Question about True GDM-41 Refrigerator
Whereis the ballast located on a tbb-3g - True GDM-41 Refrigerator
How do you remove the evaporator cover on a Tbb-2 cooler?
PDF]True Manufacturing Company, Inc. - Fixitshop.com
https://fixitshop.com/manuals/TECHNI~1.PDF
Top Removal for TBB and TDD ... Top Removal for Various Coolers - TSSU, TWT, TUC ... End Cap Replacement-T-Series Swing Door ... GDM 2 Door Cooler IDL Light Diagnosis ... If you keep the Condenser clean you will minimize service ...
[PDF]installation - True Manufacturing
https://www.truemfg.com/assets/...Website/TDB_TBB.../tbb_english.pdf
Your TRUE cooler when properly maintained will give you many years of trouble-free service. TO LOCATE REFRIGERANT ..... Removing bracket from skid. Removingbracket from cabinet. 1. 2 .... tab holding the door cord slides out the back. ... The switch is located on the front of the evaporator housing toward the front of .
Nov 08, 2015 | True TBB-2G-S Stainless Steel Beverage...
Whereis the fuel filter location of fuel filter
fuel filter location 2006 chrysler pacifica
Oct 06, 2012 | 2004 GMC Sierra 1500 Crew Cab
Ice build up and leakage in unit
The condensate drain line is clogged. Defrost it by pouring warm water and baking soda down the tube located bottom of pan under blower. Repeat until water flows easily
Apr 30, 2011 | True TBB-2G-S Stainless Steel Beverage...
Voicemail flashing light will not turn off even after deleting all messages.
SOME WORKAROUNDs - which MAY NOT WORK for everyone!
while ensuring that the TBB line is ON HOOK - NOT OFF HOOK:
1) LISTEN to your NEW VM through the Portal. If you listen through Email forwarding - this will NOT cancel the flashing VMWI.
2) Access your TBB VoiceMail from another phone (cell) or through RemotePhone. LISTEN to your NEW VM from there.
The flashing VMWI should be OFF and back to normal operation! You need to repeat the above steps for any NEW VM.
•You need to have at least one NEW VM that you have not listened to for the above to work. So if there are no NEW VM, phone your TBB line and create one. Then LISTEN to it from the Remote Phone/ cell phone, or delete it from the Portal, and the light should go off.
•Note that listening to or deleting OLD VM (whether in CURRENT or SAVED folders) will do nothing!
Jul 02, 2010 | Cell Phones
Fridge is too cold even at lowest setting and freezing drinks.
The thermostat sounds like it is out of calibration and stuck closed. A good replacement would be a Ranco A12-1560 mounted in the evaporator (cold) coil.
Nov 07, 2009 | True TBB-3G-S Commercial Refrigerator
How do i adjust the temperature in a True TBB-4G? It's too cold. Where is the thermostat?
If memory serves it is in the middle of the back left corner inside of the unit. Should be numbered 1-9 Generally 3 - 5 is correct setting. Higher the number colder the box. Most of my customers have theirs set on 5.
Aug 13, 2009 | True TBB-4G Commercial Refrigerator
I can't get the fluorescent tube to light up when the doors open.
Most fluorescent lighting have ballast in them it more then likely just needs replaced. I have included a how it works link for you HERE
I hope this helps you fix your beverage cooler.
Aug 14, 2008 | True TBB-2 Beverage Cooler
True TBB-2 Cooler issue
BY to I take it yu mean top area inside cooler. If that is the case and yu are sure the drain is clear it could possibly be one of the following.
1: rusted/ corrodid evaporator drain pan
2: coil in cooler partially frozen
Jun 28, 2008 | True TBB-2 Beverage Cooler
True GDM-41 Refrigerator Logo
73 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
christian nielsen
Are you a True Refrigerator Expert? Answer questions, earn points and help others
