Question about HP DeskJet F380 All-In-One Printer
Status: offline/online I am a novice in the use of a computer, a computer "dummy". My problem with the printer is---when the status is on-line it prints. Sometimes the printer goes offline and will not print from the computer. How do I get the status to stay on-line?
    Brigadier General:
  • 6,966 Answers
One way to make the printer go "on-line":
1. opening your "Printer & Faxes", the HP DeskJet F380 would be shown as an installed printer, by doing a right click, you would be presented with various options including making it go online.
There are two (2) areas that you can configure to make it stay always online:
i. in the same "Printer & Faxes", right click on the HP DeskJet F380, click on "Properties", in the next window click on the Advanced tab, tick "Always available", set Priority to "1", in the "Printer" tab, uncheck "Power Save".
ii. open your "Device Manager" (right click on "My Computer", click on Properties, click on "Hardware" tab, click on "Device Manager" button. Expand your "Universal Serial Bus controllers" (click on the + sign of the last entry), right click on each and everyone of your "USB Root Hub". Click on "Properties", click on "Power Management" tab, uncheck "Allow the computer to turn off this device to save power".
After each and every re-configuration it is of course required that you click on Apply/OK.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 09, 2008
Why the offline message
Check the status of the printer at Control Panel. Set it to online if it's shown as offline. If this doesn't fix the problem, check whether installing the vista driver available at your printer manufacturer's website helps.
Step 1:
a. Click Start, go to Control Panel and select Hardware and Sound.
b. Click Printer.
c. If the Printer is offline, it shows "Offline" status. If the Printer is online it shows "Ready".
d. If the Printer is offline, set it to online.
e. Right-click on the printer and select "Use Printer Online".
f. The display should change to ready when the printer is set to online.
Read More....
How to Fix an Offline Printer eHow and HP Printer Support
Thanks,
Jul 16, 2014 | HP Officejet Pro L7780 Printer
Offline change
Just go to Devices and Printers from Control Panel, Right click on your Printer and click on See Whats Printing or Print Status, Once you click on it the Printer Spool Window would appear there click on File and make sure use Printer Off line is not checked. If its not checked and you have the same issue its an issue with the driver the Printer has to be reinstalled.
May 14, 2013 | Toshiba E-Studio 3040c Color Copier
My printer (MFC-490-CW)print status is offline change online
If you want to make it online, than make sure it is on and connected to your computer, Once you are sure about this than
Go to control panel than Printers and Faxes
There You need to right click on printer and than Use printer online
IT will Put you printer back online.
Nov 10, 2009 | Brother MFC 490cw Color Inkjet...
How to change status of printer to ready mod
Open Printers and Faxes on your computer. Select the printer for which you want to change the status, right click on it and select the option Use Printer Online/Offline.
Aug 05, 2009 | Acer Computers & Internet
Printer status offline needs to be online
Do you mean it says "offline" under the printer icon in your PC's printer dialog box?
Right click it , then select "use printer online".
Please let me know
Apr 04, 2009 | Zebra 110Xi III Plus Thermal Printer
Nothing happens when i tried to print from my computer the status is offline what is wrong
same thing, woring one minute, next minute, offline. cords plugged in , no reason i have found but it happens all of the time
Sep 02, 2008 | HP DeskJet F380 All-In-One Printer
Photosmart 2575 printer is offline - won't print
Good Day,
One thing you can try instead of deleting the doucment writer is to change the default printer. You can do this by right-clicking on the HP printer icon and selecting "set as default" from the drop down box. Also try turning the printer off and back on aswell as restaring the computer if you have'nt already. Did that printer ever work from that computer? How is it wired, by "switcher" do you mean a shared printer through you network(was printer sharing configured properly), or an A-B printer switch. Please clarify
Hope this helps for now
Jul 01, 2008 | HP Photosmart C6180 All-In-One InkJet...
Printer light keeps blinking and status stays offline even it is READY
UNINSTALL AND REINSTALL THE DRIVER SOFTWARE BRO...................
IT MAY LEAD U 2 A SOLUTION.........
TRY IT
Nov 14, 2007 | HP Deskjet D2360 InkJet Printer
Offline status
Under the control panel, click on the printer to bring up the print dialog. Go to printer at the top of page, drop down the menu and uncheck use printer off line. Should bring it on line.
Hope that helps
Oct 30, 2007 | Brother MFC-640CW All-In-One InkJet...
HP DeskJet F380 All-In-One Printer Logo
274 people viewed this question
Ben Johnson
