alternator mounting bracket to the alternator mounting plate.
  9. Install the bolt to secure the top of the alternator mounting bracket to the engine air intake plenum.
  10. Tighten all of the alternator mounting bolts to 40 ft. lbs. (54 Nm).
  11. Install the accessory drive belt. Be sure the drive belt is correctly routed on the engine and correctly seated on all of the pulleys.
  12. Install the windshield wiper/motor module assembly.
  13. Reconnect the negative battery cable.
  14. Verify the charging rate of the alternator.
LET ME KNOW IF THIS HELPED.
Oct 18, 2009 | 1997 Dodge Grand Caravan
Black & Decker BDTF1010B Tower
when you take all the screws out slide the back down. there is a screw at the bottom holding it from slideing the 9th screw so to speak. you have to take out the u shaped pin on the rod once that u shaped pin is out thats where you will find all the screws to the bracket holding the moter in place take all those out too. it seems like alot but it is really not.
Jul 12, 2008 | Black & Decker BDTF1010B Tower Fan
Is there supposed to be some kind of a bracket holding the hard drive in a Acer, Aspire 1690 Series notebook, or does the hard drive just slide in without a bracket. I need to install a new hard drive in...
Dear Customer,
Acer hard drive brackets or caddies are available for all the notebook series. i would recommend you to go for a bracket for the hard drive rather than just sliding it in. For information regarding the brackets try the following site
http://www.laptopking.com/searhbrandresults.asp?brand=acer..
Please Rate this Solution.. Thank You.. Good Luck!!
Jul 11, 2008 | Acer Computers & Internet
Meade DS-2114 ATS (325 x 114mm) Telescope Logo
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Meade Optic Expert? Answer questions, earn points and help others
